Author Topic: How to keep the secondary coil from tipping over?  (Read 630 times)
« on: March 12, 2018, 12:37:52 AM »
I know this is kind of a prosaic question, but how do you mount your secondary coil tube on the bottom?  It is a tall and potentially top-heavy.  When I used a 4" PVC for my last coil, I used a PVC flange screwed to the top table, and then the PVC tube slipped over that and that is quite secure.  For my next coil, I am using a 6" PVC pipe and as far I can tell, I can not find any flanges except for a high price.
I am trying to find something not made out of metal so that the eddy current doesn't heat the metal rather than generating a current in the coil.   I looked from some plastic L brackets and have not found anything sufficiently stout to not crack when the PVC pipe is pushed on a little.   I would like to wind the coil, but want to make sure enough space is left at the bottom for mounting.
Offline Garyf
Re: How to keep the secondary coil from tipping over?
« Reply #1 on: March 12, 2018, 01:50:27 AM »
See if you can find a hardware store that has nylon bolts and nuts to pass thru the endcap. Three or four should do.
Offline CCX191
    • My instructables
« Reply #2 on: March 12, 2018, 08:20:58 AM »
I just 3d modelled my own adapter. However I used metal bolts but as @Grayf and mads in my thread mentions that you can use nylon bolts and nuts.
Have a look at my build here: https://highvoltageforum.net/index.php?topic=77.0
Maybe spam epoxy?
« Reply #3 on: March 12, 2018, 08:31:02 AM »
For my 160mm (~6") coil I used PVC pipe end caps with M12 (~1/2") nylon bolts. I obtained them from a components distributor who specialised in plastic hardware, and were as big as I could buy without paying crazy money. Wish I'd bought a few more for future projects!
« Reply #4 on: March 14, 2018, 10:24:16 AM »
For my DRSSTC1 I used the primary supports to also hold the secondary coil in place, I just removed some of the acrylic that would cover the secondary windings, so it was just kept in place by a snug fit around the bottom of the secondary coil.
For DRSSTC3 it was a whole other story as the secondary coil is around 50 kg by itself, so we made a sturdy plastic base with a bolt and split assembly for fast and easy setup/packing down. Works great :)
« Reply #5 on: March 14, 2018, 01:45:49 PM »
Thanks for the detailed response, Mads.  I bought a couple of end caps.  One will be for the base, the other to go on top to have a screw through it so I can screw on the topload.  I am going to have a small screw post terminal on the bottom of the topload so I can disconnect it from the wire that connects it to the ground/strike ring.
Offline AndreiRS
« Reply #6 on: March 14, 2018, 10:45:45 PM »
I used a pvc thing called "anti infiltration flange". I found this things at home construction stores. Cheap stuff... I could not find cheap acrylic, which would look a lot better.
Here is how it is used, it guides the water that was going around the tube to inside of it again.
The one I got looks just like this one.
Maybe you can find something like that near you. I forgot to mention, but they are only available for 100mm pvc pipes here. Or 4 inches.
« Last Edit: March 14, 2018, 10:54:02 PM by AndreiRS »
post Re: TO-247 IGBT Comparison for High Frequency & Paralleled Operation
Today at 10:30:34 PM
Today at 09:42:25 PM
Today at 09:25:26 PM
post Re: My First DRSSTC
Today at 12:50:45 PM
Today at 10:45:01 AM
Today at 09:47:51 AM
Today at 03:18:05 AM
Today at 02:08:57 AM
December 17, 2018, 10:22:31 PM
post TO-247 IGBT Comparison for High Frequency & Paralleled Operation
December 17, 2018, 09:36:03 PM
post Re: spectral analysis of Tesla coils
December 17, 2018, 02:20:01 PM
December 17, 2018, 01:13:34 PM
December 17, 2018, 01:02:35 PM
December 17, 2018, 12:33:07 PM
December 17, 2018, 12:26:08 PM
post Re: Building of my first tesla coil
December 17, 2018, 10:42:17 AM
December 17, 2018, 06:49:52 AM
Skylex86
December 16, 2018, 09:09:13 PM
December 16, 2018, 07:48:55 PM
NordicGaben
December 16, 2018, 06:13:54 PM
post spectral analysis of Tesla coils
Physikfan
December 15, 2018, 02:24:20 PM
December 14, 2018, 10:21:25 PM
December 14, 2018, 08:38:52 PM
December 13, 2018, 12:23:30 PM
December 12, 2018, 11:57:02 PM
December 12, 2018, 01:15:30 PM
December 12, 2018, 01:00:34 PM
December 12, 2018, 11:45:08 AM
December 11, 2018, 09:13:49 AM
December 11, 2018, 12:03:54 AM
December 10, 2018, 12:25:15 PM
December 10, 2018, 11:13:38 AM
December 10, 2018, 09:18:24 AM
December 10, 2018, 09:13:37 AM
December 10, 2018, 02:18:59 AM
December 09, 2018, 11:09:34 PM
December 09, 2018, 10:23:38 AM
December 09, 2018, 06:05:02 AM
Jesjes
December 09, 2018, 04:50:56 AM
December 08, 2018, 12:52:41 PM
December 08, 2018, 09:51:47 AM
post Huawei RRU3928 1800MHz radio base station teardown (part 1 of 2)
[Radio frequency]
December 06, 2018, 07:49:06 PM
December 03, 2018, 10:35:13 AM
December 03, 2018, 08:40:43 AM
Jesjes
December 03, 2018, 05:31:29 AM
chjarup
December 02, 2018, 11:44:14 PM
post SSTC-Driver PCB 1.3
December 02, 2018, 10:25:23 PM
December 02, 2018, 04:23:16 PM
chjarup
December 02, 2018, 12:12:57 PM
December 02, 2018, 09:57:04 AM
