Author Topic: about drsstc interrupter connection  (Read 1329 times)
Offline Ect1453
« on: December 28, 2018, 02:50:31 PM »
Hey, guys, I need a suggestion. you know we use fiber optic transceiver to connect an intruperter to drsstc. what else does he use?  Anybody try Optocoupler?. or do you have any other suggestions ?
Offline sjsimmo
  • Australia
Re: about drsstc interrupter connection
« Reply #1 on: December 29, 2018, 02:20:47 AM »
Hi Ect1453, :)
Some people just use shielded RCA cable, or similar. Of course this doesn't give the same amount of isolation as Fibre Optic though.
On my first SSTC I used an optocoupler at the SSTC end, and shielded RCA cable to the interrupter. This works, but probably shouldn't be used at the high power levels of a DRSSTC, unless using a simple 555 interrupter (or similar micro-controller/midi/laptop free design).
When testing my SSTC, I did notice some noise making it into the interrupter circuit. This may be prevented by another optocoupler at the interrupter end of the RCA cable, but I'm not entirely sure.
« Last Edit: December 29, 2018, 02:27:25 AM by sjsimmo »
« Reply #2 on: December 29, 2018, 12:55:50 PM »
I have also used shielded mini-jack for audio input to a SSTC and it only gave me problems. I spend more time shielding it than building a isolated interface would have. I did also make a mistake by having the audio interrupter in the enclosure under the coil. But the noise issue was more the audio source that would halt, reboot and lock up when I turned up the voltage to the cool too much.
I only make coils with fiber connected interrupters now, for less noise problems and human safety :)
Offline Ect1453
« Reply #3 on: December 30, 2018, 06:46:26 AM »
The BNC connector for the drsstc cutter produced in China also added output. it makes sense to me.   what kind of solution Do you think BNC would have?
« Reply #4 on: January 03, 2019, 11:54:34 AM »
With BNC you will have some good standard parts that is well shielded, but constructed for 50/75 Ohm impedance.
The biggest problem with direct cabling is not shielding it, but that the shield conducts noise from the coil to the interrupter/keyboard/whatever you are sending the signal from.
Today at 02:54:04 PM
Today at 02:27:26 PM
Today at 02:19:32 PM
Today at 02:10:57 PM
arctichominid
Today at 02:10:18 PM
post Re: New projet OmegaDR
Mugi30
Today at 12:27:06 PM
post Datasheet Question
Today at 08:10:27 AM
Today at 07:57:48 AM
Today at 07:01:44 AM
Today at 01:01:25 AM
Today at 12:50:28 AM
Today at 12:35:11 AM
09d08
Today at 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
[Radioactive Sources]
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
June 01, 2020, 05:27:08 PM
post Neon transformer
Iyacht
June 01, 2020, 10:02:58 AM
June 01, 2020, 03:38:05 AM
June 01, 2020, 03:07:36 AM
May 31, 2020, 11:59:47 PM
erlendse
May 31, 2020, 11:05:19 PM
nix85
May 31, 2020, 11:03:45 PM
boxermick
May 31, 2020, 09:25:36 PM
May 31, 2020, 09:25:26 PM
nix85
May 31, 2020, 09:19:32 PM
May 31, 2020, 09:12:09 PM
May 31, 2020, 09:10:39 PM
nix85
May 31, 2020, 09:00:46 PM
May 31, 2020, 08:57:42 PM
nix85
May 31, 2020, 08:50:17 PM
May 31, 2020, 08:40:02 PM
nix85
May 31, 2020, 08:32:03 PM
May 31, 2020, 08:20:07 PM
May 31, 2020, 08:13:21 PM
nix85
May 31, 2020, 07:45:04 PM
nix85
May 31, 2020, 07:42:19 PM
May 31, 2020, 07:32:32 PM
May 31, 2020, 07:23:35 PM
May 31, 2020, 07:05:04 PM
sgtraf
May 31, 2020, 06:41:13 PM
nix85
May 31, 2020, 05:54:56 PM
Mugi30
May 31, 2020, 04:15:17 PM
