Author Topic: about drsstc interrupter connection  (Read 1412 times)
Offline Ect1453
« on: December 28, 2018, 02:50:31 PM »
Hey, guys, I need a suggestion. you know we use fiber optic transceiver to connect an intruperter to drsstc. what else does he use?  Anybody try Optocoupler?. or do you have any other suggestions ?
Offline sjsimmo
  • Australia
Re: about drsstc interrupter connection
« Reply #1 on: December 29, 2018, 02:20:47 AM »
Hi Ect1453, :)
Some people just use shielded RCA cable, or similar. Of course this doesn't give the same amount of isolation as Fibre Optic though.
On my first SSTC I used an optocoupler at the SSTC end, and shielded RCA cable to the interrupter. This works, but probably shouldn't be used at the high power levels of a DRSSTC, unless using a simple 555 interrupter (or similar micro-controller/midi/laptop free design).
When testing my SSTC, I did notice some noise making it into the interrupter circuit. This may be prevented by another optocoupler at the interrupter end of the RCA cable, but I'm not entirely sure.
« Last Edit: December 29, 2018, 02:27:25 AM by sjsimmo »
« Reply #2 on: December 29, 2018, 12:55:50 PM »
I have also used shielded mini-jack for audio input to a SSTC and it only gave me problems. I spend more time shielding it than building a isolated interface would have. I did also make a mistake by having the audio interrupter in the enclosure under the coil. But the noise issue was more the audio source that would halt, reboot and lock up when I turned up the voltage to the cool too much.
I only make coils with fiber connected interrupters now, for less noise problems and human safety :)
Offline Ect1453
« Reply #3 on: December 30, 2018, 06:46:26 AM »
The BNC connector for the drsstc cutter produced in China also added output. it makes sense to me.   what kind of solution Do you think BNC would have?
« Reply #4 on: January 03, 2019, 11:54:34 AM »
With BNC you will have some good standard parts that is well shielded, but constructed for 50/75 Ohm impedance.
The biggest problem with direct cabling is not shielding it, but that the shield conducts noise from the coil to the interrupter/keyboard/whatever you are sending the signal from.
Today at 10:23:24 PM
Today at 09:36:02 PM
Today at 07:36:23 PM
Today at 04:45:18 PM
Today at 01:26:41 PM
Today at 07:53:04 AM
Today at 06:37:03 AM
Today at 04:18:29 AM
Today at 01:35:07 AM
July 10, 2020, 11:35:05 PM
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
July 08, 2020, 09:16:42 PM
July 08, 2020, 09:00:04 PM
July 08, 2020, 04:25:53 PM
July 08, 2020, 10:03:25 AM
July 08, 2020, 08:39:10 AM
July 08, 2020, 08:34:02 AM
July 08, 2020, 04:39:10 AM
post Measuring LED efficiency
July 08, 2020, 12:46:23 AM
July 07, 2020, 10:28:37 PM
July 07, 2020, 10:09:22 PM
July 07, 2020, 09:36:53 PM
July 07, 2020, 09:20:12 PM
July 07, 2020, 09:07:10 PM
July 06, 2020, 10:29:17 PM
July 06, 2020, 06:53:26 PM
July 06, 2020, 01:18:03 PM
