Author Topic: 750W solar offgrid 24V/150Ah battery setup with Victron charger  (Read 2937 times)
Hi All
I hope someone can guide me in the jungle of PWM/MPPT Western/Chinese solar battery chargers.
First a list of what I got
3x 250 Watt 48V solar panels
2x 750 Watt 24VDC/230VAC inverters
?x 24V Gel UPS batteries
So what I need is a 1000 Watt 48V solar system to 24 V battery charger. Having looked at ebay/amazon etc. its a jungle of missing specs, wild claims and no real good comparisons. I hope someone else can share their experience on this.
This is something in the price range that I find suitable and the user feedback there shows it can be used with a wide range of PV input voltage and battery bank voltage can be selected: https://www.amazon.com/ZHCSolar-Controller-Regulators-Temperature-Compensation/dp/B077TSVRDP/
Attached picture is from the solar panel.
« Last Edit: September 16, 2019, 08:54:55 PM by Mads Barnkob »
Offline the_anomaly
Re: Offgrid 48V solar to 24V battery setup
« Reply #1 on: August 15, 2018, 05:57:38 PM »
Are you going to include sun tracking?  I think its worth it and I've seen people build simple tracking units using CdS cells to sense radiation angle.  Here is a neat source of info: https://www.eia.gov/todayinenergy/detail.php?id=18871
I don't have any product experience unfortunately.  Have you looked up any brand names like Siemens / GE / Bosch?  I would think they build a quality product.  String inverters seem to be popular in the industry.  Since each panels output can vary under the same conditions, an inverter tied to each panel can maximize that panels mppt.  If you build an array of panels and feed that into a single inverter, the weakest panel limits the output of the array.  That's all I remember from my research a year ago.
« Reply #2 on: August 16, 2018, 12:18:54 PM »
I do not have space for making a tracking mount for the panels, unfortunately, the wife-acceptance-factor is simply too low on a project like that :)
Brand names are costly, if I was going to build a long term investment system that was also grid-tied, I would go for quality products.
Here I already got panels and inverters for free, so i also wanted to find a matching solution for the charger.
Thanks for the hint on string inverters vs. micro inverters, though the micro inverters is a larger investment compared to a string inverter. From what I read up on just now microinverters is a preable choice if you have serious shading issues, installations that are more spread out so all panels are not next ot eachother. Considering I only got 3, that is not my main concern.
Offline rikkitikkitavi
« Reply #3 on: August 17, 2018, 03:38:01 PM »
Why a 48V 1000W to 24V charger?
Do you plan to parallell the three panels?
250W is their peak capacity, it is not necessary to design an inverter / charger for mor than 80% of the peak power , you loose maybe 5% of total solar energy (in kWh) but you will have a smaller inverter running closer to its maximum , ie higher efficiency and hence losses. Its a bit trade of between current related losses and simple switching losses which are more related to the size of the inverter (ie close to idle losses)
« Reply #4 on: August 21, 2018, 08:28:37 AM »
The PV panels that I have comes from a 6 kW system that was dismantled, so I only have a small part of the original system. They were all tied up in 2 parallel strings running at some 400-500 Volt maybe?
So to be able to use them, I will have to parallel them with blocking diodes as there is really no 150V input chargers, without getting unnecessarily expensive.
The inverters I have is also 24VDC to 230VAC, so the choice of a 48V to 24V charger is based on my parts.
From what I understand from this Victron calculator ( https://www.victronenergy.com/upload/software/VE-MPPT-Calc-2_7.xlsx ) there is some temperature dependent parameters regarding current.
Offline the_anomaly
« Reply #5 on: August 21, 2018, 02:11:42 PM »
I'm concerned about this.  If the blocking diode is reverse biased protecting the solar panel from incoming current, won't that completely eliminate it from the array?  The weakest panels will never contribute.  How about using a standard SMPS to drop 150V (from series config) to 24, then use the battery charger?  Sure you lose a bit of power but should be much less than losing an entire panel.
« Reply #6 on: August 21, 2018, 03:31:35 PM »
I can not really find anything with a quick search that actually goes against paralleling panels. The panels already has 8 diodes built-in, maybe that is already enough to take care of these issues.
