Author Topic: My first half bridge SSTC  (Read 1781 times)
Offline Acid Byte
« on: March 30, 2017, 05:38:17 PM »
Hey guys and girls!
After seeying many great builders on the internet succesfully building awesome SSTC's,
half year back i wanted to build my own.
Though circuitry isn't super complex at first glance.
By the time you get something to run you find out it's rather complex but in a different way.
As i believe we all expirienced it isnt that easy at all when starting on this at first!
With that said i can now show my first build.
My build is a combination of what i've seen out there and from my own expiriences.
Frequency of the secundairy is about 144khz
Its a half bridge design using 2 cap (resonant cap) in series on one side of the half bridge (coil at center tab and 1 cap going to vdc+ and one going to vdc ground)
This does provide a better coupling between coils (in terms of frequency) but doesnt give that sweet resonant rise ( :( atleast not like with drsstc's).
The logic board i used is the one designed by Matt Giordano wich is a pretty simple board but works fine anyways!
Im using a antenne for the feedback (i had some issues with the current transformer distorting the signal to the schmitt inverters wich gave some strange sounds to the sparks and didnt allow the voltage on the secundairy to go sky high...)
Overview components (some things have changed since)
Logic Driver Board by Matt Giordano
Overview Components
Overview Components
Half Bridge Schematic
Logic Driver Schematic
The old setup.
This setup really gave lot's of headache because the secundairy was just way to long for the current running in my primary.
Lots of arcs from primary to secundairy when it got up to higher arcs.
Current Setup
To build this it took me about 5 months of time destroying many many mosfets!!
Old Setup :)
Latest Setup :) (sorry for the shity video... my camera added a filter because of the EMI)
/>When i have some time ill shoot a better one :)
If you have any questions about the build feel free to ask!! :)
And also if you have thoughts of how it could do better yes please!! :)
Greetings Jeroen
« Last Edit: March 30, 2017, 08:09:22 PM by Acid Byte »
Re: My first half bridge SSTC
« Reply #1 on: March 31, 2017, 01:13:18 AM »
Thanks for the writeup, nice coil!
I agree with you, exactly how I felt when I started to build my first coil.. some things you thought were simple just start to go wrong
Offline Acid Byte
« Reply #2 on: March 31, 2017, 06:54:00 AM »
Thank you! :)
Its a good start into the more serious coils :)
Yeah and everything sterts to go wrong haha!!
« Reply #3 on: April 01, 2017, 01:34:45 PM »
That is great for a first SSTC :) and hopefully you will find it a good step towards building more complex coils like a DRSSTC.
First impression improvements for longer sparks are:
- Tighter coupling between primary and secondary coil, wind that primary coil directly on the PVC pipe as a helical coil (A bunched together coil of wire like you made have a much higher loss due to self induction, the outer turns simply use some of their energy on heating up the inner turns)
- Reduce primary turns, but be sure to calculate the currents, to avoid blowing up many more MOSFETs
- The wire length from DC bus caps to the MOSFETs are way too long, these should be as short as possible! The same goes for the wires in the primary circuit, to the primary coil. Did you you my chapter on primary circuit design? http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/busbar-and-primary-circuit/
- Higher DC bus voltage, do you have 3x400VAC? Or use a voltage doubler, if you can stay within the voltage rating of the MOSFETs :)
Offline Acid Byte
« Reply #4 on: April 02, 2017, 04:33:08 PM »
Thanks yeah i'm planning on a DRSSTC right now :)
Have to figure out some stuff...
Indeed its nothing close to ideal.
In the beginning i had a much closer coupled coil but had lot's of difficulties with arcing from primary to secundairy (or the other way arround)
This was probably due to not enough current in the primary.
Im still not sure how to calculate the currents running in the primary.
Can you point me out wich formula's to use? (EDIT: i allready found the awnser on the forum)
Havn't read it yet but i will! thanks!
Yeah all wires are to long :) gonna fix that in the next coil! :) (or maybe in the future)
For the homes we only have 1x 230VAC.
So a step would be using the voltage doubler with better mosfet or IGBT. (now running on irfp460)
Greetings Jeroen
« Last Edit: April 02, 2017, 09:55:40 PM by Acid Byte »
« Reply #5 on: April 06, 2017, 10:13:42 AM »
If you have questions, then start a thread in the DRSSTC section and you will get some help if you have specific questions :)
I saw on facebook that you tried a new primary coil with better results, but properly also higher primary currents, there is a thread just under yours here in forum where primary current in SSTC is discussed: https://highvoltageforum.net/index.php?topic=40.0
The reason I advocate helical or pancake coils are that they have a geometry that makes them able to be calculated, which can be real hard for a "bunch" of wires
If you have any questions to the DRSSTC design guide, things you do not understand or think could be explained better, you can add them in this thread: https://highvoltageforum.net/index.php?topic=38.0
Offline Acid Byte
« Reply #6 on: April 07, 2017, 06:30:45 AM »
Yeah again had some arc overs so rewound the primary + took a turn off.
wound it a little bit like a rodin coil (torus knot shape) just to see what happens :)
Could it be that the torus knot shaped primary would be more efficient in transferring the power? (it sure looks like it way better then the bunch of wires together!)
