Author Topic: IGBT failure in DRSSTC  (Read 674 times)
Offline Felix Bieri
« on: September 20, 2018, 02:42:09 PM »
 [ Invalid Attachment ]  [ Invalid Attachment ] Greetings
I have a problem regarding my DRSSTC. My IGBT's die every time i power up my gate driver. As i have already burnet up 4 of my IGBT modules and the prize for this project now slightly climbs to a costs in which i can't really afford it with my students budget, I'm finally here to ask for help in this more then competent forum (thanks for all the answers i found in threads for my the project so far). I have currently dismantled my DRSSTC for redesign and upgrade purpose and some parts are still on the way from china so i can rebuild it.
The stats of the coil right now is:
Primary coil: 14.76uH
Primary cap: 200nF 6kV
Secondary coil: 116.84mH
Secondary cap: 31.62pF
Resonant Freq.: 65.49kHz
IGBT (SKM200GB128D): 1200V 300A continuous (1200A peak)
2 440V TVS over every IGBT
2 33V Zener over ervery IGBT gate
1 Snubber cap: 5uF 800V
Alu-Supercaps : 9mF 800V
Driver: UD2.7C from loneoceans
Supply Voltage: 565V (I can power it up with 325V aswell and i have tested everything with 24V before i went up to 565V.... maybe I should have waited at 325 first......)
My GDT consist of 24:24 winding around a ferrit.
(See attachments for pictures)
The improvements would be:
1x 20uF Snubber over each IGBT module
Redesign of the bridge for maintainability purpose
Primary cap: 400nF 12kV
Also, is there a way to calculate my primary peak current? For many calculations the current is needed and some calculations i have found don't make sense to me. Do i just assume a current and implement my OCD for a bit less than my IGBT can switch (1200A peak)? This doesn't seem appropriate and i would like to have propper numbers before i burn some more IGBT's  :o.
I'm very grateful for any suggestions regarding my Problem.
Greetings
Metric system ftw :)
Offline Teravolt
Re: IGBT failure in DRSSTC
« Reply #1 on: September 20, 2018, 09:10:10 PM »
what is your gate drive waveform look like?
how much drive voltage is at the gate?
is your gate drive waveform messy or wierd or clean?
do you have enough dead time?
what does the wave form at the tesla look like?
  I think you may have shoot through or the gates are being damage or your feedback is bad in some way. before you power every thing up check all of your semiconductors including your bridge recifire and drive electonics. after a failure things can be weakend or damaged. make shure that the bridge changes state at the same time that the tesla is oscilating so your zero cross is correct and there is no phasing problems. if that happened your igbt diode may be comutating or you have hard switching going on.
« Reply #2 on: September 20, 2018, 09:30:33 PM »
Hi Felix and welcome to HVF :)
I think you have a sound design here and there is no obvious faults jumping right at me, so I would start looking at the driver/GDT and see how they are driving the IGBTs. SKM200 does not just die like that, but if you start out on full DC bus voltage, you will never know if something is wrong before it just goes bang.
Do they die silently or with a bang?
You need to test with a lower voltage on the DC bus and observe the current use, if it rises dramatically above the forward voltage, you most likely have a short circuit of the IGBTs directly across the DC bus. Either due to driving them at wrong phasing, bridge construction fault or some failed part.
Remember to change everything after the GDT when you have had a IGBT failure! Gate resistors, TVS and diodes might look fine, but could be shorted or damaged! Solder it apart and check each component on its own.
Here is a good resource for trouble shooting the GDT waveform: http://www.richieburnett.co.uk/temp/gdt/gdt2.html
Offline Felix Bieri
« Reply #3 on: September 20, 2018, 09:45:44 PM »
Thanks a lot for the fast reply. And I'm glad I haven't really designed something completely wrong. If I remember correctly I had steep switching edges and no ringing. But I may have had overshots at my GDT... I can't recall caus my memory stick with the pictures on it is lost in space  :'( and as of now i can't test it again because my Driver broke too from a broken Power Supply.... I really need my stuff to get fixed....  ::) :o
To Mads question. Yes they die with a big bang :)
Anyway thanks a lot. Now i have some clues of what to look at when I'm off testing it again once it's rebuilded.
