Author Topic: about drsstc interrupter connection  (Read 515 times)
Offline Ect1453
« on: December 28, 2018, 02:50:31 PM »
Hey, guys, I need a suggestion. you know we use fiber optic transceiver to connect an intruperter to drsstc. what else does he use?  Anybody try Optocoupler?. or do you have any other suggestions ?
Offline sjsimmo
  • Australia
Re: about drsstc interrupter connection
« Reply #1 on: December 29, 2018, 02:20:47 AM »
Hi Ect1453, :)
Some people just use shielded RCA cable, or similar. Of course this doesn't give the same amount of isolation as Fibre Optic though.
On my first SSTC I used an optocoupler at the SSTC end, and shielded RCA cable to the interrupter. This works, but probably shouldn't be used at the high power levels of a DRSSTC, unless using a simple 555 interrupter (or similar micro-controller/midi/laptop free design).
When testing my SSTC, I did notice some noise making it into the interrupter circuit. This may be prevented by another optocoupler at the interrupter end of the RCA cable, but I'm not entirely sure.
« Last Edit: December 29, 2018, 02:27:25 AM by sjsimmo »
« Reply #2 on: December 29, 2018, 12:55:50 PM »
I have also used shielded mini-jack for audio input to a SSTC and it only gave me problems. I spend more time shielding it than building a isolated interface would have. I did also make a mistake by having the audio interrupter in the enclosure under the coil. But the noise issue was more the audio source that would halt, reboot and lock up when I turned up the voltage to the cool too much.
I only make coils with fiber connected interrupters now, for less noise problems and human safety :)
Offline Ect1453
« Reply #3 on: December 30, 2018, 06:46:26 AM »
The BNC connector for the drsstc cutter produced in China also added output. it makes sense to me.   what kind of solution Do you think BNC would have?
« Reply #4 on: January 03, 2019, 11:54:34 AM »
With BNC you will have some good standard parts that is well shielded, but constructed for 50/75 Ohm impedance.
The biggest problem with direct cabling is not shielding it, but that the shield conducts noise from the coil to the interrupter/keyboard/whatever you are sending the signal from.
Today at 11:46:44 AM
Today at 11:45:11 AM
[Vacuum tube Tesla coils]
Today at 11:40:18 AM
Today at 07:46:25 AM
post Re: Si-wafers, ideas?
Today at 07:07:57 AM
Today at 05:45:55 AM
June 24, 2019, 09:26:47 PM
Bert911
June 24, 2019, 04:58:39 PM
[Static electricity]
Doros
June 24, 2019, 01:56:17 PM
Avenger
June 24, 2019, 01:28:59 AM
June 24, 2019, 12:47:16 AM
juuzpo
June 23, 2019, 10:58:48 PM
Golddustpeak
June 23, 2019, 07:22:47 PM
Jeff B
June 23, 2019, 05:52:56 PM
June 23, 2019, 03:15:53 PM
donnersm
June 23, 2019, 10:09:40 AM
June 23, 2019, 10:07:04 AM
June 23, 2019, 08:50:14 AM
June 23, 2019, 01:28:20 AM
June 23, 2019, 01:17:50 AM
June 23, 2019, 01:04:13 AM
June 23, 2019, 01:02:55 AM
Coupling
June 22, 2019, 11:10:02 PM
June 22, 2019, 08:45:17 PM
June 22, 2019, 08:36:34 PM
June 22, 2019, 06:18:22 PM
June 22, 2019, 05:47:22 PM
June 22, 2019, 05:21:58 PM
June 22, 2019, 06:10:01 AM
June 21, 2019, 09:08:16 AM
June 20, 2019, 08:58:07 PM
badpeter
June 20, 2019, 07:28:00 PM
post Re: Ideas needed!
June 20, 2019, 05:13:57 PM
post Re: Why did 4HV die??
June 20, 2019, 05:07:41 PM
Bert911
June 20, 2019, 02:14:55 PM
June 20, 2019, 12:53:58 PM
June 20, 2019, 12:09:27 PM
post Choke-input DC-filter
June 20, 2019, 11:43:58 AM
June 20, 2019, 08:57:42 AM
June 20, 2019, 04:06:00 AM
June 20, 2019, 03:50:56 AM
June 19, 2019, 11:29:28 PM
June 19, 2019, 01:40:16 PM
June 19, 2019, 10:49:45 AM
June 19, 2019, 10:43:32 AM
[Light, lasers and optics]
June 19, 2019, 10:03:54 AM
June 19, 2019, 10:02:21 AM
June 19, 2019, 09:35:52 AM
badpeter
June 18, 2019, 11:35:16 PM
June 18, 2019, 08:22:23 PM
