Author Topic: My first DRSSTC  (Read 1450 times)
Offline erdal
Re: My first DRSSTC
« Reply #20 on: September 27, 2018, 02:15:59 PM »
Hi Mads,
Did you try to add such close proximity walls in JavaTC? It has a really big effect on the secondary circuit resonant frequency.
Yes, seconder resonant reduce to 210khz to 185 khz. My primary coil is not fully adjusted at the moment, I am planning to make a new adjustable primary winding with 1/4" copper pipe in my hand.
My new full bridge inverter is quite powerful, 6 amp fuse blows at 115v ac. I got dozen of broken fuse :)) I don't want to install 8 or 10 amp fuses for IGBT's health. Clearly I don't think I'll try with 230v ac in the indoor (at home) environment.
MMC cold, heatsink cold but bus cap (2200 uf/400 v) a little hot. Is this normal?
My new One Tesla midi interrupter working very well
Edit: I would recommend the IXGK60N60C2D1 IGBT. It's same to IXGN60N60c2d1 minibrick but TO-264 case. Only 4.5 usd with taxes. digikey or mouser are not in stock, but my local store have ~20000 in stock :)
Finally,
DRSSTC makes a lot of noise, how are you with your neighbors? :))
Levan Polka 85 v AC
Popcorn 115 v AC
« Last Edit: September 27, 2018, 02:51:57 PM by erdal »
Offline erdal
Re: My first DRSSTC
« Reply #21 on: September 28, 2018, 02:33:06 PM »
I made a new primer. Tuned best point to resonant. I first tried to wrap the PVC pipe. it's not a good idea. Because the coupling was too high, so the sparks from the primer to the secondary. Then I removed the PVC pipe, adjusted the height of the secondary and primery.
Take Five 115 volt AC
Mission Impossible (Fuse Blown)
Re: My first DRSSTC
« Reply #22 on: October 01, 2018, 01:37:18 PM »
Finally,
Good results with all the MIDI playing, makes it worth the effort of building it :)
It sounds like your DC bus capacitors are not suitable for the amount of ripple current you are loading it with, try to do the calculations for your coil as you can see how to do here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/dc-bus-capacitor/
Noise is a serious issue with a DRSSTC and I have had neighbors yelling at me to stop it, especially when we ran the large DRSSTC at 500 BPS 14kW, that was one loud and ear ringing tone :D
Re: My first DRSSTC
Today at 08:48:51 AM
VNTC
Today at 04:54:44 AM
post Re: Primary-Strike Protection Grounding Scheme - Insanity?
February 18, 2019, 09:25:24 PM
February 18, 2019, 09:11:48 PM
February 18, 2019, 06:38:29 PM
post My first DRSSTC on bricks
Laci
February 18, 2019, 05:17:53 PM
February 18, 2019, 08:44:19 AM
post Primary-Strike Protection Grounding Scheme - Insanity?
nabzim
February 18, 2019, 05:06:18 AM
[Electronic circuits]
February 18, 2019, 12:13:02 AM
post Re: A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
[Light, lasers and optics]
Laci
February 17, 2019, 08:22:04 PM
post A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
FilipŠebík
February 17, 2019, 07:04:54 AM
VNTC
February 17, 2019, 03:16:00 AM
[Solid state Tesla coils]
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
February 13, 2019, 03:12:37 PM
February 13, 2019, 02:47:49 PM
TonyHV
February 13, 2019, 01:57:55 PM
February 13, 2019, 01:53:36 PM
TonyHV
February 13, 2019, 01:45:53 PM
February 13, 2019, 12:58:48 PM
TonyHV
February 13, 2019, 12:35:10 PM
post Re: Homemade flyback on 60N60DLF full bridge
[Transformer (ferrite core)]
Platinum
February 12, 2019, 09:17:29 PM
post Video gear & workflow: Canon 5D mk3, Rødelink, FPS1000HD and more
[DSLR]
February 12, 2019, 08:51:43 AM
post Re: STB16PF06L
pentode
February 12, 2019, 08:16:33 AM
February 11, 2019, 11:06:05 PM
February 11, 2019, 10:58:06 PM
post Re: STB16PF06L
February 11, 2019, 10:18:39 PM
Laci
February 11, 2019, 04:28:24 PM
post STB16PF06L
pentode
February 11, 2019, 04:21:54 PM
Thunderstruck
February 11, 2019, 11:55:44 AM
February 11, 2019, 08:13:07 AM
post Homemade flyback on 60N60DLF full bridge
Platinum
February 10, 2019, 08:36:12 PM
post Resistor tolerance?
February 10, 2019, 05:46:39 PM
post Re: Help! IBGT 60N60 has been destroyed a lot by my coil
sjsimmo
February 09, 2019, 09:19:49 AM
post Help! IBGT 60N60 has been destroyed a lot by my coil
VNTC
February 09, 2019, 05:32:59 AM
post Re: DRSSTC design guide - progress report
February 08, 2019, 05:10:29 PM
