Author Topic: Difference between closed surface toroid and ringed toroid?  (Read 1520 times)
Offline Patric
« on: August 25, 2018, 12:08:07 PM »
Dear all,
Most tesla coil designs feature a closed surface toroid top load whereas only the very large ones use toroids build from tubing rings. Can someone explain how a ringed top load compares to a closed surface one in terms of capacitance and overall performance? On a ringed torus what are the minimum gaps between the rings?
Thanks, Patric
Re: Difference between closed surface toroid and ringed toroid?
« Reply #1 on: August 25, 2018, 03:37:33 PM »
Hi Patric and welcome to HVF
I made two calculations in JavaTC, one for a solid toroid and one for a 7 ringed skeleton toroid and there is less than 10% difference in capacitance, you can see them here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/topload/
The skeleton toroid is a trade-off, it can not reach the same charge voltages that a super smooth solid toroid would, but a skeleton toroid only costs a fraction to produce.
Performance wise in a Tesla coil where we want to create lightning, there is not much difference. We need to shape a decent field to just keep the arcs away from the secondary and primary coils and we are happy :)
A solid toroid is however highly needed when you want to suppress outbreak, which electrons find very hard to do from the very even surface of a solid toroid, this could be in large HVDC installations for power transmission or those famous marx generator installations found overgrown in Russia.
Offline Patric
« Reply #2 on: August 26, 2018, 08:21:27 AM »
Thx Mads, that's very interesting and opens up some more unusual design ideas that I have for skeleton toroid (love that word). I will share some CAD renderings once I am there.
Cheers Patric
« Reply #3 on: August 26, 2018, 10:32:19 PM »
There are some good and ingenious ways of doing ringed/tube/skeleton toroids. I did the boring/normal 7 rings horizontal, but check these out.
From Zrg: http://4hv.org/print.php?plugin:forum.165062
From a instruable with all calculations needed: https://www.instructables.com/id/Tesla-Coil-Wound-Aluminum-Toroid/
« Reply #4 on: August 27, 2018, 12:14:32 PM »
I once used a skeleton toroid with 8mm tubes. It had the tendency to break out from the bottom even though I had used a breakout rod. That lead to arcs ending on the primary. The larger effort to bend fatter tubes is well spent.
July 04, 2020, 10:35:50 PM
July 04, 2020, 08:56:15 PM
July 04, 2020, 04:37:32 PM
July 04, 2020, 04:14:44 PM
July 04, 2020, 01:52:14 PM
July 04, 2020, 12:37:48 PM
July 04, 2020, 12:17:47 AM
July 03, 2020, 07:12:18 AM
July 03, 2020, 06:36:16 AM
July 03, 2020, 04:20:42 AM
July 03, 2020, 03:01:56 AM
July 02, 2020, 11:17:48 PM
July 02, 2020, 11:09:25 PM
July 02, 2020, 10:57:02 PM
July 02, 2020, 10:47:18 PM
July 02, 2020, 09:03:20 PM
DJthefirst
July 02, 2020, 08:01:03 PM
July 02, 2020, 07:04:55 PM
July 02, 2020, 07:02:30 PM
July 02, 2020, 06:51:20 PM
July 02, 2020, 05:34:23 PM
DJthefirst
July 02, 2020, 05:09:09 PM
July 02, 2020, 12:51:29 PM
July 02, 2020, 12:20:18 PM
July 02, 2020, 05:30:41 AM
DJthefirst
July 02, 2020, 04:16:58 AM
July 02, 2020, 01:02:02 AM
July 01, 2020, 06:54:30 AM
July 01, 2020, 06:25:30 AM
July 01, 2020, 02:47:13 AM
July 01, 2020, 02:43:34 AM
aes92000
July 01, 2020, 02:33:07 AM
July 01, 2020, 12:03:08 AM
aes92000
June 30, 2020, 10:34:36 PM
post Re: E-Bay Marx generator
June 30, 2020, 09:14:06 PM
June 30, 2020, 09:05:32 PM
June 30, 2020, 09:01:55 PM
June 30, 2020, 08:22:33 PM
June 30, 2020, 07:54:40 PM
June 30, 2020, 05:13:57 PM
aes92000
June 30, 2020, 04:08:34 PM
June 30, 2020, 02:54:22 PM
June 30, 2020, 01:04:30 PM
Justin
June 30, 2020, 10:07:49 AM
June 29, 2020, 12:43:36 AM
June 28, 2020, 12:57:53 PM
June 28, 2020, 12:24:17 PM
June 28, 2020, 02:19:44 AM
post E-Bay Marx generator
June 27, 2020, 09:36:57 PM
June 27, 2020, 09:28:56 PM
