Author Topic: Theremin Interrupter  (Read 524 times)
« on: March 11, 2018, 06:07:14 PM »
Hello Tesla Fans,
Yesterday I got a wild hair and thought: wouldn't it be cool to control your Tesla coil with a Theremin?  Well, I designed an interrupter that I think should do just that.   It has two plates which are capacitively coupled to your hands.  One plate controls the pitch (or bps) of the DRSSTC, the other the volume or the length of the interrupter pulses.
I have included the schematic and the board I laid out to try it.  Here's how it works:
Each of the 74HC04 have a pair of oscillators on it.  One of the HC04's is for the pitch, the other for the volume.  One of the oscillators has its capacitor hooked up to a plate so that by moving your hand next to the plate, it changes the capacitance and therefore the oscillation frequency.  The other is adjusted so that when you hand is not near the plate, the frequency matches the other oscillator.  Using a XOR gate and a low-pass filter, the beat frequency between these two oscillators is derived.
For the volume, (HC04 U3), the beat frequency is converted to a voltage by converting the beat frequency to a series of pulses of a uniform length, and then low-pass filtering these pulses.
For the pitch, the beat frequency is used to derive a ramp signal that resets each time the cycle of the pitch beat frequency is low.  By using a comparator with the voltage derived from the volume, a pulse-width-modulated signal is derived to modulate the length of this pulse.
An analog output is also provided as well.   To do this, transistor Q2 is a voltage follower with its collector tied to the output of U2D.  When U2D is low, current flows through D10 and the capacitor C13 is discharged.  When U2D is high, the voltage follower limits the charging voltage of C13 to one diode drop below the voltage at C10 which is the volume-proportional voltage.  This is low pass filtered to get a sinusoidal-like signal.
Anyways, I'm still working on getting a DRSSTC up and going, hope to have it Theremin controlled! :)
Re: Theremin Interrupter
« Reply #1 on: March 11, 2018, 09:20:18 PM »
A little while ago I built the OpenTheremin v3 and it can be modified to output MIDI, which could then be fed to a DRSSTC without any problems.
I do believe that you should either sit in a faraday cage with your theremin or stay at a great distance to the coil, to avoid it ends up in some loop of the sparks interfering with the note generation.
« Reply #2 on: March 11, 2018, 10:31:02 PM »
It might be fine if the theremin tank circuit and DRSSTC tank circuit operate sufficiently far away from each other in frequency, and the broadband noise produced by the coil isn't too bad. I do like the idea!
« Reply #3 on: March 13, 2018, 01:56:34 PM »
Did you build your circuit? I tried to build several theremins and they all turned out to be just good noise synthesizers. Biggest problem was to tune them, which Gaudi solved well in openTheremin v3, using varicap diodes
Check his openTheremin page http://www.gaudi.ch/OpenTheremin/ It's excellent and you can really play something on it
Last year I tried what Mads suggested, modifying openTheremin for MIDI output and then feeding that to onetesla MIDI interrupter
At the time openTheremin MIDI firmware had some problems so it kinda worked, the whole setup was glitchy/lagging even without DRSSTC being powered on. Lagging was probably caused by the computer and next time I would try connecting openTheremin directly, which will need some mods on the openTheremin MIDI firmware. So at the end DRSSTC sounded pretty bad and I couldn't play anything recognizable :D
edit: I hope that I'll have some free time this month to finally play with the DRSSTC, I bought wire mesh for the faraday cage so I might revisit theremin interrupter :)
« Last Edit: March 13, 2018, 02:02:20 PM by futurist »
« Reply #4 on: March 14, 2018, 01:53:20 PM »
I know it's tricky to make a theremin stable, but others have done it, and I'm going to try it.  I put both of the oscillators, the variable and fixed oscillator, on the same chip 74HC04, so that hopefully the temperature drift of the two oscillators will cancel somewhat.  As for component values, that's a bit harder, because probably you have to use a capacitor with low temperature drift.  I am going to use plates rather than antennas initially because it's easier to get more capacitance variation that way, and they'll be placed close to the circuit mounted on the side of the enclosure.
Due to feature creep, I added a little bit so it could be a theremin by itself by putting on a simple amplifier chip, and corrected a few problems.
post Re: Drsstc 3
Today at 02:28:27 AM
Garyf
September 18, 2018, 05:51:35 PM
post Re: Theremin based on the stm32f103c8t6 and bluepill, stm32duino
September 18, 2018, 05:00:57 AM
September 17, 2018, 08:57:40 PM
September 17, 2018, 11:20:53 AM
post Re: Drsstc 3
September 17, 2018, 11:17:23 AM
post Re: mmc capacitor banks
September 17, 2018, 08:52:32 AM
aq62386238
September 16, 2018, 03:31:06 PM
post Re: Drsstc 3
September 16, 2018, 04:34:36 AM
post Theremin based on the stm32f103c8t6 and bluepill, stm32duino
September 15, 2018, 10:55:33 PM
post Re: Garden flag pole hit by lightning
September 14, 2018, 05:13:33 PM
September 14, 2018, 04:50:48 PM
OakleyC
September 14, 2018, 12:45:05 AM
September 13, 2018, 09:59:00 PM
September 13, 2018, 03:34:39 PM
post Garden flag pole hit by lightning
September 13, 2018, 02:35:00 PM
September 13, 2018, 08:59:50 AM
OakleyC
September 13, 2018, 02:09:09 AM
September 12, 2018, 04:16:38 PM
post Re: Drsstc 3
September 12, 2018, 12:21:48 PM
post mmc capacitor banks
OakleyC
September 12, 2018, 11:18:07 AM
September 12, 2018, 08:56:06 AM
September 12, 2018, 08:11:12 AM
Spuriosity_
September 12, 2018, 04:58:28 AM
September 10, 2018, 04:31:16 PM
September 10, 2018, 01:37:22 PM
post Re: new member seeking advice.
September 10, 2018, 01:36:14 PM
September 09, 2018, 07:59:44 PM
pentode
September 09, 2018, 09:09:22 AM
September 09, 2018, 08:42:36 AM
post Re: 160mm PLL sstc
September 09, 2018, 08:22:06 AM
post new member seeking advice.
shogun94
September 08, 2018, 12:57:25 AM
post Re: Non toroid top loads
Patric
September 05, 2018, 08:41:36 PM
post Chineese spark aways !
pentode
September 05, 2018, 02:30:21 PM
September 05, 2018, 01:43:24 PM
September 05, 2018, 01:42:16 PM
September 05, 2018, 01:35:07 PM
September 05, 2018, 12:36:22 PM
post Re: Drsstc 3
September 05, 2018, 12:31:49 PM
aq62386238
September 05, 2018, 11:59:20 AM
September 05, 2018, 11:52:36 AM
post Re: Drsstc 3
September 05, 2018, 10:08:06 AM
September 05, 2018, 08:36:25 AM
post Re: Drsstc 3
September 05, 2018, 05:44:25 AM
September 05, 2018, 05:33:32 AM
aq62386238
September 04, 2018, 04:47:33 PM
September 04, 2018, 01:51:22 PM
aq62386238
September 04, 2018, 01:38:46 PM
September 04, 2018, 12:07:06 PM
aq62386238
September 04, 2018, 10:51:43 AM
