Author Topic: Help for people buying the "12-48 Volt 1800/2500 Watt ZVS induction Heater"  (Read 1429 times)
I built my first experimental cheap power supply and it was a great success!
12 laptop chargers put together for 40V 51A.
Offline flyrod
I did blow up one Mosfet, but that was my own fault for paralleling one gate with too low of a resistance.
So do these boards use the same pull up resisters for gate drive?
5 minute stress test at full power. 1800 Watt peak input power.
Flyrod: "So do these boards use the same pull up resisters for gate drive?"
If you mean "do they use the same gate drive circuit as does the 1000 watt unit?"
Yes, for the 1800 watt unit that I have, at least.
The same 470 ohm 5 w wirewound resistor, 10K resistor, 12 volt zener  and FR307.
If you mean: "do all 4 gate drivers use the same pull up resistors for gate drive?"
The answer is still "yes".
Pete Stanaitis
A new 2200 Watt power supply made from server power supplies, and with steady cameras :)
Test of it in a long induction heater run is being edited and will come online in a few days
This test is being run at 36VDC and everything stays cool over a course of 10 minutes, I would say it can run stable at this power input. The 5 minute test at 40VDC showed resonant capacitors heating up.
Test is powered by the "2200 Watt server power supply for induction heating"
That sure was a successful test.
    Is the "glowing" color that we see on the video that same as what you see in person?  Do you do anything special with the white balance of your video camera?
I am starting to work on establishing operational upper frequency limits on these devices.  I wonder how high they can go and still work okay.  Today, I certainly exceeded that number, so now I will have to "back up" to see where the real tripping point is.
So far, I hypothesize  that the data I gather from the 1000 watt unit will transfer directly to the 1800 and 2500 watt devices, since their gate circuits appear to be identical.  (Having said that, and seeing that two of three gate circuits are in parallel, I WILL have to verify that some day.)
By the way, I am using a cheap inductance meter for these measurements.  I think it is this one:
https://www.ebay.com/itm/LC100-A-High-Precision-Digital-Inductance-Capacitance-L-C-Meter-Tester-SMT-Clip/253959986062?hash=item3b2131db8e:m:mOpTSkV_q1oIM9pHKxVlPfw
Here's the record of this morning's test:
Objective:
  Determine the lower work coil inductance range for safe, useful operation of the popular 1000 Watt to 2500 Watt ZVS induction heaters.
Date: march 18, 2019
Subject for testing, March 18, 2019:
Testing a 10" U shaped work coil on the 1000 watt unit.
Method:
Make up a "one turn" coil to use as a worst case situation.  This coil is simply 25" of 1/4" OD copper tubing that is bent into a "U" shape, with about 3/4" between the arms.
Summary:
My initial conclusion is that the oscillation frequency observed during this test is somewhat beyond the safe or useful upper limit for this design.
  I hypothesize that the lower limit for work coil inductance is about 1.0 microhenry.
Notes:
First I checked out the system using a "stock" 2" ID 6 Turn coil.  It ran, as it normally does,  at  about 6 amps of idle current.
Then I removed the 6 turn coil and replaced it with this "U" coil:
The measured inductance of this "U" coil is about 0.240 micro henry.
At present, the coil is actually several inches longer than 10.  I call it a "10 inch coil" because, once fully shaped, it would have a work area about 10 inches long for heat treating knife blades.
It has a spacing between the tubes of about 3/4".
For reference, these 1000 watt ZVS heaters come with coils that produce resonant frequencies between about 103 kHz and about 83 kHz.  These coils have measured inductances of about 1.05 to 1.38 micro henry.
Results:
The system  DID oscillate, but at about 154 kHz.
And the gate waveform degraded significantly from the almost square shape it has with the "stock"  6 turn X 1 1/2" to 2" ID coils.  The signal almost looked like a sine wave with a slightly flattened top, both the leading AND the trailing edges.
  The idle current went to 16 amps.  I think this extra 10 amps is caused by the degraded gate signals causing the Mosfets to be running in linear mode for a good share of the time.  Also, the capacitors heated rapidly within a minute or so of "power on".
It seems I have rather good UV filters on my phone and DSLR, as you actually see a red glowing work piece in the video and not a purple glow. It does however not filter it all, it does glow more bright on the video than in reality and I guess you have the same experience.
Objective:
Method:
Summary:
Notes:
Results:
Thanks for doing these experiments with lower inductance work coils and the resulting frequencies and currents. As expected it heats up a lot from increased switching losses due to more time in the linear region, but also it did not explode! I had expected it to burn to ground from your U turn coil :)
post Re: GDT Experiments
March 20, 2019, 11:15:50 PM
Thunderstruck
March 20, 2019, 09:07:04 PM
post Re: Keep or throw away ?
March 20, 2019, 05:18:07 PM
post Re: New small SSTC
Bambinz
March 20, 2019, 03:52:15 PM
March 20, 2019, 01:23:52 PM
March 20, 2019, 01:18:29 PM
March 20, 2019, 01:06:24 PM
post Re: cute-qcw Tesla Coil
March 20, 2019, 01:00:46 PM
March 20, 2019, 12:41:22 PM
Thunderstruck
March 19, 2019, 10:02:41 PM
March 19, 2019, 08:14:33 PM
March 19, 2019, 05:12:03 PM
Experimentonomen
March 19, 2019, 01:32:32 PM
March 19, 2019, 12:20:34 PM
March 19, 2019, 12:15:22 PM
March 19, 2019, 10:46:50 AM
Thunderstruck
March 19, 2019, 09:11:09 AM
March 19, 2019, 08:24:31 AM
March 19, 2019, 01:51:51 AM
Thunderstruck
March 18, 2019, 09:56:42 PM
March 18, 2019, 07:55:52 PM
March 18, 2019, 06:11:07 PM
March 18, 2019, 02:27:35 PM
March 18, 2019, 12:52:35 PM
March 18, 2019, 12:22:58 PM
post New small SSTC
Bambinz
March 18, 2019, 11:46:18 AM
Bambinz
March 18, 2019, 11:29:02 AM
March 18, 2019, 10:35:04 AM
Marty
March 18, 2019, 05:32:43 AM
Experimentonomen
March 17, 2019, 09:13:47 PM
post Re: DRSSTC Driver Logic
March 17, 2019, 04:08:33 PM
post Re: WTB: Large Heatsink with a Baseplate at least 10mm thick
March 17, 2019, 02:46:44 PM
March 17, 2019, 02:21:45 PM
March 17, 2019, 01:54:47 PM
March 17, 2019, 10:15:16 AM
March 17, 2019, 09:33:50 AM
March 17, 2019, 05:32:48 AM
Thunderstruck
March 17, 2019, 02:39:25 AM
post WTB: Large Heatsink with a Baseplate at least 10mm thick
March 16, 2019, 10:06:39 PM
March 16, 2019, 08:35:51 PM
March 16, 2019, 08:04:52 PM
March 16, 2019, 06:44:14 PM
March 16, 2019, 09:57:55 AM
Thunderstruck
March 16, 2019, 09:40:55 AM
March 16, 2019, 08:57:54 AM
Thunderstruck
March 16, 2019, 08:46:24 AM
March 16, 2019, 08:27:24 AM
post Re: UD 2.7C Build
Thunderstruck
March 16, 2019, 07:35:58 AM
post GDT Experiments
Thunderstruck
March 16, 2019, 06:32:36 AM
post cute-qcw Tesla Coil
March 16, 2019, 06:01:44 AM