I know it's not a ideal situation but for now it's ok.
when i have read your guide i can start being more serious in the build (at the moment because i dont have all the knowledge most of the time is just trail and error for me. (wich does seem to give me alot of expirience :) ))
anyway ill be building alot more coils to see what happens in different situations. :)
Offline Acid Byte
« Reply #7 on: August 06, 2017, 12:21:42 PM »
A few updates on my half bridge coil.
I redid the primary and made a helical for it with much better coupling to the secundairy.
Also redid the inverter stage.
So this is the new 10 turn 6mm2 primary coil
And here is the new inverter layout on hand drawn pcb.
Now using 2x fgh60n60's in parallel a side
« Last Edit: August 06, 2017, 12:51:49 PM by Acid Byte »
post Re: My First DRSSTC
Today at 11:07:22 AM
sjsimmo
Today at 08:08:58 AM
post Re: How to calculate VA rating and other things for Ferrite Core? (SMPS)
[Transformer (ferrite core)]
sjsimmo
Today at 01:24:15 AM
post How to calculate VA rating and other things for Ferrite Core? (SMPS)
FilipŠebík
January 18, 2019, 07:32:38 PM
post Re: How to design a 7.5kV AC source?
January 18, 2019, 04:25:14 PM
post How to design a 7.5kV AC source?
CristianM
January 18, 2019, 03:48:06 PM
[Electronic circuits]
the_anomaly
January 17, 2019, 02:01:36 AM
January 16, 2019, 04:26:38 AM
post AC vs DC fuses, high current, explosive destructive testing and theory
[Capacitor banks]
January 15, 2019, 09:48:48 PM
neukyhm
January 15, 2019, 10:51:46 AM
January 14, 2019, 05:08:38 PM
the_anomaly
January 14, 2019, 01:15:53 PM
January 14, 2019, 12:22:07 PM
January 11, 2019, 05:10:39 AM
January 10, 2019, 10:59:25 PM
post Re: 迎词、来
[General chatting]
January 10, 2019, 06:56:59 PM
January 10, 2019, 05:33:48 PM
[General chatting]
black.yang
January 10, 2019, 02:11:58 AM
January 09, 2019, 09:14:59 PM
post Acoustic spectra of sung vowels by the FFT analyzer HP 3561A
Physikfan
January 08, 2019, 08:44:16 PM
post Re: IGBT failure in DRSSTC
Felix Bieri
January 08, 2019, 05:33:55 PM
post Re: Huawei RRU3928 1800MHz radio base station teardown (part 1 of 2)
[Radio frequency]
January 08, 2019, 08:25:08 AM
post Re: SimpleDriver v2.3, my phase-shifting QCW DRSSTC controller
January 08, 2019, 08:25:02 AM
January 08, 2019, 02:01:50 AM
post Re: (DR)SSTC II
January 07, 2019, 10:23:38 PM
Laci
January 07, 2019, 08:53:32 PM
January 07, 2019, 08:17:44 PM
January 07, 2019, 07:37:53 PM
January 07, 2019, 01:30:36 PM
Laci
January 07, 2019, 12:43:26 PM
January 07, 2019, 08:09:49 AM
NEYi
January 07, 2019, 07:43:50 AM
[General chatting]
January 07, 2019, 06:48:06 AM
January 07, 2019, 06:39:56 AM
Laci
January 06, 2019, 09:23:19 PM
January 06, 2019, 07:11:25 PM
January 06, 2019, 07:02:14 PM
January 06, 2019, 12:43:46 PM
Laci
January 06, 2019, 11:55:09 AM
TDAF
January 06, 2019, 09:48:06 AM
post Re: First SSTC build, need help troubleshooting
[Solid state Tesla coils]
TDAF
January 06, 2019, 09:45:17 AM
post 关于: 这个便宜的 drsstc 驱动程序从 aliexpress 1.3 b 类型?
black.yang
January 06, 2019, 08:34:46 AM
post 迎词、来
[General chatting]
black.yang
January 06, 2019, 08:20:21 AM
flyrod
January 06, 2019, 12:34:15 AM
January 05, 2019, 05:27:23 PM
flyrod
January 05, 2019, 03:46:29 PM
Laci
January 05, 2019, 09:51:10 AM
January 04, 2019, 11:02:25 PM
Laci
January 03, 2019, 08:38:15 PM
January 03, 2019, 08:15:48 PM