I'll be updating this thread then as soon as I have new data or questions. If anyone has further suggestions I'd gladly hear them.
Thanks a lot again!
« Last Edit: September 20, 2018, 11:32:12 PM by Felix Bieri »
« Reply #4 on: September 21, 2018, 04:52:34 PM »
As Mads said, there isn't anything obviously wrong, so more info would help. Photos/diagrams, scope screenshots of gate drive etc.
Remember that you can hook up a coil to a bench supply (or a few small supplies in series) for testing at say ~50-100V - even if they would current limit if run continuously you'll still be able to capture the current/voltage waveforms from the bridge for a single pulse. If that is successful then I'd try and ramp it up slowly from there - if you don't have a variac even stopping at rectified mains (rather than doubled mains) would be better than going all the way in one jump.
Offline Felix Bieri
« Reply #5 on: October 02, 2018, 03:32:26 PM »
My snubbers (DHA1200K20#) have finally arrived: http://www.dawn-cap.cn/upload/201609/DAWNCAP-DHA%202015.pdf
I have yet to receive all my other parts tho. So here a fiew questions first for further planning.
Im gonna replace my primary capacitors with DTR6000K0.40-*-# also from dawncap: http://www.dawn-cap.cn/upload/201806/DAWNCAP-DTR%202015.pdf
As stated in the datasheet the Ipeak these capacitors can bear is 1400A, which is confirmed when i calculate the Ipeak with: Ipeak = C * dV/dT. As stated on Mads site: http://kaizerpowerelectronics.dk/theory/good-mmc-capacitors/. So i am not allowed, for the sake of my dear capacitors, to go with my OCD over this value of 1400A? Is this correct? Or is the OCD limited with the peak current value of the IGBT aka. 1200A? I'm kind of confused at what level I should set my OCD so i can prevent too strong Currents. :o
Edit: My confusion is probably caused because I've seen some people talk about 2000A peak currents in the primary with CM600DU-24FA IGBT. In the datasheet the Ipeak is set to 1200A tho..... how can they have so high peak currents without breaking the IGBT?
« Last Edit: October 02, 2018, 08:45:07 PM by Felix Bieri »
« Reply #6 on: October 03, 2018, 10:44:41 AM »
I am looking forward to hear about your results and experiences with the Dawncaps, I have also looked at them before and on paper they do look good to the price, but I never tried them.
Maximum peak current all comes down to dissipated heat, so with more cooling, larger thermal mass and such we can overload the components but at the cost of their expected life time. To calculate the maximum possible switching speeds and currents for a IGBT, check out my guide on that. It is simply a matter of soft switching being less stressful on the IGBTs and that we aim for a certain die temperature rise per pulse: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
So if you push higher peak currents through something, it just means higher temperature and if you keep adding that up, it usually ends with fire ;)
Offline Felix Bieri
« Reply #7 on: October 16, 2018, 11:54:48 AM »
@Mads: Im quite sure i found an error on your page. Chapter "Thermal impedance": You compare the Thermal impedance of 300BPS with a dutycycle of around 0.06 with the thermal impedance of the 0.5 Dutycylce given in the datasheet. You get a factor 2.66 which is wrong i think. 0.17K/W / 0.015K/W (@ D=0.06 from shematic) is around factor 11.33 lower not 2.66. I think you compared Thermal impedance of the 0.5 dutycycle with the dutycycle of 300BPS directly.
Also i have finished repairing my Driver, GDT and Interrupter (I currently use an interrupter module to convert MIDI from a Keayboard with maxFreq = 554.37Hz, a Cis5)
I tuned the Interrupter to always have a Dutycycle of 10% at the maxFreq. So for this frequency it would be around 200us. The feedback of 65kHz was simulated with an oszillator. Images of the tests and results are attached. Are these values plausible? (Its an ancient oszilloscope... pls have mercy about the quality  ;D)
I just need my primary caps now so i can rebuild the rest of my coil and test it further.
