Author Topic: Rotoray spark gap motor power  (Read 1604 times)
Offline Patric
« on: August 26, 2018, 08:18:56 AM »
here's a newbie question: all of these RSG synchronous motors and also those converted induction motors, they seem to be immensely oversized for the job they actually need to do. I mean all they do is turn a (considerably heavy) disk. Ok, accelerating it to ops speeds does take some torque, but once it's spinning, there should be hardly any torque needed right? So why are we seeing > 1kW monsters wheeling around here?  ??? Is it in fact the necessary starting torque to sync up with mains frequency? Scratching my head on that one.
Cheers, Patric
Offline the_anomaly
Re: Rotoray spark gap motor power
« Reply #1 on: August 26, 2018, 03:21:35 PM »
I built a rotary spark gap years ago with a small DC motor.  I liked being able to control the frequency with a variac.  I think it has to do with availability; 1-2hp motors are very common and cheap to buy used.
« Reply #2 on: August 26, 2018, 10:39:24 PM »
With a rotating disc with a few studs there is not much load to drive, unless there is some spark gap forces I am not aware of that influences the rotation force.
But as the disc or arms get bigger, you introduce a great deal of air resistance and bigger motors are needed. F.ex. check out the size of the RSG from Bill Wysocks 13M system: https://teslauniverse.com/tesla-news/galleries/bill-wysocks-model-13m
« Reply #3 on: August 29, 2018, 07:23:37 PM »
I used a $15 angle grinder for an asynchronous rotary spark gap and controlled its speed with a triac (like a lamp dimmer but higher current).  These spin at very high RPMs and don't have a lot of torque, because angle grinders cut with speed not force.  I was using a phenolic disc with screw heads which I think is probably around the same moment of inertia than a stone cutting disc.  Many synchronous motors are designed for heavier duty loads, with maybe the exception of timing motors, as brushed motors or shaded pole motors tend to be used for lighter loads.
Cheers, Patric
« Reply #4 on: June 15, 2019, 06:35:48 AM »
My SRSG uses a modified 1/2 HP 3600 RPM induction motor. The rotor is a 10" diameter 1/2" thick piece of G10. It has 4 flying tungsten electrodes. It comes up to speed in a few seconds. At speed, it moves a LOT of air. It is just about the right power. If you use an under-powered motor, it will not stay synchronous.
« Last Edit: June 16, 2019, 05:21:18 PM by MRMILSTAR »
post Re: Budget USB cameras
missoum0514
Today at 06:56:08 PM
post Re: Dual MOT tesla coil
Today at 05:23:15 PM
nielsquake
Today at 05:02:26 PM
Today at 04:31:04 PM
Today at 10:05:59 AM
Today at 08:21:26 AM
nielsquake
August 02, 2020, 11:45:38 PM
August 02, 2020, 08:10:47 PM
August 02, 2020, 07:27:33 PM
August 02, 2020, 07:14:17 PM
nielsquake
August 02, 2020, 06:58:34 PM
August 02, 2020, 06:49:59 PM
August 02, 2020, 05:10:12 PM
August 02, 2020, 04:55:14 PM
UB_Serpent
August 02, 2020, 04:20:13 PM
UB_Serpent
August 02, 2020, 04:05:12 PM
post Dual MOT tesla coil
August 02, 2020, 01:07:54 PM
August 02, 2020, 07:13:54 AM
August 02, 2020, 02:26:11 AM
missoum0514
August 01, 2020, 11:57:24 PM
August 01, 2020, 10:24:21 PM
August 01, 2020, 03:59:43 PM
UB_Serpent
August 01, 2020, 06:22:53 AM
nielsquake
July 31, 2020, 07:32:09 PM
nielsquake
July 31, 2020, 06:15:27 PM
nielsquake
July 31, 2020, 05:38:49 PM
July 31, 2020, 04:35:43 PM
July 31, 2020, 02:33:48 PM
post Re: IGBT Selection
July 31, 2020, 01:47:51 PM
July 31, 2020, 10:51:47 AM
July 31, 2020, 06:37:20 AM
UB_Serpent
July 31, 2020, 04:11:14 AM
nielsquake
July 31, 2020, 02:33:30 AM
Halfcorp
July 31, 2020, 01:29:05 AM
nielsquake
July 31, 2020, 12:38:28 AM
July 31, 2020, 12:13:43 AM
July 30, 2020, 09:51:25 PM
nielsquake
July 30, 2020, 09:50:16 PM
post How much is the voltage used in Corona Discharge tubes for ozone Generation?
UB_Serpent
July 30, 2020, 02:05:39 PM
July 30, 2020, 03:14:53 AM
July 29, 2020, 10:00:44 PM
July 29, 2020, 06:09:14 PM
July 29, 2020, 12:52:24 PM
July 29, 2020, 08:32:00 AM
July 29, 2020, 05:23:35 AM
July 29, 2020, 04:34:02 AM
post IGBT Selection
Halfcorp
July 29, 2020, 01:56:26 AM
post Re: my 4" coil turned to a 6" at 68"+ arcs
Bradselph
July 28, 2020, 10:33:09 PM
Halfcorp
July 28, 2020, 01:14:38 PM
July 28, 2020, 01:11:56 PM
