Author Topic: SSTC-Interrupter Audio + PWM PCB Rev 1.0  (Read 262 times)
Online Fumeaux
« on: November 04, 2018, 04:14:58 PM »
Hi Guys!
As I already said in another post, I worked on a SSTC-Interrupter PCB. Same rules as before. It's not my schematic. If you want to know more about the schematic visit: http://kaizerpowerelectronics.dk/tesla-coils/musical-sstcdrsstc-interrupter/
Waring: It could contain errors so better check the circuit for yourself
Edit: Guess what, there is an error, the holes for the resistors are not long enough. It should still be functional, just ugly.
PCB:
Documentation:
* SSTC-Interrupter Audio PWM.pdf
« Last Edit: December 20, 2018, 03:33:29 PM by Fumeaux »
Re: SSTC-Interrupter Audio + PWM PCB Rev 1.0
« Reply #1 on: November 05, 2018, 01:07:33 PM »
Thanks for also sharing this little neat interrupter + audio board :)
With SW1 it can only be either normal or audio interrupter? In my SSTC2 schematic I noted that to run CW mode, the ENBL pin of the UCCs should be tied to +12V (a earlier version I had just left it floating, which worked for me, but gave problems for other builders)
Online Fumeaux
« Reply #2 on: November 05, 2018, 06:17:13 PM »
Yes SW1 just toggles between audio and pwm, my switch is a 2x 1/0/1 so i can leave the pin floating. My pll-board has a 12V-pin next to the INT-IN-pin so you can use CW via my pll-board without having an interrupter board. You can bridge them or solder wires to it, with a switch. I did look at the schematic of the ucc's and they have a pullup resistor intergrated. Which means, with proper shielding, it should even work without any further customisations.
post Re: My First DRSSTC
Today at 11:07:22 AM
Today at 08:08:58 AM
Today at 01:24:15 AM
January 18, 2019, 07:32:38 PM
January 18, 2019, 04:25:14 PM
CristianM
January 18, 2019, 03:48:06 PM
January 17, 2019, 02:01:36 AM
January 16, 2019, 04:26:38 AM
January 15, 2019, 09:48:48 PM
post Re: My X-Ray Machine
neukyhm
January 15, 2019, 10:51:46 AM
January 14, 2019, 05:08:38 PM
January 14, 2019, 01:15:53 PM
January 14, 2019, 12:22:07 PM
January 11, 2019, 05:10:39 AM
January 10, 2019, 10:59:25 PM
post Re: 迎词、来
January 10, 2019, 06:56:59 PM
January 10, 2019, 05:33:48 PM
January 10, 2019, 02:11:58 AM
January 09, 2019, 09:14:59 PM
Physikfan
January 08, 2019, 08:44:16 PM
Felix Bieri
January 08, 2019, 05:33:55 PM
[Radio frequency]
January 08, 2019, 08:25:08 AM
January 08, 2019, 08:25:02 AM
January 08, 2019, 02:01:50 AM
post Re: (DR)SSTC II
January 07, 2019, 10:23:38 PM
January 07, 2019, 08:53:32 PM
January 07, 2019, 08:17:44 PM
January 07, 2019, 07:37:53 PM
January 07, 2019, 01:30:36 PM
January 07, 2019, 12:43:26 PM
January 07, 2019, 08:09:49 AM
NEYi
January 07, 2019, 07:43:50 AM
January 07, 2019, 06:48:06 AM
January 07, 2019, 06:39:56 AM
January 06, 2019, 09:23:19 PM
January 06, 2019, 07:11:25 PM
January 06, 2019, 07:02:14 PM
January 06, 2019, 12:43:46 PM
January 06, 2019, 11:55:09 AM
TDAF
January 06, 2019, 09:48:06 AM
TDAF
January 06, 2019, 09:45:17 AM
January 06, 2019, 08:34:46 AM
post 迎词、来
January 06, 2019, 08:20:21 AM
January 06, 2019, 12:34:15 AM
January 05, 2019, 05:27:23 PM
January 05, 2019, 03:46:29 PM
January 05, 2019, 09:51:10 AM
January 04, 2019, 11:02:25 PM
January 03, 2019, 08:38:15 PM
January 03, 2019, 08:15:48 PM
