Author Topic: How to design a 7.5kV AC source?  (Read 1610 times)
Offline CristianM
« on: January 18, 2019, 03:48:06 PM »
Hello! I need to design a high voltage AC source with the following specifications:
- 7.5kVpp max. output voltage;
- adjustable output voltage;
- isolated output;
- sine wave output;
- adjustable output (sine wave) frequency in the range 40Hz-2kHz;
- max. 1 mA output current.
Can someone recommend a possible solution? A basic transformer or flyback supply (maybe recommend some components, schematics) or even a commercial solution?
Re: How to design a 7.5kV AC source?
« Reply #1 on: January 18, 2019, 04:25:14 PM »
I'll venture a solution...
Use a full-bridge or H-bridge of MOSFETS such as the IRF820, where each side is driven by two 50% duty cycle square wave signals of different frequencies with a difference between the frequencies that is the output frequency you want that would drive both sides of a small ferrite transformer primary.  For example, if you want 1 kHz, you would drive one side perhaps with 200 kHz, the other with 201 kHz.   You could rectify mains power for example to power the H-bridge, for example, from 220 VAC to 300 VDC, with a full-wave rectifier, and use a buck converter or even a small variac on the primary side to adjust the DC voltage on the bridge.  A ferrite transformer, for example, with a 10:350 turn ratio so that you could transform the 300 VDC voltage up to the 7.5 kVAC range.  A high voltage polypropylene capacitor (perhaps 1000 pF?) would need to be placed on the secondary output of the transformer to filter high frequency (200 kHz) and leave a clean sine wave, or you might have to build a pi lowpass filter if you want the high harmonics really attenuated.   You will probably also need a DC block capacitor as well in series with the primary winding.   What I've described is open loop and I think to close the loop you would need to use an optoisolator to feedback a signal to the buck converter to regulate the voltage, or you could just put a resistive load (like a 10 megaohm 10 watt resistor) to try to provide some stability to the output voltage and act as a bleeder resistor if you don't need super accurate output voltage.
« Reply #2 on: January 19, 2019, 04:46:02 PM »
Hi Cristian and welcome to HVF
All your specifications would be reachable with a ferrite core with a HV winding and driven by a half-/full-bridge. The frequency is however what makes this less trivial, you would most likely need to make a voltage modulator to get such low frequencies.
I got no experience in the following suggestion, its just an idea I just had when thinking about how defibrillators work. You could form a high voltage pulse through a large output inductor to slow down the current and get a sine wave from a square input.
Offline CristianM
« Reply #3 on: January 20, 2019, 09:31:14 PM »
Thanks for the suggestions. I'll try to implement them.
May 05, 2021, 10:30:49 PM
May 05, 2021, 10:13:16 PM
May 05, 2021, 08:29:59 PM
May 05, 2021, 07:03:25 PM
May 05, 2021, 06:57:17 PM
May 05, 2021, 06:38:06 PM
May 05, 2021, 06:02:21 PM
May 05, 2021, 04:51:47 PM
Rapy2
May 05, 2021, 01:03:30 PM
May 05, 2021, 12:21:48 PM
Rapy2
May 05, 2021, 11:17:11 AM
May 05, 2021, 11:04:35 AM
May 05, 2021, 09:47:58 AM
May 05, 2021, 09:40:40 AM
May 05, 2021, 12:01:57 AM
May 04, 2021, 09:48:43 PM
May 04, 2021, 09:02:34 PM
May 04, 2021, 07:17:08 PM
Rapy2
May 04, 2021, 11:19:14 AM
post Re: Flashover
May 04, 2021, 09:56:30 AM
May 04, 2021, 01:50:12 AM
post Flashover
May 04, 2021, 01:24:10 AM
Rapy2
May 04, 2021, 12:57:12 AM
Rapy2
May 04, 2021, 12:34:29 AM
May 03, 2021, 10:08:05 PM
SimonNwardUK
May 03, 2021, 10:07:26 PM
May 03, 2021, 09:38:30 PM
May 03, 2021, 07:29:14 PM
markus
May 03, 2021, 06:20:47 PM
Rapy2
May 03, 2021, 04:02:39 PM
Rapy2
May 03, 2021, 01:19:51 PM
May 03, 2021, 12:43:48 PM
May 03, 2021, 08:16:19 AM
May 03, 2021, 08:14:37 AM
May 03, 2021, 04:18:29 AM
May 03, 2021, 04:16:35 AM
Rapy2
May 02, 2021, 11:55:57 PM
May 02, 2021, 11:32:39 PM
post Re: Prototype boards
May 02, 2021, 09:20:23 PM
May 02, 2021, 09:15:02 PM
May 02, 2021, 08:36:18 PM
Lilsara21
May 02, 2021, 08:03:03 PM
May 02, 2021, 07:48:15 PM
May 02, 2021, 07:45:41 PM
May 02, 2021, 07:37:08 PM
May 02, 2021, 07:35:46 PM
May 02, 2021, 04:52:01 PM
post Prototype boards
May 02, 2021, 04:27:33 PM
May 02, 2021, 03:46:12 PM
May 02, 2021, 03:39:45 PM
