Author Topic: Voltage Multipliers keep destroying drivers  (Read 1329 times)
Offline Andy Kay
« on: June 06, 2018, 08:13:56 PM »
I've been playing with Cockcroft Walton and Marx configurations, and I've been running them from a 12V car battery in order to avoid getting high voltage spikes on my mains electrical system. I've used various kinds of devices for stepping up the 12V to provide a feed for the multiplier, such as CCFL inverters, ionizer circuits, and SS Tesla coil drivers, and every time the system works for a short time before the drive stage for the transformer primary coil burns out. Is there a standard way of dealing with this problem?
Offline FilipŠebík
Re: Voltage Multipliers keep destroying drivers
« Reply #1 on: June 07, 2018, 04:43:07 PM »
Limit current or use 1:1 transformer as a protection for HV spikeback (if that's a thing, duh)
« Reply #2 on: June 08, 2018, 09:14:22 AM »
It sounds like you have problems with either inductive kickback/EMF, lack coupling capacitor on the primary side of the transformer to avoid DC offset or you are saturating the transformer from high load and got no protection in the driver against transformer saturation.
« Reply #3 on: June 15, 2019, 05:19:35 PM »
I built one of those Chinese 20-stage Marx generators that you see on E-Bay and was experiencing a similar problem. It would occasionally blow the ZVS driver which was driving the flyback transformer. The problem stumped me for a while. Then one day I noticed that when it fired I could see a dim arc jumping across the resistor isolating the flyback coil from the Marx generator first stage. Some of the discharge energy was feeding back into the flyback coil which then fed back into the ZVS driver. I replaced the 2 resistors with higher voltage units and the problem was solved. You have to check those Chinese designs.
« Last Edit: June 16, 2019, 05:25:09 PM by MRMILSTAR »
« Reply #4 on: September 10, 2019, 10:02:25 PM »
One potential fix is to place a suitably-rated varistor across the transformer primary.
« Reply #5 on: October 10, 2019, 08:40:40 AM »
hopefully your transformer has an electrostatic shield between primary and secondary to cancel capacitive coupling primary to secondary especially important if you have flashovers as you will impinge your output voltage as a pulse into your primary circuit
then TVS diodes acroos the drive devices set just below their max voltage and tvs 20 volt diodes gate to source / base to emitter
ignore the above and keep feeding the silicon gods your expensive sacrifices
post Re: Cost reduction in consumer electrics
Today at 07:33:01 PM
Today at 11:09:20 AM
post Cost reduction in consumer electrics
Today at 07:25:20 AM
post Re: HV resistor in oil
Today at 05:52:11 AM
Today at 05:21:07 AM
December 04, 2019, 06:05:11 PM
post Re: Full bridge showing half the voltage
December 04, 2019, 02:57:02 PM
post Re: Sense coil fabrication?
[Induction launchers, coil guns and rails guns]
December 04, 2019, 12:40:51 PM
December 04, 2019, 11:20:25 AM
December 04, 2019, 08:28:15 AM
December 04, 2019, 07:41:21 AM
December 04, 2019, 05:15:49 AM
December 04, 2019, 05:06:39 AM
December 04, 2019, 04:31:16 AM
December 04, 2019, 04:26:38 AM
December 04, 2019, 04:10:16 AM
December 04, 2019, 12:28:15 AM
December 04, 2019, 12:11:32 AM
December 03, 2019, 07:58:41 PM
post Re: Driving Nixie-tubes with arduino
December 03, 2019, 07:54:08 PM
December 03, 2019, 07:41:00 PM
December 03, 2019, 02:14:00 PM
December 03, 2019, 01:24:00 PM
December 03, 2019, 10:45:58 AM
post Driving Nixie-tubes with arduino
December 03, 2019, 09:04:42 AM
December 03, 2019, 07:29:48 AM
December 03, 2019, 05:07:28 AM
December 03, 2019, 04:34:46 AM
December 02, 2019, 09:06:07 PM
December 02, 2019, 10:51:33 AM
jturnerkc
December 02, 2019, 05:49:05 AM
December 02, 2019, 04:10:14 AM
December 02, 2019, 04:09:37 AM
December 02, 2019, 03:42:16 AM
December 01, 2019, 10:47:18 PM
December 01, 2019, 09:17:38 PM
post HV resistor in oil
December 01, 2019, 08:51:31 PM
jturnerkc
December 01, 2019, 07:32:44 PM
post Re: Corona on the.... GDT??
December 01, 2019, 12:14:57 PM
post Re: SSTC low voltage at gate transformer and heating drivers
December 01, 2019, 04:30:10 AM
December 01, 2019, 02:56:39 AM
post Re: New to tesla coils, some questions before I start building a SSTC
Blin
November 30, 2019, 10:28:56 PM
jturnerkc
November 30, 2019, 09:41:17 PM
post Re: QCW ramp generator
November 30, 2019, 06:12:28 PM
November 30, 2019, 04:28:34 PM
November 30, 2019, 02:26:53 PM
November 30, 2019, 12:45:22 PM
post Re: Suggestions for CW HV feed-through
November 30, 2019, 06:45:09 AM
post Full bridge showing half the voltage
November 30, 2019, 06:42:20 AM
November 30, 2019, 05:24:50 AM