Greetings
« Reply #8 on: October 18, 2018, 08:02:24 PM »
Thanks for catching that error Felix! I corrected the page and added a little more text to make it less confusing.
Your oscilloscope shots looks fine and corresponds to your design criteria, 10% duty cycle is a good maximum for MIDI, just watch the temperature if you have many long notes
Offline Felix Bieri
« Reply #9 on: January 08, 2019, 05:33:55 PM »
Hello again
I've been busy over the holidays and still am because of exams :S. But still I managed to finish constructing my DRSSTC for now. I managed to test some parts as well. As of now I've verified that the DC Voltage works perfectly fine (for testing purpose I drive with a onephase variac with 50VAC). My driver works together with my interrupter just fine. Also my switching of the resistors works as intended -> I switch a resistor in series for loading the supercaps at the beginning to limit current, after 40sec i shortcircuit the resistor. Because I want to drive the coil at 400V in the end and no threephase variac available this is my solution.
The issue i face now is my IGBT's are now not really switching and my driver doesn't really "start" to output signals. I probably did not fine tune my driver correctly for the now added inductance of the 15:15 transformer for the gate driver. Maybe I have to delay more tests forther caus of exams but never the less here some pictures of the coil as of now.
Greetings ;D
post Re: My First DRSSTC
Today at 08:08:58 AM
Today at 01:24:15 AM
January 18, 2019, 07:32:38 PM
January 18, 2019, 04:25:14 PM
CristianM
January 18, 2019, 03:48:06 PM
January 17, 2019, 02:01:36 AM
January 16, 2019, 04:26:38 AM
January 15, 2019, 09:48:48 PM
post Re: My X-Ray Machine
neukyhm
January 15, 2019, 10:51:46 AM
January 14, 2019, 05:08:38 PM
January 14, 2019, 01:15:53 PM
January 14, 2019, 12:22:07 PM
January 11, 2019, 05:10:39 AM
January 10, 2019, 10:59:25 PM
post Re: 迎词、来
January 10, 2019, 06:56:59 PM
January 10, 2019, 05:33:48 PM
January 10, 2019, 02:11:58 AM
January 09, 2019, 09:14:59 PM
Physikfan
January 08, 2019, 08:44:16 PM
Felix Bieri
[Radio frequency]
January 08, 2019, 08:25:08 AM
January 08, 2019, 08:25:02 AM
January 08, 2019, 02:01:50 AM
post Re: (DR)SSTC II
January 07, 2019, 10:23:38 PM
January 07, 2019, 08:53:32 PM
January 07, 2019, 08:17:44 PM
January 07, 2019, 07:37:53 PM
January 07, 2019, 01:30:36 PM
January 07, 2019, 12:43:26 PM
January 07, 2019, 08:09:49 AM
NEYi
January 07, 2019, 07:43:50 AM
January 07, 2019, 06:48:06 AM
January 07, 2019, 06:39:56 AM
January 06, 2019, 09:23:19 PM
January 06, 2019, 07:11:25 PM
January 06, 2019, 07:02:14 PM
January 06, 2019, 12:43:46 PM
January 06, 2019, 11:55:09 AM
TDAF
January 06, 2019, 09:48:06 AM
TDAF
January 06, 2019, 09:45:17 AM
January 06, 2019, 08:34:46 AM
post 迎词、来
January 06, 2019, 08:20:21 AM
January 06, 2019, 12:34:15 AM
January 05, 2019, 05:27:23 PM
January 05, 2019, 03:46:29 PM
January 05, 2019, 09:51:10 AM
January 04, 2019, 11:02:25 PM
January 03, 2019, 08:38:15 PM
January 03, 2019, 08:15:48 PM
post Re: Component questions
January 03, 2019, 02:05:31 PM
