Author Topic: Huawei RRU3908 base station teardown and circuit analysis (part 1 & 2)  (Read 566 times)
The Huawei RRU3908 is an outdoor Radio Base Station with one to four carriers and one to six sectors at 20/40 Watt RF output power per carrier.
Part 1 is the teardown itself with a walkthrough of different design highlights.
Part 2 is coming online in the following 1-2 weeks.
Part 2 is a complete circuit analysis and will also have high res pictures uploaded to this article.
« Last Edit: July 09, 2018, 09:43:08 PM by Mads Barnkob »
EDIT July 12 2018: See next post for new video with fixed audio. Sorry for the problems with low audio recordings on the first one.
Central Processing Units
Network communication is handled by a Freescale MPC8321 PowerQUICC2 CPU which runs at 200 MHz and has 2x 256 MB Hynix DDR2 RAM. It utilises a PMC QuadPHY 10 GB controller for the two optical input / output.
Decoding and encoding of the single bit streams for ADC and DAC are handled by the 3 Altera Cyclone III FPGA and the custom Huawei SD6151RBI controllers.
The single bit streams are treated by the Texas Instrument TMS320 series DSP CPUs. TMS320C6410 which is a fixed-point DSP that only calculates with integer numbers and the TMS320CT16482 1 GHz DSP CPU calculates floating point numbers.
Receive part
The input signal comes in two out of phase lines and are first treated by a Skyworks SKY73021-11 1.7 to 2.2 GHz downconversion mixer to get the frequency from 2.2 GHz to 550 MHz.
The local oscillator for the downconversion mixer is a Analog Devices ADF4110B.
A SIPAT SAW filter is used for isolation.
Depending on signal origin or type, I assume that the Analog Devices AD8376 Variable Gain Amplifiers are used before the signal lines split out into either a 3G ADC line or 4G ADC line.
The 3G line analog to digital conversion is handled by the Analog Devices AD6655-10 which is a 14-bit 150 MSPS chip that is specifically targeted for the 3G base stations.
The 4G line has a few more components as there is 2 MCL HSWA+1110 SPDT RF switch that feeds into 2 Maxim MAX2039E up/dowoconversion mixer and through a additional MCL HSWA+1110 SPDT RF switch it is handled by the Analog Devices AD9230-11-200 ADC which is a 11-bit 200 MSPS chip.
All timing is handled by the Analog devices AD9516-3 which is a 14-output clock generator with a built in 2 GHz local oscillator.
Transmit part
The single bit datastream from the Altera Cyclone III FPGA is handled by 2 Analog Devices TxDAC AD9788 which are specified for 16-bit 800 MSPS.
To get the signal up in frequency to the broadcast carrier frequency 2 Analog Devices ADL5375-05 upconversion modulators are used. These has a range from 400 MHz to 6 GHz.
The signal is then sent through a 5 staged ceramic resonator band pass filter.
Signal phase can be switched from the setup of transistors and EMC Technology & Florida RF Labs HPJ2F hybrid couplers.
The pre-amplifier before the signal is sent to the power amplifier is a Freescale MMG3004NT1 high linearity amplifier capable of 17 dB amplification in the range of 400 MHz to 2.2 GHz.
To control the signal strength a MCL 31R5 digital step attenuator sits before the output connector. This is a 31.5 dB attenuator that can work in 0.5 dB steps from a 6-bit serial control interface.
Power Amplifier
The power amplifier uses two stages where the first is a Infineon PTMA180402FL 40 Watt RF LDMOS that through a Xinger II XC1900A-03S hybrid coupler feeds two 90 degree out of phase signals to the output stage transistors which are NXP BLF6G20LS-140 140 Watt RF LDMOS.
The output is recombined in a Xinger II XC1900A-03S hybrid coupler before leaving to the diplexer through a circulator.
« Last Edit: July 12, 2018, 07:55:08 PM by Mads Barnkob »
Part 2 of 2 video, with fixed audio as good as possible, it was a low microphone level at the recording stage that was the problem, so also +12dB was possible in editing.
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 07:47:34 PM
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
setkiki
February 22, 2019, 04:28:24 AM
bogdan
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
post Re: My X-Ray Machine
Agent Smith
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
bogdan
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
February 19, 2019, 04:54:44 AM
nabzim
[Light, lasers and optics]
Thunderstruck
post Re: Resistor tolerance?
TonyHV
TonyHV
pentode
TonyHV
TonyHV
