Author Topic: Low/Medum frequency royer induction heater  (Read 1071 times)
Offline kamelryttarn
« on: April 30, 2018, 12:49:26 PM »
I modified an ebay induction heater this weekend in order to try and heat up a small brass pipe. I tried to search the web for information about what frequency to use but I couldn't find much info so I tried a few different capacitor banks to see if I could measure the difference and take it from there.
Firstly I made a new work coil by winding a enameled wire about 1mm in diameter around a glass tube. With the default cap bank of 2uF I got about 70kHz without anything in the work coil and about 80kHz when I had the brass pipe inside it.
I used a lead acid car battery that was charged to around 13V for all tests. "Idle current" was 3,3A and "working current" was 11A so I assume the power transferred to the work piece is roughly 100W. This is probably not very accurate but all I wanted to do was figure out I should aim for a high or low frequency.
Next I soldered an additional 6pcs of capacitors to that backside of the PCB doubling the capacitance. When I fired it up I got 48kHz instead at idle and 60kHz with the brass pipe inside the work coil. Currents were 5A at idle and 19A when "working" so I think that brass responds better at lower frequencies.
The final test was made with a 30uF capacitor salvaged from the welder I bought to get my large three phase transformer. Unfortunately I did not get any current measurements but unloaded work coil gave me 19kHz . When I inserted the brass pipe and fired it up it quickly broke down and one of the mosfets started smoking.
The 30uF is probably not going to survive very long under these conditions but it was fun to give it a try. I will try and replace the mosfets and other components and do some more testing.
« Last Edit: April 30, 2018, 01:23:17 PM by kamelryttarn »
Re: Low/Medum frequency royer induction heater
« Reply #1 on: May 01, 2018, 11:07:12 AM »
Great to see you back with more experiments :)
I think your test voltage is too low, you simply risk blowing the MOSFETs from not switching them fully on. Maybe try with 24V instead?
I seem to recall that the 23.9MB document here: http://kaizerpowerelectronics.dk/tools/file-archive/?drawer=application_notes*induction_heating contains some tables on frequency for different material types.
« Reply #2 on: May 01, 2018, 01:07:06 PM »
Great document! Did you scan that?
Yes I think you are correct about my driving voltage. However, since these are ridiculously power hungry circuits, finding a 24V psu that can drive this thing is not easy or cheap.
I found a really good online calculator that may aid me choosing a frequency: http://www.nessengr.com/technical-data/skin-depth/
I would like something like 1mm penetrating depth in my brass pipe which suggest an oscillating frequency just shy of 20kHz. I am also somewhat limited by my coil design since I only want to heat about 10-20mm of the pipe so I can not wind a 100mm long 15mm diameter coil to get a reasonable inductance of my work coil. One solution could perhaps be to wind a much larger diameter coil and up the psu voltage to compensate for the distance between the work coil and the work piece.
« Reply #3 on: May 01, 2018, 05:46:08 PM »
Just add another 12 volt lead acid car battery.
« Reply #4 on: May 02, 2018, 08:55:59 AM »
I would if I had one.
Re: Low/Medum frequency royer induction heater/Battery
« Reply #5 on: May 02, 2018, 08:36:41 PM »
Getting a car battery:
  Many car batteries are replaced before they are totally shot.
Assuming that you do have a battery charger of some sort:
So, go to a car repair shop and ask if you can pick through their used batteries.  They get $5 or $10 in trade, right?  Prepare to pay that much.  If you tell them what you are doing with them, they may even sell them for less.
   Find one or two that still have some life left.  I know this is a rough "rule of thumb", but if the terminal voltage is above 12.2, it will probably take a charge, at least long enough for experimental purposes.
post HV Pulser/Switcher
magnetic_fields
Today at 12:36:58 PM
Today at 07:55:15 AM
MrFox
August 21, 2019, 10:51:21 AM
post Re: Drsstc 3
August 21, 2019, 03:59:47 AM
post Heavily improvised DRSSTC
Grzegorz2121
August 21, 2019, 01:36:21 AM
Grzegorz2121
August 21, 2019, 01:10:06 AM
August 20, 2019, 02:22:09 PM
August 19, 2019, 09:08:12 PM
post Re: Drsstc 3
August 19, 2019, 02:27:06 PM
Avalanche
August 19, 2019, 02:12:41 PM
post Re: Drsstc 3
August 19, 2019, 10:44:35 AM
post Re: Drsstc 3
August 19, 2019, 07:37:07 AM
post Re: Drsstc 3
August 19, 2019, 03:29:24 AM
post Re: My second DRSSTC
erdal
August 18, 2019, 05:05:24 PM
Bert911
August 18, 2019, 01:04:35 PM
August 17, 2019, 11:09:16 PM
August 17, 2019, 11:00:32 PM
August 17, 2019, 09:44:07 PM
August 17, 2019, 09:01:00 PM
post Re: Twin System Build
August 17, 2019, 08:06:42 PM
Lane
August 17, 2019, 10:45:26 AM
Lane
August 17, 2019, 06:21:45 AM
August 17, 2019, 12:59:20 AM
fnordest
August 17, 2019, 12:18:48 AM
post Re: Drsstc 3
August 16, 2019, 10:34:46 PM
August 16, 2019, 10:26:19 PM
August 16, 2019, 10:19:18 PM
August 16, 2019, 10:07:31 PM
August 16, 2019, 09:28:35 PM
August 16, 2019, 09:17:04 PM
August 16, 2019, 09:14:36 PM
August 16, 2019, 08:03:18 PM
August 16, 2019, 01:49:53 PM
MrFox
August 16, 2019, 12:21:36 PM
Lane
August 16, 2019, 11:22:45 AM
August 15, 2019, 06:23:40 PM
August 15, 2019, 06:17:55 PM
Lane
August 15, 2019, 01:51:04 PM
August 14, 2019, 07:05:57 PM
Bert911
August 14, 2019, 03:42:34 PM
[Static electricity]
Patric
August 14, 2019, 02:56:49 PM
August 14, 2019, 01:42:21 PM
erdal
August 14, 2019, 12:53:10 PM
Patric
August 14, 2019, 09:22:21 AM
post Re: Drsstc 3
August 14, 2019, 04:39:11 AM
August 13, 2019, 07:10:31 PM
August 13, 2019, 05:17:23 AM
August 12, 2019, 09:54:35 PM
erdal
August 12, 2019, 08:40:16 PM
August 12, 2019, 07:27:23 PM
