Author Topic: How To Varnish A Tesla Coil Secondary Coil  (Read 366 times)
« on: August 08, 2022, 09:47:24 PM »
This video shows your the method, tools and best of all, a few tricks to get a good Tesla Coil secondary coil varnish job done! This is something everyone can do, from a cheap battery drill to a expensive servo/stepper motor winding rig, its about the skill and not just expensive tools. You can do it!
I realized there is no general section for something that goes across topologies, so it ended up here for the coil I made it for :)
Offline TMaxElectronics
Re: How To Varnish A Tesla Coil Secondary Coil
« Reply #1 on: August 08, 2022, 10:01:56 PM »
I can really recommend using epoxy as opposed to varnish actually. I use Epoxyplast 100P which is designed for clear cast floors and I beleive can actually take a car driving over it. It takes a long time to cure (>24h!) or a heatgun firing through the center of the tube to cure faster (~8h). But it does so bubble free without needing de-gassing, and gets so hard you can hit the coil with a hammer without it taking damage (not kidding, I tried with an old one that I mis-wound with the wrong wire diameter). Mine has also survived some racing sparc incidents I had when I modified my inner primary connection and left a sharp edge on it :)
I tend to give it two or thee thin-ish coatings, after which you won't even feel the windings anymore. The only thing you need to make absolutely sure is that the coil doesn't stop moving during the curing process or else the resin will sag down to one side, even if its already dry to the touch on the surface. So instead of using a battery drill I use a mains powered one running nice and slowly from a variac.
I've attempted to test the dielectric breakdown strength of that stuff by embedding two electrodes exactly one mm apart from another. But I couldn't get it to break down even with 20kV across them for 5 minutes .
Offline Twospoons
« Reply #2 on: August 09, 2022, 12:22:26 AM »
Polyester resin is also worth considering, as it will gel well before full cure so sag is less of an issue.  You can control the cure rate by using more or less catalyst (within reason), unlike epoxy where proper cure depends on the proper ratio of hardener to resin. Polyester resin is usually cheaper too.
« Reply #3 on: August 09, 2022, 09:22:37 PM »
I need to experiment with epoxy before throwing it on a large coil and ruin it :)
I have used polyurethane because its cheap and easy to work with, very forgiving varnish.
This video also got featured on hackaday: https://hackaday.com/2022/08/09/junkbox-build-keeps-tesla-coils-perfectly-varnished/
post Re: IF D95T vs IF D95OC
Today at 06:56:51 AM
alexhanyuan
November 25, 2022, 11:28:15 PM
post Re: Induction cooker without electronics
Solhi
November 25, 2022, 12:05:50 PM
Solhi
November 25, 2022, 07:53:52 AM
Solhi
November 24, 2022, 08:08:48 AM
post Re: EEFL backlight circuits
November 24, 2022, 07:26:49 AM
post Re: Air cored inductors proximity to conductive objects
November 24, 2022, 03:02:11 AM
post Re: Solid State “rheostat” that will withstand high electrostatic fields
AkashaStar
November 24, 2022, 02:25:42 AM
Solhi
November 24, 2022, 01:45:33 AM
November 23, 2022, 11:27:18 PM
post Stepper motor drive without switching
November 23, 2022, 10:23:07 PM
