Author Topic: DRSSTC design guide - progress report  (Read 2773 times)
Re: DRSSTC design guide - progress report
« Reply #20 on: February 06, 2019, 03:59:33 PM »
I got the MMC article updated (password is still: "test"): http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/mmc-tank-capacitor/
MMC calculator has also been updated with the correct dissipation and temperature rise calculations: http://kaizerpowerelectronics.dk/calculators/mmc-calculator/
Please check it out and see if you can find any errors or suggestions for improvement :)
Now I just need to add some more pictures to the MMC design article and it will go "live"
« Reply #21 on: February 07, 2019, 09:19:49 PM »
It only took me a mere 4 years from I first started this article about the MMC until it is now done for public released :)
Not that it took me 4 full years to write on it, but it has been a on/off gathering of information and then finally making a write-up on it.
I hope this will help many builders understand MMC design better: http://kaizerpowerelectronics.dk/tesla-coils/drsstc-design-guide/mmc-tank-capacitor/
« Reply #22 on: February 07, 2019, 11:32:01 PM »
Have had a quick look through it, is some nice work but I'm not sure I subscribe to the idea that the MMC layout has a big effect on current sharing.
I would have thought that any sharing issues would only arise if the reactance of each capacitor string is similar in magnitude to the parasitic resistance/inductance of the connections between the strings.
Given that the reactance of a 100nF capacitor is ~16 ohms at 100kHz this should completely swamp any effects of the connections (unless they are _really_ bad) and thus force nearly perfect current sharing.
I'd personally focus more on keeping enough distance between capacitors, at least when being run at high RMS currents, so that there is less chance of hot spots.
Offline flyglas
« Reply #23 on: February 08, 2019, 05:10:29 PM »
Hi Mads,
your calculation of the temperature rise of the MMC seems to be correct, but your conclusion is wrong.
When you are calculating the temperature rise with the power dissipated within the capacitor (I^2*ESR) and the thermal resistance, than your are calculating the steady state and not only a limited period of time.
Cite: "While almost 10ºC does not sound like much, we have to remember that this is for a single second of operation."
In theory you only have to let the capacitor be able to cool down enough between pulses, when the temperature rise (at steady state) is over the allowed temperature rise of the capacitor.
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
[Solid state Tesla coils]
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 07:47:34 PM
Laci
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
[Transformer (ferrite core)]
setkiki
February 22, 2019, 04:28:24 AM
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
Laci
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
VNTC
February 19, 2019, 04:54:44 AM
post Re: Primary-Strike Protection Grounding Scheme - Insanity?
February 18, 2019, 09:25:24 PM
February 18, 2019, 09:11:48 PM
February 18, 2019, 06:38:29 PM
post My first DRSSTC on bricks
Laci
February 18, 2019, 05:17:53 PM
February 18, 2019, 08:44:19 AM
post Primary-Strike Protection Grounding Scheme - Insanity?
nabzim
February 18, 2019, 05:06:18 AM
[Electronic circuits]
February 18, 2019, 12:13:02 AM
post Re: A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
[Light, lasers and optics]
Laci
February 17, 2019, 08:22:04 PM
post A place where I can buy a fiber cable/reciever/transmitter for SSTC interrupter
FilipŠebík
February 17, 2019, 07:04:54 AM
VNTC
February 17, 2019, 03:16:00 AM
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
