Author Topic: My second DRSSTC  (Read 2521 times)
Offline erdal
Re: My second DRSSTC
« Reply #20 on: November 12, 2018, 06:58:26 PM »
Hi Mads,
I could not record the video because I tried inside at the home. It's make very dangerous sparks :)) i just took some photos. I plans to record test videos outdoors
Offline erdal
« Reply #21 on: July 28, 2019, 01:20:33 PM »
Hi again  :D
Full power @ 700amps 325 volts in open air tests  ;D
I am planing to changing IGBT’s CM200 to CM300, 600v to 1200v with voltage dublicate ;)
« Last Edit: July 28, 2019, 01:39:16 PM by erdal »
« Reply #22 on: July 28, 2019, 03:28:59 PM »
i don't know how i missed the original build but this is awesome! i love the simple ingenuity behind the ikea desk. it's truly an amazing looking coil
Offline erdal
« Reply #23 on: August 03, 2019, 09:58:44 PM »
THNX oneKone :))
Misson Impossible 700 amps OCD, 340 v bus voltage
When johnny comes marching back home
mmc capacitors fail after long tests  :P
My new mmc design. each 0.1 uf, 1200 volts, 8 ampers irms,  12 parallel 5 serial total 60 caps. 0.24 uf 6.000 volt 96 amper irms
« Last Edit: August 07, 2019, 07:35:10 PM by erdal »
« Reply #24 on: August 08, 2019, 08:35:57 AM »
These capacitors are also less sturdy than the CDE 942C series or snubber MKP pulse capacitors, so failure on such a MMC is expected if it does not have a large overhead for voltage and current specification.
Your new MMC layout is problematic, the inner capacitors will not be able to radiate the heat from their losses, so they will heat up faster than the outer ring of caps and will fail before the others due to temperature changing their characteristics.
Offline Bambinz
« Reply #25 on: August 08, 2019, 11:58:47 AM »
I agree, and then if the inner caps fail the other caps fail consequently (avalanche effect).
Offline erdal
« Reply #26 on: August 12, 2019, 08:40:16 PM »
Hello All,
Not work! :-\
I changed the MMC, bus voltage ok, driver ok, but nothing any sparks.
Fuse not blown, no any shortcut at IGBTs
what would be the reason?
Offline erdal
« Reply #27 on: August 14, 2019, 12:53:10 PM »
Hello,
Now working :)) one of IGBT is death. G to E is 155 ohm :(
I changed CM200DY-12NF to CM300DY-12NF. Can i increase 700 amps to 900 amps at OCD?
Thank you
Erdal
Spark to strike rail
« Reply #28 on: August 16, 2019, 10:19:18 PM »
I still recommend that you do a Fmax2, switching loss calculation to make sure that the CM300 can withstand 900A at 100 kHz, it is a much higher frequency than CM300 is usually used at. I think the highest recorded I got on my page is 700A at 72 kHz by loneoceans.com
Good to see that you found the defective IGBT brick, how about the gate resistor/zener diode, were they damaged aswell? I often saw this problem when a IGBT died.
« Reply #29 on: Today at 12:59:20 AM »
I see that you're using the 600V rated CM300, these should be a lot faster than the 1200V ones, so I suspect that 100kHz/900A will be ok, though at the upper limits of what you can do with them.
Lane
Today at 10:45:26 AM
Lane
Today at 06:21:45 AM
post Re: My second DRSSTC
post Re: Twin System Build
fnordest
Today at 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:07:31 PM
August 16, 2019, 09:28:35 PM
August 16, 2019, 09:17:04 PM
August 16, 2019, 09:14:36 PM
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
August 15, 2019, 06:23:40 PM
August 15, 2019, 06:17:55 PM
Lane
August 15, 2019, 01:51:04 PM
August 14, 2019, 07:05:57 PM
Bert911
August 14, 2019, 03:42:34 PM
[Static electricity]
Patric
August 14, 2019, 02:56:49 PM
August 14, 2019, 01:42:21 PM
erdal
Patric
August 14, 2019, 09:22:21 AM
post Re: Drsstc 3
August 14, 2019, 04:39:11 AM
August 13, 2019, 07:10:31 PM
August 13, 2019, 05:17:23 AM
August 12, 2019, 09:54:35 PM
erdal
August 12, 2019, 07:27:23 PM
August 12, 2019, 09:18:15 AM
August 12, 2019, 09:06:34 AM
August 12, 2019, 09:02:38 AM
August 12, 2019, 08:29:20 AM
August 12, 2019, 05:25:24 AM
August 10, 2019, 08:14:35 PM
post Re: 30% power increase
August 08, 2019, 04:18:09 PM
[Vacuum tube Tesla coils]
Bambinz
August 08, 2019, 01:15:11 PM
Bambinz
August 08, 2019, 12:15:26 PM
Bambinz
Bambinz
August 08, 2019, 11:56:51 AM
August 08, 2019, 10:04:39 AM
August 08, 2019, 08:33:01 AM
August 07, 2019, 09:16:57 PM
August 07, 2019, 01:15:46 PM
August 07, 2019, 02:32:25 AM
post 30% power increase
August 06, 2019, 04:35:37 PM
post Re: Drsstc 3
fnordest
August 06, 2019, 10:56:30 AM
post Re: Drsstc 3
August 06, 2019, 05:11:10 AM
