Author Topic: Drsstc 3  (Read 4472 times)
Re: Drsstc 3
« Reply #40 on: February 28, 2019, 11:21:25 AM »
time to get started on this project again!
in the time since i last posted i haven't achieved much. the bridge and the mmc are pretty much completed with some minor tweaks needed.
For the bridge i ended up using 8mm aluminium plate for the bus bars which has an added bonus of making the assembly more rigid, although i don't know if its a wise decision to be relying on the terminals of the bricks to take the load of the capacitors?  As for the mmc it was pretty simple. 3mm x 15mm coper flat bar was used along with m6 cap heads to keep everything in place.
« Last Edit: February 28, 2019, 11:23:00 AM by oneKone »
Re: Drsstc 3
« Reply #41 on: April 10, 2019, 01:45:25 AM »
For about a month now I've been put off on this project, I really couldn't be bothered making any progress and I couldn't figure out why..... Then it hit me! I hate the look of it 😢
Basically I had a 450x450x350mm "cube" for the base of the coil, to me that's pretty unappealing. One look I do like are round bases both a helical primary. Apart from Mads drsstc 1 I haven't really seen bigger drsstc with helical primaries at all, unless having a pancake primary was more of the norm 5-10 years ago?
So my question is, are there any drawbacks from having a helical primary at this size I can't think of?
Re: Drsstc 3
« Reply #42 on: April 10, 2019, 09:13:24 AM »
Good old Dr. Spark, which seems to have closed down his website, primarily built helical primary coils and they performed great!
Now I built a helical coil on my first DRSSTC for several reasons:
- To make the coil take up less space, smaller diameter
- I thought it was easier to make primary coil holders for this type compared to spiral
- Tapping was easier with cable just going up the side
I will avoid helical coils in the future for the following reasons:
- It has a high coupling that is harder to adjust/control
- It is much closer to the topload, so there is more strikes to ground rail
- It was a pain to wind the coil through the 4 sheets with too small holes, it took me hours to move it centimeters at a time as it kept locking itself in place
- There is no performance gain over spiral, for a DRSSTC
I would however still make round platforms with spiral primary coils, as I think they look great, but when you get up in size you really need a bigger base to stabilize the thing with wheels out in the corners of a box.
You could also go inbetween spiral and helical and make a upsidedown U shape primary if you want it to have a smaller diameter overall.
Looking forward to see what you decide on :)
Re: Drsstc 3
« Reply #43 on: April 10, 2019, 09:49:46 AM »
Cheers for the guidance Mads. Is having a upsidedown U primary the same calculation as a flat pancake?  I had a quick look at your drsstc that uses one, looks extremely nice.
Re: Drsstc 3
« Reply #44 on: April 10, 2019, 12:21:20 PM »
I think I just went with a median value based on spiral coil and coupling as if it was a helical, but as you can see from the article on my website, I did a lot of measurements instead, as I could not calculate its specifications.
I guess you have to use something like FEMM in order to get a correct simulation as spiral/helical calculators and javatc does not support that primary form.
Re: Drsstc 3
Seb555
Today at 08:14:08 AM
April 18, 2019, 10:33:01 PM
post Re: New small SSTC
April 18, 2019, 10:28:28 PM
April 18, 2019, 10:24:33 PM
April 18, 2019, 10:13:06 PM
April 18, 2019, 09:51:49 PM
April 18, 2019, 09:26:14 PM
April 18, 2019, 09:20:15 PM
April 18, 2019, 09:10:30 PM
April 18, 2019, 08:01:36 PM
April 18, 2019, 07:04:40 PM
post Question about secondary
April 18, 2019, 06:32:18 PM
post Directional Cosmic ray detector
pentode
April 18, 2019, 05:39:02 PM
DICKEYBIRD
April 18, 2019, 04:32:55 PM
post Re: Resisitors
April 17, 2019, 11:12:06 PM
April 17, 2019, 10:44:02 PM
April 17, 2019, 09:38:39 PM
April 17, 2019, 09:29:05 PM
April 17, 2019, 09:22:07 PM
bogdan
April 17, 2019, 09:08:08 PM
April 17, 2019, 09:01:40 PM
April 17, 2019, 08:55:48 PM
April 17, 2019, 08:51:47 PM
April 17, 2019, 08:42:33 PM
April 17, 2019, 08:34:44 PM
April 17, 2019, 08:22:30 PM
Bambinz
April 17, 2019, 08:16:07 PM
April 17, 2019, 08:14:52 PM
bogdan
April 17, 2019, 07:55:29 PM
April 17, 2019, 11:51:59 AM
April 17, 2019, 09:53:36 AM
April 16, 2019, 08:46:05 PM
Bambinz
April 16, 2019, 06:55:02 PM
Bambinz
April 16, 2019, 06:45:24 PM
April 16, 2019, 03:06:02 PM
April 16, 2019, 03:26:34 AM
April 16, 2019, 01:20:34 AM
April 15, 2019, 10:02:19 PM
April 15, 2019, 09:28:09 PM
April 14, 2019, 09:20:52 PM
April 14, 2019, 07:56:40 PM
April 14, 2019, 03:00:18 PM
post Secondary Design Tool
April 14, 2019, 08:00:59 AM
DICKEYBIRD
April 14, 2019, 03:58:34 AM
April 14, 2019, 12:23:14 AM
post One trace illustrate 2 resonance frequency
April 14, 2019, 12:15:19 AM
April 13, 2019, 11:16:20 PM
April 13, 2019, 09:40:09 PM
April 13, 2019, 06:00:05 PM
post Re: Hi Steve, would you please explain . . . .
Rafferty
April 13, 2019, 02:45:11 PM
