Author Topic: Calculating Hard-Switching losses  (Read 993 times)
Offline Phoenix
« on: July 31, 2018, 05:37:45 PM »
Hello  :)
I would like to calculate the maximum frequency i can drive an IGBT-Brick within its thermal limitation. I am using SKM200GB128D Bricks.
I am calculating the losses for 180A Hardswitching and a frequency of 20kHz. I need to find out the turn on/off energy first using the datasheet.
And here is my question: When reading the energy of the chart, do i need to use the 180A of current or the change of current (dI/dt)? The change of current would only be around 22.6A/µs high for 180A at 20kHz, which would result in much lower turn on/off energies.
Greetings,
Re: Calculating Hard-Switching losses
« Reply #1 on: July 31, 2018, 06:54:55 PM »
It is your peak current, that is how I calculated it for soft-switching here: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/igbts/
I guess you can use my example all the way through, just ignore the reduction factors for resonant switching that I use :)
Offline Phoenix
« Reply #2 on: July 31, 2018, 08:06:16 PM »
Thank you for your reply  :)
I have already followed your guide for the calculations but i am stuck at that point. In this application i am only switching  an inductive load, which results in a triangular waveform. The IGBT's always switch at the peaks of this waveform (180A). There is no resonance circuit, so the IGBT's always switch at full current. Because of that, i think i have to read the chart at 180A of current. But if i read the chart at the operating current, i can't keep up with the manufacturers claim of 220A at 20kHz with a junction temperature of 150°C and a case temperature of 80°C. Here are my calculations:
As you see i am only able to switch at a maximum frequency of 8.462kHz but according to the datasheet the bricks should be able to switch 20kHz at 220A.
Is there something wrong with my calculations?
Edit: I just tried something new and i think i have found the problem: A square wave has a RMS-Factor of 1, but a triangular wave only has a factor of 0,577. The maximum current rating in the datasheet is for DC, so there are no switching losses included. If i put in the numbers for 127A (220*0,577) into the equations, the result is 23,462 kHz and it should work for my inverter. Could this result be correct?
Greetings,
« Last Edit: July 31, 2018, 08:54:19 PM by Phoenix »
« Reply #3 on: July 31, 2018, 09:24:55 PM »
I was just about to mention that, just like I had to reduce for soft-switching short pulses, as hard-switching is seen as a square wave, a triangle waveform would also have to use a reduction factor, but you already figured that out :)
Offline Phoenix
« Reply #4 on: July 31, 2018, 10:27:35 PM »
I have now used the reduction factor for my 180A which gives me about 104A RMS. I used the RMS value for the CE Voltage and in the calculation for the conduction losses. But i have not used it for the turn on/off energy, because the IGBT still has to switch the 180A peak.
According to my calculations, if the junction has a temperature of 125°C and the Case has a temperature of 50°C, i can run my Inverter up to 20,6kHz. I also converted the equation to tell me the temperature difference between junction and case, at 20kHz the difference would be 73°C. I could now use a circuit which cuts of the supply voltage to the inverter using a relay, when the case temperature reachs 57°C, so the junction would never get hotter than 130°C  :D
Greetings,
« Last Edit: July 31, 2018, 11:57:15 PM by Phoenix »
Offline rikkitikkitavi
« Reply #5 on: August 17, 2018, 03:44:38 PM »
Just a thought, wouldnt average value instead of RMS be more accurate?
The loss is the integral of the current*voltage across the switching device during the switching event.
A man can not have to many variacs
Offline Phoenix
« Reply #6 on: August 17, 2018, 04:47:21 PM »
I only used the RMS Value for the calculation of the conduction losses during the ON-State.
For the losses during the switching event, i used the full 180A, because the IGBT's switch at the current maximum.
« Reply #7 on: August 18, 2018, 03:26:03 PM »
Conduction losses for an IGBT should probably be done with the average (mean) current rather than RMS - they behave more like a diode than a resistor in forward conduction. RMS is appropriate for MOSFETs though, and it probably won't make a lot of difference anyway.
Today at 02:22:09 PM
August 19, 2019, 09:08:12 PM
post Re: Drsstc 3
August 19, 2019, 02:27:06 PM
Avalanche
August 19, 2019, 02:12:41 PM
post Re: Drsstc 3
August 19, 2019, 10:44:35 AM
post Re: Drsstc 3
August 19, 2019, 07:37:07 AM
post Re: Drsstc 3
August 19, 2019, 03:29:24 AM
post Re: My second DRSSTC
erdal
August 18, 2019, 05:05:24 PM
Bert911
August 18, 2019, 01:04:35 PM
August 17, 2019, 11:09:16 PM
August 17, 2019, 11:00:32 PM
August 17, 2019, 09:44:07 PM
August 17, 2019, 09:01:00 PM
post Re: Twin System Build
August 17, 2019, 08:06:42 PM
Lane
August 17, 2019, 10:45:26 AM
Lane
August 17, 2019, 06:21:45 AM
August 17, 2019, 12:59:20 AM
fnordest
August 17, 2019, 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:19:18 PM
August 16, 2019, 10:07:31 PM
August 16, 2019, 09:28:35 PM
August 16, 2019, 09:17:04 PM
August 16, 2019, 09:14:36 PM
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
August 15, 2019, 06:23:40 PM
August 15, 2019, 06:17:55 PM
Lane
August 15, 2019, 01:51:04 PM
August 14, 2019, 07:05:57 PM
Bert911
August 14, 2019, 03:42:34 PM
[Static electricity]
Patric
August 14, 2019, 02:56:49 PM
August 14, 2019, 01:42:21 PM
erdal
August 14, 2019, 12:53:10 PM
Patric
August 14, 2019, 09:22:21 AM
post Re: Drsstc 3
August 14, 2019, 04:39:11 AM
August 13, 2019, 07:10:31 PM
August 13, 2019, 05:17:23 AM
August 12, 2019, 09:54:35 PM
erdal
August 12, 2019, 08:40:16 PM
August 12, 2019, 07:27:23 PM
August 12, 2019, 09:18:15 AM
August 12, 2019, 09:06:34 AM
August 12, 2019, 09:02:38 AM
August 12, 2019, 08:29:20 AM
August 12, 2019, 05:25:24 AM
August 10, 2019, 08:14:35 PM
