Author Topic: How go get single mode optic fiber to work  (Read 786 times)
Offline TDAF
« on: April 25, 2018, 04:27:52 PM »
I bought this cheap optic fiber cable off of eBay
I can't get this to transmit with any LED I use
What can I do about it
Except for buying a optic transmitter that is
Re: How go get single mode optic fiber to work
« Reply #1 on: April 25, 2018, 05:24:15 PM »
Hello TDAF,
I tried something similar with my SC optic fiber cable. I took a 5mW green laser module to light into one side and thought, considering the brightness of the laser (on a white wall it‘s no more confortable to look at the dot), I should clearly see green on the other side. Actually I had to search for it, although I perfectly knew where it should be.
There was a green dot, but it was incredibly small and not bright at all; I had the impression, that it was the smallest point I could be able to make out.
So, where I want to get with this is
1) Although you‘re lighting up one side, you might not be able to see something on the other side
2) As the actual "conducting channel" is so small, there‘s not a lot of light going in. Therefore you need a very sensitive detector.
Offline TDAF
« Reply #2 on: April 25, 2018, 05:39:59 PM »
I have a detector ic
It's just the transmitter that''s the problem
« Reply #3 on: April 25, 2018, 05:54:03 PM »
Single mode receivers and transmitters are completely different to multi-mode ones. Make sure you have everything matched (Rx, Tx and fibre)!
Offline TDAF
« Reply #4 on: April 25, 2018, 06:15:05 PM »
The Rx is a HFBR-2412tz which to my knowledge is a single-mode receiver so, IM SAFE!!
« Reply #5 on: April 25, 2018, 06:37:56 PM »
HFBR-2412tz is a multimode receiver!
I bought a similar cable on ebay and it ended up in the garbage
Offline TDAF
« Reply #6 on: April 25, 2018, 06:55:20 PM »
uhhhhh......
shit
« Reply #7 on: April 25, 2018, 08:28:19 PM »
Sorry, but I think you'll need to look at the HFBR datasheets, research and search further (multimode patch leads are cheap on ebay thankfully). There is also a colour code - wikipedia should help you with that. Avoid yellow!
post Re: Bleed R's for MMC caps ?
pentode
Today at 08:36:58 AM
L_Mangold
Today at 02:40:13 AM
post Re: Kaizer DRSSTC1 bridge failure and repair, caught on video.
dexter
February 22, 2019, 07:47:34 PM
February 22, 2019, 06:10:35 PM
February 22, 2019, 04:34:54 PM
February 22, 2019, 04:34:14 PM
post Kaizer DRSSTC1 bridge failure and repair, caught on video.
February 22, 2019, 02:59:46 PM
pentode
February 22, 2019, 12:20:26 PM
February 22, 2019, 10:07:23 AM
pentode
February 22, 2019, 08:28:17 AM
post Re: TL494 Flyback driver oscillator section
setkiki
February 22, 2019, 04:28:24 AM
bogdan
February 21, 2019, 06:41:27 PM
February 21, 2019, 06:06:46 PM
February 21, 2019, 03:15:47 PM
post Bleed R's for MMC caps ?
pentode
February 21, 2019, 02:54:39 PM
February 21, 2019, 09:37:55 AM
post Re: 160mm PLL sstc
February 21, 2019, 04:44:03 AM
post Re: My X-Ray Machine
Agent Smith
February 20, 2019, 11:10:28 PM
February 20, 2019, 06:45:41 PM
bogdan
February 20, 2019, 03:20:24 PM
February 20, 2019, 10:02:24 AM
February 20, 2019, 08:42:24 AM
February 19, 2019, 08:48:51 AM
VNTC
February 19, 2019, 04:54:44 AM
nabzim
[Light, lasers and optics]
VNTC
VNTC
Thunderstruck
black.yang
post Re: Resistor tolerance?
TonyHV
TonyHV
black.yang
black.yang
pentode
TonyHV
TonyHV
