Author Topic: Flashing the digispark with the oneTesla MIDI interrupter code  (Read 688 times)
I managed to modify and flash the digispark with the oneTesla interrupter code.   Here's how to do it:
1.  Buy a Digispark (usually $5 to $10).
2.  Get an Arduino Uno to use as a programmer.
3.  Follow these instructions to plug in the Arduino as the ArduinoISP avrisp programmer:
http://www.instructables.com/id/How-to-Program-an-ATtiny-85-Digispark/
In particular, connect the following pins together
Uno 5V : Digispark Terminal VCC
Uno GND:  Digispark Terminal GND
Uno pin 13:  Digispark P2
Uno pin 12:  Digispark P1
Uno pin 11:  Digispark P0
Uno pin 10:  Digispark P5
4.  Install Arduino software to get avrdude
5.  Flash the Digispark with new code:
avrdude -C"C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -v -pattiny85 -cavrisp -PCOM5 -b19200 -D -e -Uflash:w:main.hex:i make
using the main.hex file from the attached distribution, change the paths and the com port to match your configuration.
6.  Disconnect and plug in the digispark; it should be recognized as a OneTesla MIDI controller.
A single pole-single throw switch is attached to P0, the LED is attached to P2 through a 100 ohm resistor.
« Last Edit: May 11, 2018, 01:14:51 AM by profdc9 »
Re: Flashing the digispark with the oneTesla MIDI interrupter code
« Reply #1 on: May 17, 2018, 11:03:23 AM »
Thanks for the guide.
What are the advantages of the digispark over just a arduino uno? Is it just that its much smaller and cheaper?
« Reply #2 on: May 17, 2018, 04:02:53 PM »
It's smaller and cheaper.  I bought mine for $5 on ebay, but you can get Chinese ones for $2 if you want to wait for them.   There's no wiring to do except to add the LED for the fiber optic cable, so it's basically ready to go, it is essentially the same circuit as OneTesla's USB with the pins exchanged.   Also, you don't need a USB to MIDI interface for it, you just connect the USB directly to it.  The disadvantage is that it doesn't use the SD cards, which I wasn't going to use anyways.
I added a spot for the OneTesla USB midi interrupter to one of my interrupters so that it can share the same output LED and save some money there as well, as well as integrate both the test interrupter and the music interrupter into a single board.
« Last Edit: May 17, 2018, 04:13:05 PM by profdc9 »
« Reply #3 on: May 20, 2018, 12:09:36 PM »
Arduino boards will work the same, it depends on which one are you more comfortable using. Nano boards cost under 3$ delivered and if you use internal FTDI you also don't need MIDI-USB cable
VNTC
Today at 03:16:00 AM
[Solid state Tesla coils]
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
February 13, 2019, 03:12:37 PM
February 13, 2019, 02:47:49 PM
TonyHV
February 13, 2019, 01:57:55 PM
February 13, 2019, 01:53:36 PM
TonyHV
February 13, 2019, 01:45:53 PM
February 13, 2019, 12:58:48 PM
TonyHV
February 13, 2019, 12:35:10 PM
post Re: Homemade flyback on 60N60DLF full bridge
[Transformer (ferrite core)]
Platinum
February 12, 2019, 09:17:29 PM
post Video gear & workflow: Canon 5D mk3, Rødelink, FPS1000HD and more
[DSLR]
February 12, 2019, 08:51:43 AM
post Re: STB16PF06L
pentode
February 12, 2019, 08:16:33 AM
February 11, 2019, 11:06:05 PM
February 11, 2019, 10:58:06 PM
post Re: STB16PF06L
February 11, 2019, 10:18:39 PM
Laci
February 11, 2019, 04:28:24 PM
post STB16PF06L
pentode
February 11, 2019, 04:21:54 PM
Thunderstruck
February 11, 2019, 11:55:44 AM
February 11, 2019, 08:13:07 AM
post Homemade flyback on 60N60DLF full bridge
Platinum
February 10, 2019, 08:36:12 PM
post Resistor tolerance?
February 10, 2019, 05:46:39 PM
post Re: Help! IBGT 60N60 has been destroyed a lot by my coil
sjsimmo
February 09, 2019, 09:19:49 AM
post Help! IBGT 60N60 has been destroyed a lot by my coil
VNTC
February 09, 2019, 05:32:59 AM
post Re: DRSSTC design guide - progress report
February 08, 2019, 05:10:29 PM
post Re: Russian Marx generator test center torn down
February 08, 2019, 09:19:57 AM
February 07, 2019, 11:32:01 PM
February 07, 2019, 09:19:49 PM
post Re: Keep or throw away ?
Thunderstruck
February 07, 2019, 12:20:52 PM
February 07, 2019, 12:16:31 PM
Thunderstruck
February 07, 2019, 11:27:44 AM
February 07, 2019, 08:56:57 AM
February 06, 2019, 08:47:55 PM
February 06, 2019, 08:46:20 PM
post Russian Marx generator test center torn down
February 06, 2019, 08:45:25 PM
TonyHV
February 06, 2019, 07:04:20 PM