I like your idea about the DC-DC converter, will see what I have in stock :)
« Reply #7 on: August 22, 2018, 01:15:39 PM »
The maximum voltage of a panel will always be higher than the ideal operating voltage (which should be set at the MPP, "maximum power point" where the V*I product is greatest), so assuming identical panels the diodes should always be forward biased, with each panel running at the same voltage but slightly different currents.
Mads: have you looked into maximum power point trackers? just running a series or parallel string of panels into the input of a standard DC-DC converter will not give good results - you want to be manipulating the duty cycle to get the maximum power from the panels.
You can probably approximate this with a simple controller by looking the V-I curve of the panel and regulating the _input_ voltage of the DC-DC converter to this value (output is essentially constant, as it's running into a battery bank, though you'd want to add over-charging protection), which will run the panel near the ideal point.
A better controller would perturb it's operating point while measuring output (or input) power to actually hit the ideal panel voltage for the exact conditions it's running in (will vary with temperature, sunlight etc).
I did a bit of this stuff at uni, designed/built a system of three 200W+ MPPTs (maximum power point trackers) and a 600W battery charger. The charger was a bit iffy (kept blowing up output diodes) but the MPPTs worked well. Mine just used a hall effect current sensor and a voltage divider, both sampled by a microcontroller, which perturbed the PWM duty cycle in one direction until the I*V product started dropping, then went the other way. This simple algorithm meant it would oscillate a little (trivial amount) around the maximum power point and would track it if conditions changed.
Offline the_anomaly
« Reply #8 on: August 25, 2018, 06:15:45 PM »
I can't find anything bad about parallel either which surprises me.  I tried to set up a test but I forgot that a single cell only produces ~0.5 volts with no load and I just don't have time to solder a bunch together and try it.
If one of the panels becomes shaded or has another defect and the system is asked to supply (for example) 5amps, that one panel may produce 5amps but at a lower voltage than the other panels because its maximum power point has been shifted. That is what made me think a protection diode could become reverse biased.  I could still be wrong about this but wiring the panels in series would surely allow them all to contribute power even when they are not all operating at their maximum power point.
Offline station240
« Reply #9 on: October 16, 2018, 02:57:07 PM »
Victron have not unreasonable pricing
https://www.victronenergy.com/solar-charge-controllers
I rewrote the instructions at the top of the page to be clearer.
In our MPPT model names,  the first number is the maximum PV open circuit voltage. The second number is the maximum charge current.
For example MPPT 75/50, maximum PV open circuit voltage 75V.  maximum charge current 50A.
Re: Offgrid 48V solar to 24V battery setup, finally some news
« Reply #10 on: May 05, 2019, 08:18:22 PM »
So I actually ended up buying a brand new Victron Energy 100V | 30A battery charger as it suited my needed for parallel operation up to 100V input and 30A, in a 24V system it can do 1500 W, so with my 750 W in panels I can always double up on that with this charger. It also has blue-tooth and can be controlled, setup and surpervised over a app, I am looking forward to see how well that works.
I also got hold of two used sealed batteries, each 12V 150Ah and 55kg!. Connected in series for 24V and that should actually match the rule of thumb for being able to be recharged in 6 hours on 750W worth of panels. I about that somewhere and maybe I remember wrong, but it is not so important, the price of the batteries was too good to consider any alternatives :)
Also a picture of my 3 panels. (4th got smashed during transport from storage :( )
« Reply #11 on: May 08, 2019, 09:14:16 PM »
In part 1 I give a walk-through of my test setup, charging and the Victron app to control the charger over blue-tooth, it all consists of:
3x 250W solar panels
1x Victron SmartSolar 100|30 MPPT battery charger
2x Norbatt 12V 150Ah batteries
1x 750W 24VDC to 230VAC inverter
« Reply #12 on: May 19, 2019, 11:24:46 AM »
First test with all 3 panels on a sunny day
« Reply #13 on: May 20, 2019, 11:30:34 PM »
Are those monocrystalline or polycrystalline solar cells?
