Author Topic: Search for Parts...  (Read 323 times)
Offline CEDEng
Search for Parts...
« on: October 23, 2018, 10:05:20 PM »
First post, thanks for the help in Advance.
Let me start by saying I have $oogled this topic to death, no luck, so I'm joining forums willy-nilly to find an answer!  I need some parts to SAFELY put together a small project.  The parts are:
Any small-ish din-rail style screw-tight terminal block good for 5kV or more;  OR
Any random manufacturer or part # for the white "plug" end of a Hipot lead from a quadtech/chroma HIPOT tester.
I'm not really a "beginner" but I'm also not sure where else to post this!  These may seem like "easy" questions, but apparently, the gods of the InterWebz are conspiring against me on this one.
Bottom line is - I need to terminate one HV wire in a box.  Best case - I recreate what's on a HiPot tester, and just use that, plug socket and all.  For that, I need the white "plug" part and mating bulkhead connector.
Second best - I feed the wire into the box - and screw it into a terminal, rest of circuit fully assembled.
Minor detail - I have a ton of the Chroma testers, thus the request for mates.
Hope you can help - thanks either way!
Re: Search for Parts...
« Reply #1 on: October 24, 2018, 08:13:53 AM »
Hi and welcome to HVF
I actually thought, like you, that you could just google some 6kV terminal blocks and find a standard DIN rail mounted system, but certainly not :)
I guess its not really used, so the good old large terminal blocks are still used for these special cases: https://www.weidmueller.com/int/products/product-innovations/product-innovations-2018/cabinet/high-voltage-terminal-hv-2700-and-hv-4000
You should maybe look into high voltage BNC connectors? https://www.amphenolrf.com/connectors/mhv.html
Offline the_anomaly
« Reply #2 on: October 24, 2018, 01:16:14 PM »
You can buy the plug end from Chroma directly: http://www.shopchromausa.com/hipot-safety-page-2/?p=catalog&mode=catalog&parent=32&pg=2&pagesize=30
I've not registered to see the price but I would think its reasonable.  A company I worked for used to do this when production wore out the cable.
If you need a plug/socket combo, Amphenol Alden makes some HV ones.  https://www.surplussales.com/Wire-Cable/HVWire-2.html
Offline CEDEng
« Reply #3 on: October 24, 2018, 02:53:42 PM »
Thanks everyone.
As it turns out, I've been down the same roads -
The chroma single-piece price is unbelievable (I won't post it here) considering I just need the plastic "end" part...
The Weidmuellers seemed promising, except they are larger than my entire enclosure - I can keep them in mind for the next thing though.
The Amphenol will solve some of my problems, but what I mainly need to do is either a)  run a lead with "End" from my box and plug it directly into my Quadtech (requires the correct plastic end) OR use my Quadtech lead, cut off the alligator clip, and terminate it neatly in my box (Terminal block).  Either way is fine with me, but for such a simple puzzle it is turning out to be a real time-sucker!
I could use the Amphenol pair - cut off the alligator clip from the test lead, use the amphenol end, and mount the mate to the box...that's not impossible.
I found these:  http://hvstuff.com/high-voltage-connectors-plugs-sockets
But I can't find anything that tells me I can trust them with my cc.  Any one have any experience with them?
Thanks again!
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
[Solid state Tesla coils]
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 07:47:34 PM
Laci
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
[Transformer (ferrite core)]
setkiki
February 22, 2019, 04:28:24 AM
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
Laci
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
VNTC
February 19, 2019, 04:54:44 AM
post Re: Primary-Strike Protection Grounding Scheme - Insanity?
February 18, 2019, 09:25:24 PM
February 18, 2019, 09:11:48 PM
February 18, 2019, 06:38:29 PM
post My first DRSSTC on bricks
Laci
February 18, 2019, 05:17:53 PM
February 18, 2019, 08:44:19 AM
post Primary-Strike Protection Grounding Scheme - Insanity?
nabzim
February 18, 2019, 05:06:18 AM
[Electronic circuits]
February 18, 2019, 12:13:02 AM
post Re: A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
[Light, lasers and optics]
Laci
February 17, 2019, 08:22:04 PM
post A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
FilipŠebík
February 17, 2019, 07:04:54 AM
VNTC
February 17, 2019, 03:16:00 AM
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
