Author Topic: DIY MMA welder (aka stick welder)  (Read 587 times)
Offline rikkitikkitavi
« on: July 11, 2018, 04:08:30 PM »
I have a couple of huge transformers (2kVA 20*2V) -C-core that is.
but it is the normal type, ie not possible to install magnetic shunts. I have  some large inductors (reactors)
I have humungs large rectifiers (400V 200A *16pcs) and heatsinks to match. Might even have some thyristors fitted for this...
A simple setup would be to use it as a current limited output for a MMA (stick) welder, AC or DC.
But it is difficult to adjust the output current this way.
 Also, the circuit needs to be designed with quite a large inductance in the reactor to compensate for the large open circuit voltage used for arc striking (about 50V+) compared to operating voltage on arc (about 15-25V)
One option is to use one of my even humungouser variacs (25A, ie 5kVA) to adjust output voltage and hence current draw as the welding arc voltage is not so affected by current through it.
This leads however to a less than mobile equipment. All together it packs up to 60 kg+ without casing. Or weelbarrow...
I never intended to have a inverter style portable welder but what options are there to replace the variac? How to build a variable  inductance for current limit easy way?
I have also some iron cores EI-150 size etc, and a good set of angle grinders :)
What ideas to use for increasing the voltage for arc striking but still having a low voltage output?
A man can not have to many variacs
Re: DIY MMA welder (aka stick welder)
« Reply #1 on: July 14, 2018, 05:54:41 AM »
Sounds like an awesome project. I'm not big into welding but one thing you can try to get a higher start voltage is to have a HF start box. This would allow a few kv to jump from the stick to the work surface to get an easier start, similar to the way a tig welder initiates the arc.
A quick google search has found this:
 https://www.dudley.nu/projects/hfstart/
i had to repair the hf start in my tig welder and this is what i replaced the step-up transformer and circuitry with:
 https://www.ebay.com.au/itm/Boost-Step-up-Module-High-voltage-Generator-Converter-DC3-7v-7-4v-to-400KV-EU/222903670891?hash=item33e618186b:g:H8kAAOSwXXVavZbv
« Reply #2 on: July 16, 2018, 10:17:34 AM »
Hmm, good idea.
Using a high voltage design, low resistance reactor in series to block the voltage but the problem is that it needs to block only the HF .  This is how any normal TIG is used.
DC welding , typically electronic inverter to be able to control current properly and with inert electrodes and protection gas.
It can therefore only be used with DC, but fortunately most MMA welding is used with DC (AC demands AC welding pins) , either positive or negative to the work piece.
Will look into it further. The protection reactor might demand some design for high impendance and high voltage design at HF, but low impendance at DC.
Today at 02:51:26 PM
post Re: What is the true in tuning guide?
Today at 02:48:02 PM
post Re: A problem solved with hand tools
[General chatting]
Today at 01:48:08 PM
post Re: Kaizer half bridge driver
Today at 01:45:00 PM
[General chatting]
Today at 11:21:29 AM
post What is the true in tuning guide?
VNTC
Today at 10:01:21 AM
post A problem solved with hand tools
[General chatting]
Today at 07:52:41 AM
[General chatting]
Today at 07:33:30 AM
post Re: tesla coil varnish is dumb
[Solid state Tesla coils]
July 14, 2019, 10:49:03 PM
July 14, 2019, 09:59:40 PM
July 14, 2019, 08:20:52 PM
July 14, 2019, 06:06:30 PM
post tesla coil varnish is dumb
July 14, 2019, 05:29:10 PM
post Led Closeups with Mobile phone and lens .
[Smart phones]
DashApple
July 14, 2019, 03:00:09 PM
post Re: Drsstc 3
July 14, 2019, 02:06:26 PM
post Re: DRSSTC in brust mode
July 14, 2019, 02:04:22 PM
post Re: Twin System Build
July 14, 2019, 01:27:18 AM
July 14, 2019, 01:22:15 AM
post Re: Drsstc 3
July 13, 2019, 03:48:54 PM
post DRSSTC in brust mode
SAMGO
July 13, 2019, 04:17:55 AM
donnersm
July 12, 2019, 08:54:54 PM
July 12, 2019, 07:16:40 PM
July 12, 2019, 06:33:00 PM
post Smooth corona or heavy spark, RF wave radiation frequency of Tesla coil drops ve
VNTC
July 12, 2019, 11:09:28 AM
post Re: Drsstc 3
July 12, 2019, 09:56:38 AM
post Re: Drsstc 3
July 12, 2019, 01:23:58 AM
post Re: Completed my pulsed power generator
[Capacitor banks]
July 11, 2019, 05:48:27 PM
[Capacitor banks]
July 11, 2019, 02:58:13 PM
July 11, 2019, 02:45:24 PM
post Kaizer half bridge driver
donnersm
July 11, 2019, 06:59:01 AM
post Completed my pulsed power generator
[Capacitor banks]
July 11, 2019, 05:43:31 AM
fnordest
July 11, 2019, 01:05:42 AM
post Re: "LightningStorm" VTTC project
[Vacuum tube Tesla coils]
Avenger
July 09, 2019, 07:31:37 PM
post Re: Siemens Polyphos 30 xray machine
July 09, 2019, 04:48:29 PM
July 09, 2019, 03:53:37 PM
[Electronic circuits]
Bert911
July 09, 2019, 08:45:17 AM
post DRSSTC schematic for simulating (primary feedback self-oscillating)
VNTC
July 09, 2019, 06:10:12 AM
July 08, 2019, 09:13:42 PM
post Re: Driving the LED lights with the streamers
July 08, 2019, 09:02:20 PM
post Re: Drsstc 3
July 08, 2019, 03:57:17 PM
July 08, 2019, 12:05:54 PM
post Driving the LED lights with the streamers
donnersm
July 08, 2019, 11:04:00 AM
post Re: Aliexpress cheap CM300-24H
SAMGO
July 08, 2019, 10:43:33 AM
post Re: Hydron's 160mm DRSSTC and topload current measurements
July 08, 2019, 09:59:49 AM
July 08, 2019, 08:04:44 AM
July 07, 2019, 08:19:33 PM
July 07, 2019, 08:03:59 PM
July 07, 2019, 05:28:04 PM
July 07, 2019, 05:24:20 AM
post Re: Induction Heater schematic modification
July 07, 2019, 04:53:29 AM