One thing I was wondering about such a setup is the feasibility of setting up a wireless repeater that would charge a battery.  What kind of average power over 24 hrs over the year do you think you could get?  Problem is in the winter at 55.6 N the amount and number of hours of daylight are relatively low.  But perhaps an average of 40 watts is feasible?
« Reply #14 on: May 21, 2019, 09:59:54 PM »
I think they are polycrystalline, as it was a standard house hold installation they came from, some 12 years back or so since they were bought.
Average power is indeed a problem over the year, it will be hard to tell before having all 3 panels on the roof, but I have been running with a single panel on a wall for a while now, it can on good days do 600Wh, but that is not enough to make up for a 15W/hour load running 24/7, the bad days simply drains the battery beyond what it can recharge on the good. Efficiency on charging batteries is just not that good :)
« Reply #15 on: June 12, 2019, 07:33:16 PM »
 In part 3 I test the setup with all 3 panels connected and look at the performance over the last 8 days.
It all consists of:
« Reply #16 on: September 16, 2019, 09:40:27 AM »
In part 4 I take a look at the efficiency and look at the performance over the last 60 days
Re: 750W solar offgrid 24V/150Ah battery setup with Victron charger
« Reply #17 on: September 16, 2019, 09:48:37 PM »
Mads
these are about the best there are
Outback Flexmax 80 FM80 MPPT 80 AMP Solar Charge Controller
programmable battery voltage etc etc
they are not cheap 499 on amazon
Today at 07:09:09 AM
Today at 06:02:30 AM
Today at 05:14:40 AM
Today at 03:54:03 AM
Today at 03:48:54 AM
Today at 01:03:12 AM
May 30, 2020, 11:50:10 PM
May 30, 2020, 11:37:54 PM
May 30, 2020, 11:32:37 PM
post Servomex CO2 analyser
May 30, 2020, 11:06:18 PM
Bradselph
May 30, 2020, 10:14:21 PM
May 30, 2020, 08:33:05 PM
Bradselph
May 30, 2020, 07:08:49 PM
May 30, 2020, 05:26:49 PM
May 30, 2020, 05:25:45 PM
May 30, 2020, 04:31:14 PM
May 30, 2020, 02:05:07 PM
May 30, 2020, 09:46:46 AM
May 30, 2020, 08:34:58 AM
May 29, 2020, 11:22:22 PM
post Re: SSTC Micro
May 29, 2020, 08:53:35 PM
May 29, 2020, 08:25:06 PM
sgtraf
May 29, 2020, 05:42:45 PM
post Re: SSTC Micro
May 29, 2020, 04:13:50 PM
May 29, 2020, 10:50:36 AM
post Re: SSTC Micro
jockoFergy
May 29, 2020, 08:46:27 AM
May 29, 2020, 12:00:26 AM
May 28, 2020, 11:40:37 PM
May 28, 2020, 11:29:00 PM
May 28, 2020, 10:33:50 PM
May 28, 2020, 10:07:59 PM
post Re: SSTC Micro
May 28, 2020, 09:39:53 PM
May 28, 2020, 03:55:56 PM
May 28, 2020, 10:25:50 AM
post Re: SSTC Micro
May 28, 2020, 04:59:02 AM
May 28, 2020, 04:32:26 AM
post Re: SSTC Micro
Rowdy
May 28, 2020, 04:12:23 AM
Rowdy
May 28, 2020, 03:41:17 AM
Rowdy
May 28, 2020, 03:40:25 AM
post Re: SSTC Micro
jockoFergy
May 28, 2020, 02:42:23 AM
May 27, 2020, 06:21:39 PM
fnordest
May 27, 2020, 12:11:06 PM
May 27, 2020, 11:51:19 AM
May 26, 2020, 07:55:03 PM
May 26, 2020, 07:40:48 PM
iraquois
May 26, 2020, 05:12:42 PM
May 26, 2020, 03:57:04 PM
May 26, 2020, 01:52:26 PM
May 26, 2020, 11:52:33 AM
May 26, 2020, 09:40:52 AM
