Author Topic: Increasing secondary diameter from 160 to 200mm  (Read 925 times)
Offline Phoenix
« on: May 17, 2018, 07:31:47 PM »
Hello everybody,
About a month ago i finished building my first DRSSTC. I am very happy with the results. You can see a small test video with MIDI modulation here:
When i started this project I never thought that i would be able to run my coil up to 1200A. Because of that, i selected a 160mm resonator with 77cm length and 1850 turns. But i think i could get longer sparks with a 200mm resonator that is 100cm long. 1200A is quite a lot for a 160mm secondary.
Would such an increase in diameter make a big difference? Is it worth the work of winding a new secondary and remaking the primary?
Greetings,
Phoenix
« Last Edit: May 17, 2018, 07:34:09 PM by Phoenix »
Re: Increasing secondary diameter from 160 to 200mm
« Reply #1 on: May 20, 2018, 12:23:19 PM »
I wouldn't change anything :) Coil works nicely and extra headroom for the current will make sure that IGBTs won't blow up anytime soon
Winding new secondary and rebuilding the primary is almost like building a new coil. I have similar sized coil and thought about upgrading to fullbridge, then making bigger secondary. At the end I gave up and decided to build a new coil at some point
« Reply #2 on: May 22, 2018, 10:05:31 PM »
Congratulations on the build!
I agree with futurist, don't change a thing, that is a wonderful running coil. If you think you got too many ground sparks and want "longer" sparks from a taller secondary coil, there is a easier and cheaper solution to that, put your coil up on a 50 cm tall platform and fine tune it for maximum spark length again :)
I kind of went through the same process with my DRSSTC3, kept upgrading stuff on the way and it just took too much money and time, should just have built big from the start or stayed with original design, but it takes building one to learn that.
« Reply #3 on: May 23, 2018, 08:53:46 AM »
The other way to look at it is an excuse to build a second larger coil and run multi-channel midi! :P
Offline Phoenix
« Reply #4 on: May 23, 2018, 09:48:34 AM »
Thank you for all your replies  :D
I am going to leave the DRSSTC like it is now. Maybe i am going to upgrade to a skeleton topload because they look better than the aluminum flex tubing. I also bought a new 70A rectifier because the coil pulls up to 50A peak from one phase during groundstrikes! The old rectifier can only handle up to 35A.
I already own a right sized table as a platform. I am going to give it a try during the next run. If I run the coil on full power i am only getting groundstrikes. The grass in my backyard is already burned up because of the strikes into the soil   ;D
Greetings,
Phoenix
« Last Edit: May 23, 2018, 12:41:13 PM by Phoenix »
Offline Phoenix
« Reply #5 on: July 24, 2018, 11:23:29 PM »
It has been a while but here I have a video of my DRSSTC in a HV-Laboratory recorded with my DSLR instead of the camcorder:
Sadly, I did not have anything on hand to set the coil higher and because of that, I am getting a lot of groundstrikes and the spark length is limited. The coil is not even on full power in this video. But I think that groundstrikes look also really nice with their bright appearance.
Greetings,
Phoenix
« Last Edit: July 24, 2018, 11:30:18 PM by Phoenix »
« Reply #6 on: July 25, 2018, 12:51:11 PM »
Great performance and good sound quality, it does not get muddy at all despite playing multiply tones.
You should add a faraday cage made from chicken wire around your DSLR to protect the microphone from EMI, you do not even have to ground it, just have a cage all around it with a hole for the lens and you will get much better sound quality.
Offline Phoenix
« Reply #7 on: July 25, 2018, 01:15:39 PM »
Thank you very much for subscribing to my channel, Mads  :)
Actually, the DSLR was behind a farady cage (the whole test area of the laboratory is inside a farady cage) with a mesh size of about 2cm, so i managed to record the video right through the wire cage.
But as you said, a finer chicken wire should bring better results, because there is still some EMI going through the cage (the monitors of a PC started turning on). Thanks for the recommendation.
Today at 08:48:51 AM
VNTC
Today at 04:54:44 AM
post Re: Primary-Strike Protection Grounding Scheme - Insanity?
February 18, 2019, 09:25:24 PM
February 18, 2019, 09:11:48 PM
February 18, 2019, 06:38:29 PM
post My first DRSSTC on bricks
Laci
February 18, 2019, 05:17:53 PM
February 18, 2019, 08:44:19 AM
post Primary-Strike Protection Grounding Scheme - Insanity?
nabzim
February 18, 2019, 05:06:18 AM
[Electronic circuits]
February 18, 2019, 12:13:02 AM
post Re: A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
[Light, lasers and optics]
Laci
February 17, 2019, 08:22:04 PM
post A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
FilipŠebík
February 17, 2019, 07:04:54 AM
VNTC
February 17, 2019, 03:16:00 AM
[Solid state Tesla coils]
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
February 13, 2019, 03:12:37 PM
February 13, 2019, 02:47:49 PM
TonyHV
February 13, 2019, 01:57:55 PM
February 13, 2019, 01:53:36 PM
TonyHV
February 13, 2019, 01:45:53 PM
February 13, 2019, 12:58:48 PM
TonyHV
February 13, 2019, 12:35:10 PM
post Re: Homemade flyback on 60N60DLF full bridge
[Transformer (ferrite core)]
Platinum
February 12, 2019, 09:17:29 PM
post Video gear & workflow: Canon 5D mk3, Rødelink, FPS1000HD and more
[DSLR]
February 12, 2019, 08:51:43 AM
post Re: STB16PF06L
pentode
February 12, 2019, 08:16:33 AM
February 11, 2019, 11:06:05 PM
February 11, 2019, 10:58:06 PM
post Re: STB16PF06L
February 11, 2019, 10:18:39 PM
Laci
February 11, 2019, 04:28:24 PM
post STB16PF06L
pentode
February 11, 2019, 04:21:54 PM
Thunderstruck
February 11, 2019, 11:55:44 AM
February 11, 2019, 08:13:07 AM
post Homemade flyback on 60N60DLF full bridge
Platinum
February 10, 2019, 08:36:12 PM
post Resistor tolerance?
February 10, 2019, 05:46:39 PM
post Re: Help! IBGT 60N60 has been destroyed a lot by my coil
sjsimmo
February 09, 2019, 09:19:49 AM
post Help! IBGT 60N60 has been destroyed a lot by my coil
VNTC
February 09, 2019, 05:32:59 AM
post Re: DRSSTC design guide - progress report
February 08, 2019, 05:10:29 PM
