Author Topic: Counterpoise? Need help!  (Read 938 times)
Offline antoine_z_h
« on: June 22, 2018, 12:23:41 PM »
Hi Guys.,
So I have SSTC2 now, working and operational, and I get feedback thru a current transformer, but unfortunately I don't have any Good Ground so sometimes my secondary feedback wire spark inside the CT, my friend Chris advised me about counterpoise, which would help grounding my coil ..
Any idea how to make that at home ? Can I use aluminum foil sheet ? or reflective car sunscreen?
Sunscreen
« Last Edit: June 22, 2018, 10:07:29 PM by Mads Barnkob »
Re: COUNTERPOISE ??? NEED HELP
« Reply #1 on: June 22, 2018, 01:08:08 PM »
Aluminium foil would work. The car windscreen thing probably has a very thin layer of aluminium - maybe too thin to be useful, and tricky to get a good connection.
I think most people use "chicken wire" mesh or similar as it is more durable and easier to deal with than big bits of foil. Note that the holes are _not_ a problem for this use.
Offline antoine_z_h
« Reply #2 on: June 22, 2018, 02:08:23 PM »
Okay so I may use chicken wire , or a mesh with tighter holes, would both work ?
Also please could you tell me, how to apply that to my device ? I mean do you want me to spread a sheet of the mesh under my coil (lets say 1M X 1M ) and connect the secondary ground to it ?
thanks,
« Reply #3 on: June 22, 2018, 03:09:34 PM »
Either will work.  Even if the counterpoise was a loop of wire on the floor with spokes from a center point, the capacitance would be a good fraction of a fully filled mesh because the charge tends to be concentrated on the edge of the counterpoise.  However, it is still worth using chicken wire rather than a loop of wire as its cheap and still given you more capacitance.
Offline antoine_z_h
« Reply #4 on: June 22, 2018, 03:58:34 PM »
can you tell me how to apply that in real life ?
« Reply #5 on: June 22, 2018, 10:05:10 PM »
Yes, think of it as an artificial ground plane. The idea of the ground is to have a much bigger capacitance than your topload, so there is a ratio between its size and how effective it will be. It is recommended to have roughly 10 times capacitance in the ground plane compared to the topload, that is is almost always not practically possible.
You should read this huge article I wrote: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/grounding-circuit-protection-and-emi/
Today at 05:51:09 AM
Today at 04:07:17 AM
VNTC
Today at 02:19:24 AM
VNTC
Today at 02:00:48 AM
VNTC
Today at 01:33:56 AM
May 22, 2019, 08:31:55 PM
dexter
May 22, 2019, 08:31:51 PM
VNTC
May 21, 2019, 11:35:57 PM
May 21, 2019, 09:59:54 PM
May 21, 2019, 09:51:27 PM
May 21, 2019, 09:49:03 PM
82026
May 21, 2019, 09:02:10 PM
Vaclav
May 21, 2019, 08:59:57 PM
May 21, 2019, 08:28:43 PM
May 21, 2019, 08:22:28 PM
Vaclav
May 21, 2019, 06:21:37 PM
May 21, 2019, 06:12:55 PM
May 21, 2019, 04:06:38 PM
Vaclav
May 21, 2019, 03:56:56 PM
Vaclav
May 21, 2019, 03:46:56 PM
May 21, 2019, 02:32:59 PM
May 21, 2019, 06:12:18 AM
May 20, 2019, 11:30:34 PM
Vaclav
May 20, 2019, 06:38:54 PM
May 20, 2019, 06:33:49 PM
82026
May 20, 2019, 02:27:59 PM
May 20, 2019, 02:57:46 AM
May 20, 2019, 01:06:27 AM
82026
May 19, 2019, 09:14:59 PM
May 19, 2019, 06:40:41 PM
May 19, 2019, 04:04:12 PM
May 19, 2019, 11:24:46 AM
May 19, 2019, 03:22:54 AM
May 19, 2019, 03:18:52 AM
May 18, 2019, 10:48:59 PM
Golddustpeak
May 18, 2019, 04:19:11 PM
May 17, 2019, 10:57:17 PM
jpb133
May 17, 2019, 09:41:56 PM
May 17, 2019, 12:41:17 PM
82026
May 16, 2019, 04:15:58 PM
May 16, 2019, 02:19:39 PM
Golddustpeak
May 16, 2019, 01:50:44 PM
May 16, 2019, 12:17:01 PM
May 16, 2019, 08:45:15 AM
May 15, 2019, 11:49:59 PM
May 15, 2019, 10:51:33 PM
May 15, 2019, 09:35:41 PM
Golddustpeak
May 15, 2019, 05:07:20 PM
May 15, 2019, 12:46:33 PM
May 15, 2019, 10:08:11 AM
