Author Topic: DRSSTC design guide - progress report  (Read 3986 times)
Re: DRSSTC design guide - progress report
« Reply #20 on: February 06, 2019, 03:59:33 PM »
I got the MMC article updated (password is still: "test"): http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/mmc-tank-capacitor/
MMC calculator has also been updated with the correct dissipation and temperature rise calculations: http://kaizerpowerelectronics.dk/calculators/mmc-calculator/
Please check it out and see if you can find any errors or suggestions for improvement :)
Now I just need to add some more pictures to the MMC design article and it will go "live"
« Reply #21 on: February 07, 2019, 09:19:49 PM »
It only took me a mere 4 years from I first started this article about the MMC until it is now done for public released :)
Not that it took me 4 full years to write on it, but it has been a on/off gathering of information and then finally making a write-up on it.
I hope this will help many builders understand MMC design better: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/mmc-tank-capacitor/
« Reply #22 on: February 07, 2019, 11:32:01 PM »
Have had a quick look through it, is some nice work but I'm not sure I subscribe to the idea that the MMC layout has a big effect on current sharing.
I would have thought that any sharing issues would only arise if the reactance of each capacitor string is similar in magnitude to the parasitic resistance/inductance of the connections between the strings.
Given that the reactance of a 100nF capacitor is ~16 ohms at 100kHz this should completely swamp any effects of the connections (unless they are _really_ bad) and thus force nearly perfect current sharing.
I'd personally focus more on keeping enough distance between capacitors, at least when being run at high RMS currents, so that there is less chance of hot spots.
Offline flyglas
« Reply #23 on: February 08, 2019, 05:10:29 PM »
Hi Mads,
your calculation of the temperature rise of the MMC seems to be correct, but your conclusion is wrong.
When you are calculating the temperature rise with the power dissipated within the capacitor (I^2*ESR) and the thermal resistance, than your are calculating the steady state and not only a limited period of time.
Cite: "While almost 10ÂșC does not sound like much, we have to remember that this is for a single second of operation."
In theory you only have to let the capacitor be able to cool down enough between pulses, when the temperature rise (at steady state) is over the allowed temperature rise of the capacitor.
August 22, 2019, 09:47:58 PM
post Re: Suitable capacitors and switches? 10kV
August 22, 2019, 09:38:27 PM
post Re: HV Pulser/Switcher
August 22, 2019, 09:34:25 PM
post Re: Drsstc 3
August 22, 2019, 09:32:24 PM
post Re: Heavily improvised DRSSTC
August 22, 2019, 09:25:16 PM
August 22, 2019, 09:13:44 PM
post HV Pulser/Switcher
magnetic_fields
August 22, 2019, 12:36:58 PM
August 22, 2019, 07:55:15 AM
MrFox
August 21, 2019, 10:51:21 AM
post Re: Drsstc 3
August 21, 2019, 03:59:47 AM
post Heavily improvised DRSSTC
Grzegorz2121
August 21, 2019, 01:36:21 AM
Grzegorz2121
August 21, 2019, 01:10:06 AM
August 20, 2019, 02:22:09 PM
August 19, 2019, 09:08:12 PM
post Re: Drsstc 3
August 19, 2019, 02:27:06 PM
post Flashing light prize 2019
Avalanche
August 19, 2019, 02:12:41 PM
post Re: Drsstc 3
August 19, 2019, 10:44:35 AM
post Re: Drsstc 3
August 19, 2019, 07:37:07 AM
post Re: Drsstc 3
August 19, 2019, 03:29:24 AM
post Re: My second DRSSTC
erdal
August 18, 2019, 05:05:24 PM
Bert911
August 18, 2019, 01:04:35 PM
post Re: You would think this would be easy to find.
August 17, 2019, 11:09:16 PM
August 17, 2019, 11:00:32 PM
August 17, 2019, 09:44:07 PM
post You would think this would be easy to find.
August 17, 2019, 09:01:00 PM
post Re: Twin System Build
August 17, 2019, 08:06:42 PM
Lane
August 17, 2019, 10:45:26 AM
Lane
August 17, 2019, 06:21:45 AM
August 17, 2019, 12:59:20 AM
fnordest
August 17, 2019, 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
post Re: Teardown of Danfoss VLT6000 4kW Variable Frequency Drive
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:19:18 PM
post Re: [Development] Project of an SSTC driver.
August 16, 2019, 10:07:31 PM
August 16, 2019, 09:28:35 PM
August 16, 2019, 09:17:04 PM
post Re: ESAB Power TIG 200 Welder Teardown
August 16, 2019, 09:14:36 PM
post ESAB Power TIG 200 Welder Teardown
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
post Suitable capacitors and switches? 10kV
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
August 15, 2019, 06:23:40 PM
August 15, 2019, 06:17:55 PM
Lane
August 15, 2019, 01:51:04 PM
August 14, 2019, 07:05:57 PM
Bert911
August 14, 2019, 03:42:34 PM
post Re: Van de Graaf is leaking charge
[Static electricity]
Patric
August 14, 2019, 02:56:49 PM
August 14, 2019, 01:42:21 PM
erdal
August 14, 2019, 12:53:10 PM
post Van de Graaf is leaking charge
Patric
August 14, 2019, 09:22:21 AM
