Author Topic: Closed loop control of DC motor  (Read 803 times)
Offline kamelryttarn
« on: February 28, 2018, 09:41:26 AM »
A while ago I started a build of a simple (or so I thought) magnetic stir plate. I ordered a cheap motor on ebay and a friend helped me to 3d-print a holder for the neodymium magnets. I use and arduino with a mosfet to get speed control by PWM.
The problem was that the magnets locked on to the screws I used to mount the motor in the plastic case so it took quite a bit of force to get it to start so I thought I could use a closed loop to control the speed of the motor. I bought a new motor with a built in magnetic encoder that sends pulses when the motor spins. I wrote a small program for my arduino and connected the pulse output from the motor to one of the hardware interrupt pins. When I tried it I got very erratic behavior that I believe may be caused by the inertia of the rotating axel . Would you agree and do you have any good ideas what I can do to remedy the problem?
To understand the pictures better I will try to explain the code I used. Every time I got a change (either rising or falling edge) from the encoder, the mosfet channel is turned off and the arduino resumes the regular loop that has a pause time (to regulate speed) and the turns the mosfet on again. In the pictures channel 0 is the encoder on the motor and channel 1 is the mosfet driver. The last screenshot is from a test I did where i let the motor spin for a few seconds and the turned the mosfet off to see how long after the power was cut to the motor it still turned.
Today at 07:27:18 AM
Today at 07:02:44 AM
post Drsstc tank Cap testing
Today at 05:56:46 AM
Today at 12:03:47 AM
station240
July 13, 2020, 01:08:35 PM
July 13, 2020, 08:30:46 AM
post Re: Capacitors and arcs
Paradox
July 13, 2020, 01:59:09 AM
July 13, 2020, 01:20:59 AM
July 12, 2020, 05:06:10 AM
July 11, 2020, 10:23:24 PM
July 11, 2020, 09:36:02 PM
July 11, 2020, 07:36:23 PM
July 11, 2020, 04:45:18 PM
July 11, 2020, 01:26:41 PM
July 11, 2020, 07:53:04 AM
July 11, 2020, 06:37:03 AM
July 11, 2020, 04:18:29 AM
July 11, 2020, 01:35:07 AM
July 10, 2020, 11:35:05 PM
Morvandium
July 10, 2020, 11:10:57 PM
Morvandium
July 10, 2020, 11:06:07 PM
k42
July 10, 2020, 08:53:06 PM
July 10, 2020, 07:20:48 PM
Morvandium
July 10, 2020, 04:45:43 PM
July 10, 2020, 10:57:29 AM
July 10, 2020, 08:55:30 AM
July 10, 2020, 08:48:33 AM
July 10, 2020, 07:00:13 AM
July 10, 2020, 06:57:36 AM
July 10, 2020, 05:44:54 AM
July 09, 2020, 09:23:38 PM
July 09, 2020, 09:09:08 PM
July 09, 2020, 07:00:49 PM
July 09, 2020, 02:33:38 PM
July 09, 2020, 12:16:32 PM
July 09, 2020, 11:46:10 AM
July 09, 2020, 10:56:18 AM
July 09, 2020, 08:37:52 AM
July 09, 2020, 06:45:18 AM
July 09, 2020, 02:36:22 AM
July 08, 2020, 09:43:20 PM
Morvandium
July 08, 2020, 09:33:35 PM
July 08, 2020, 09:23:14 PM
July 08, 2020, 09:16:42 PM
July 08, 2020, 09:00:04 PM
July 08, 2020, 04:25:53 PM
July 08, 2020, 10:03:25 AM
July 08, 2020, 08:39:10 AM
July 08, 2020, 08:34:02 AM
July 08, 2020, 04:39:10 AM
