Author Topic: My first DRSSTC  (Read 1988 times)
Offline erdal
Re: My first DRSSTC
« Reply #20 on: September 27, 2018, 02:15:59 PM »
Hi Mads,
Did you try to add such close proximity walls in JavaTC? It has a really big effect on the secondary circuit resonant frequency.
Yes, seconder resonant reduce to 210khz to 185 khz. My primary coil is not fully adjusted at the moment, I am planning to make a new adjustable primary winding with 1/4" copper pipe in my hand.
My new full bridge inverter is quite powerful, 6 amp fuse blows at 115v ac. I got dozen of broken fuse :)) I don't want to install 8 or 10 amp fuses for IGBT's health. Clearly I don't think I'll try with 230v ac in the indoor (at home) environment.
MMC cold, heatsink cold but bus cap (2200 uf/400 v) a little hot. Is this normal?
My new One Tesla midi interrupter working very well
Edit: I would recommend the IXGK60N60C2D1 IGBT. It's same to IXGN60N60c2d1 minibrick but TO-264 case. Only 4.5 usd with taxes. digikey or mouser are not in stock, but my local store have ~20000 in stock :)
Finally,
DRSSTC makes a lot of noise, how are you with your neighbors? :))
Levan Polka 85 v AC
Popcorn 115 v AC
« Last Edit: September 27, 2018, 02:51:57 PM by erdal »
Offline erdal
Re: My first DRSSTC
« Reply #21 on: September 28, 2018, 02:33:06 PM »
I made a new primer. Tuned best point to resonant. I first tried to wrap the PVC pipe. it's not a good idea. Because the coupling was too high, so the sparks from the primer to the secondary. Then I removed the PVC pipe, adjusted the height of the secondary and primery.
Take Five 115 volt AC
Mission Impossible (Fuse Blown)
Re: My first DRSSTC
« Reply #22 on: October 01, 2018, 01:37:18 PM »
Finally,
Good results with all the MIDI playing, makes it worth the effort of building it :)
It sounds like your DC bus capacitors are not suitable for the amount of ripple current you are loading it with, try to do the calculations for your coil as you can see how to do here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/dc-bus-capacitor/
Noise is a serious issue with a DRSSTC and I have had neighbors yelling at me to stop it, especially when we ran the large DRSSTC at 500 BPS 14kW, that was one loud and ear ringing tone :D
Re: My first DRSSTC
Today at 05:36:38 PM
Today at 04:56:10 PM
post Re: Strange GDT signals (need to help)
Today at 11:55:27 AM
Today at 05:51:09 AM
Today at 04:07:17 AM
VNTC
Today at 02:19:24 AM
VNTC
Today at 02:00:48 AM
VNTC
Today at 01:33:56 AM
May 22, 2019, 08:31:55 PM
dexter
May 22, 2019, 08:31:51 PM
VNTC
May 21, 2019, 11:35:57 PM
May 21, 2019, 09:59:54 PM
May 21, 2019, 09:51:27 PM
May 21, 2019, 09:49:03 PM
82026
May 21, 2019, 09:02:10 PM
Vaclav
May 21, 2019, 08:59:57 PM
May 21, 2019, 08:28:43 PM
May 21, 2019, 08:22:28 PM
Vaclav
May 21, 2019, 06:21:37 PM
May 21, 2019, 06:12:55 PM
May 21, 2019, 04:06:38 PM
Vaclav
May 21, 2019, 03:56:56 PM
Vaclav
May 21, 2019, 03:46:56 PM
May 21, 2019, 02:32:59 PM
May 21, 2019, 06:12:18 AM
May 20, 2019, 11:30:34 PM
Vaclav
May 20, 2019, 06:38:54 PM
May 20, 2019, 06:33:49 PM
82026
May 20, 2019, 02:27:59 PM
May 20, 2019, 02:57:46 AM
May 20, 2019, 01:06:27 AM
82026
May 19, 2019, 09:14:59 PM
May 19, 2019, 06:40:41 PM
May 19, 2019, 04:04:12 PM
May 19, 2019, 11:24:46 AM
May 19, 2019, 03:22:54 AM
May 19, 2019, 03:18:52 AM
May 18, 2019, 10:48:59 PM
Golddustpeak
May 18, 2019, 04:19:11 PM
May 17, 2019, 10:57:17 PM
jpb133
May 17, 2019, 09:41:56 PM
May 17, 2019, 12:41:17 PM
82026
May 16, 2019, 04:15:58 PM
May 16, 2019, 02:19:39 PM
Golddustpeak
May 16, 2019, 01:50:44 PM
May 16, 2019, 12:17:01 PM
May 16, 2019, 08:45:15 AM
May 15, 2019, 11:49:59 PM
May 15, 2019, 10:51:33 PM
May 15, 2019, 09:35:41 PM
