Author Topic: primary coil support  (Read 1312 times)
Offline DaiKen
« on: February 10, 2018, 08:20:05 PM »
Hi all,
In http://kaizerpowerelectronics.dk/tesla-coils/kaizer-drsstc-i/ Mads writes: 'I do not recommend anyone to make the same primary coil supports' and I have some trouble finding a working alternative.
Suggestions, advice & tips are very welcome.
Ton
Re: primary coil support
« Reply #1 on: February 11, 2018, 07:26:16 PM »
What I meant was the through-hole solution, because it is very hard work to get it screwed into position.
You can do almost exactly the same, but then saw down through the holes, just a little off centre so you get a little snap-in to hold the tubing in place, or you can also drill small holes behind the slots to fix the coil into position with a small piece of wire or so. Take a look at my DRSSTC4 f.ex.
But I do recommend make flat spiral primary coils for DRSSTCs, they provide plenty of coupling and gets further away from the topload.
Offline DaiKen
« Reply #2 on: February 11, 2018, 08:15:10 PM »
Hi Mads,
Thanks for your reply. That's just what I read, and looking at the pictures I can imaging the difficulties.
Making a flat spiral coil for a coil based on your DRSSTC1, can I use the same amount of windings?
« Reply #3 on: February 11, 2018, 10:24:31 PM »
You don't even need so many turns, as it will be tapped at a much lower number of turns, in the range of 5-6 turns in order to de-tune the primary below secondary resonant frequency.
On http://kaizerpowerelectronics.dk/calculators/spiral-coil-calculator/ I plotted these numbers and that seems to be a good enough solution for DRSSTC1, you can change the distance between turns if its getting too big, but too small also makes it harder to tune with a large tap connection.
Offline DaiKen
« Reply #4 on: February 12, 2018, 03:44:13 PM »
Thanks Mad!
Like it very much you took the effort to make this calculation!
Peregrine
Today at 10:40:58 AM
Today at 09:02:23 AM
Today at 08:58:38 AM
Today at 05:33:22 AM
Today at 05:08:28 AM
Irido
Today at 04:45:06 AM
Today at 02:44:42 AM
latethannever
Today at 01:58:48 AM
latethannever
kilovolt
post Re: 230 volts spark gap
Quentief
Quentief
[Hobby Sites]
kilovolt
kilovolt
pianomanjcb
February 13, 2020, 08:53:14 PM
post Re: Induction heater
Quentief
February 13, 2020, 02:24:54 PM
February 13, 2020, 10:53:32 AM
kilovolt
February 13, 2020, 08:53:43 AM
February 13, 2020, 05:44:24 AM
post Re: NST
February 13, 2020, 05:00:40 AM
post Re: NST
February 13, 2020, 03:57:38 AM
post Re: NST
February 13, 2020, 03:50:12 AM
pianomanjcb
February 13, 2020, 03:42:49 AM
February 13, 2020, 01:51:14 AM
post Re: NST
February 12, 2020, 05:56:29 PM
post 500 KW AM radio transmitter
February 12, 2020, 05:05:53 PM
February 12, 2020, 03:58:43 PM
post NST
February 12, 2020, 03:01:10 PM
February 12, 2020, 05:29:38 AM
post Re: Microwave Oven Transformer
February 12, 2020, 04:56:19 AM
