Author Topic: Ideas needed!  (Read 2356 times)
Ideas needed!
« on: February 25, 2018, 07:31:40 AM »
hi,
i recently picked up a decommissioned mig welder from a mate. he said for some reason the case and handle was missing but the internals are all still good. so it got me thinking.... what could i use these cores for? i'm thinking as an inductor for a boost converter?  being a mig welder it would just be a big step down transformer with most likely a 12-40v output at 80 amps.
Re: Ideas needed!
« Reply #1 on: February 25, 2018, 11:18:59 AM »
From the picture those cores look like laminated steel. If they are designed for 50/60Hz then you won't be able to run them at the higher frequencies used in a switchmode (e.g. buck or boost) converter without huge losses in the cores.
Someone might have other suggestions for use though.
Offline AndreiRS
Re: Ideas needed!
« Reply #2 on: February 25, 2018, 12:52:14 PM »
Well that's what he said. Works ok till only 400hz if I remember. Why not use it as a mig welder? ::)
Re: Ideas needed!
« Reply #3 on: February 26, 2018, 12:32:38 AM »
@Hydron
I didn't even think about that. I just saw a big core and got excited!
@AndreiRS
I don't think I could justify the parts cost to get it running again, as well as I have a few other welders.
Re: Ideas needed!
« Reply #4 on: February 26, 2018, 08:35:10 PM »
As you sit with 50 Hz parts it is hard to really reinvent it outside its original purpose.
One useful purpose, if you do not want a old welder, could be a spot welder for building prototype enclosure.
I actually also googled and found this from a welder manufacturer: https://www.everlastgenerators.com/blog/top-10-things-do-old-welder
Re: Ideas needed!
« Reply #5 on: February 27, 2018, 01:59:01 AM »
Haha mads... I think I could use number 5 as an option! I think I'll see how much current the transformation draws when connected to mains, if it's not a lot I might just use it as a power supply if I get into high power zvs drivers
Offline kamelryttarn
Re: Ideas needed!
« Reply #6 on: February 27, 2018, 09:48:28 AM »
Why not just convert it to a high current PSU? They can be very useful for driving induction circuits among other things. If it's a three phase transformer you would get a pretty low ripple voltage.
Re: Ideas needed!
« Reply #7 on: June 20, 2019, 05:13:57 PM »
You might be able to use it as a ballast for a SGTC HV transformer.
Re: Ideas needed!
Today at 08:14:58 AM
[Radioactive Sources]
Today at 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
post Re: New projet OmegaDR
Mugi30
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
June 01, 2020, 05:27:08 PM
post Neon transformer
Iyacht
June 01, 2020, 10:02:58 AM
June 01, 2020, 03:38:05 AM
June 01, 2020, 03:07:36 AM
May 31, 2020, 11:59:47 PM
erlendse
May 31, 2020, 11:05:19 PM
nix85
May 31, 2020, 11:03:45 PM
boxermick
May 31, 2020, 09:25:36 PM
May 31, 2020, 09:25:26 PM
nix85
May 31, 2020, 09:19:32 PM
May 31, 2020, 09:12:09 PM
May 31, 2020, 09:10:39 PM
nix85
May 31, 2020, 09:00:46 PM
May 31, 2020, 08:57:42 PM
nix85
May 31, 2020, 08:50:17 PM
May 31, 2020, 08:40:02 PM
nix85
May 31, 2020, 08:32:03 PM
May 31, 2020, 08:20:07 PM
May 31, 2020, 08:13:21 PM
nix85
May 31, 2020, 07:45:04 PM
nix85
May 31, 2020, 07:42:19 PM
May 31, 2020, 07:32:32 PM
May 31, 2020, 07:23:35 PM