November 23, 2022, 09:29:01 AM
post Re: Vacuum pump
Alberto
November 23, 2022, 08:45:37 AM
November 23, 2022, 04:44:20 AM
post Air cored inductors proximity to conductive objects
November 23, 2022, 01:10:17 AM
post Re: Post-Soviet Tesla Coil Teardown and Test
November 22, 2022, 08:40:19 PM
post Re: Ericsson RBS 6601 RRUS 12 analysis(kind of)
November 22, 2022, 08:22:09 PM
Kirby4life
November 22, 2022, 08:45:06 AM
post Ericsson RBS 6601 RRUS 12 analysis(kind of)
RickNitro
November 22, 2022, 08:36:11 AM
November 22, 2022, 06:42:31 AM
November 22, 2022, 06:40:32 AM
November 22, 2022, 04:53:40 AM
November 22, 2022, 02:17:08 AM
November 21, 2022, 11:03:04 PM
Alberto
November 21, 2022, 09:55:02 PM
Solhi
November 21, 2022, 03:09:26 PM
LoOdaK
November 21, 2022, 09:38:22 AM
post Re: Trichel pulses
November 20, 2022, 10:05:15 PM
post Trichel pulses
November 20, 2022, 09:48:37 PM
November 20, 2022, 07:17:36 PM
mthome4
November 20, 2022, 02:28:22 PM
post Post-Soviet Tesla Coil Teardown and Test
November 20, 2022, 02:03:49 PM
Solhi
November 20, 2022, 10:00:13 AM
post Re: TV flyback number of primary turns rule of thumb
November 20, 2022, 05:13:12 AM
post Re: Plasma Toroid
November 20, 2022, 05:08:31 AM
November 20, 2022, 01:27:00 AM
post Re: Basic Gate driving doubts
November 19, 2022, 10:12:14 PM
November 19, 2022, 09:57:35 PM
prabhatkumar
November 19, 2022, 09:50:23 PM
November 19, 2022, 08:26:45 PM
November 19, 2022, 06:53:17 PM
November 19, 2022, 06:05:47 PM
Alberto
November 19, 2022, 05:34:46 PM
Solhi
November 19, 2022, 02:30:04 PM
AkashaStar
November 19, 2022, 01:56:10 PM
post Re: Buck converter question
dru
November 19, 2022, 08:03:56 AM
Solhi
November 19, 2022, 06:38:00 AM
post Basic Gate driving doubts
prabhatkumar
November 19, 2022, 05:37:09 AM
post Re: ZVS driver won't oscillate
November 19, 2022, 03:59:56 AM
post Re: Non-laser pointer
November 19, 2022, 03:56:32 AM
November 19, 2022, 03:36:20 AM
November 19, 2022, 03:26:48 AM
Alberto
November 19, 2022, 12:40:33 AM
November 18, 2022, 09:32:33 PM
November 18, 2022, 05:48:00 PM
post Re: Audio Modulated CRT Flyback Transformer Loud Sparks
November 18, 2022, 03:49:12 PM
November 18, 2022, 02:56:49 PM
post IF D95T vs IF D95OC
November 18, 2022, 01:44:38 PM
Solhi
November 18, 2022, 11:38:44 AM
post Non-laser pointer
November 18, 2022, 10:05:29 AM
November 18, 2022, 06:54:55 AM
November 18, 2022, 06:29:23 AM
post Buck converter question
dru
November 18, 2022, 06:10:52 AM
November 18, 2022, 05:53:15 AM
Solhi
November 18, 2022, 05:21:52 AM
November 18, 2022, 04:00:04 AM
November 17, 2022, 10:24:35 PM
November 17, 2022, 08:30:00 PM
November 17, 2022, 07:28:16 PM
November 17, 2022, 03:38:00 PM
November 17, 2022, 04:03:51 AM
post Re: what type of diode is better for make high voltage diode?
November 17, 2022, 03:57:40 AM
November 17, 2022, 03:26:32 AM
November 16, 2022, 11:23:37 PM
November 16, 2022, 08:00:54 PM
November 16, 2022, 05:09:00 PM
November 16, 2022, 04:57:27 PM
post TV flyback number of primary turns rule of thumb
November 16, 2022, 03:27:06 PM
November 16, 2022, 03:16:13 PM
post Bluetooth to aux for plasma speaker circuits
November 16, 2022, 03:00:54 PM
Solhi
November 16, 2022, 11:43:49 AM
post Re: Electrical resistance cooking
November 16, 2022, 09:00:46 AM
November 16, 2022, 08:53:42 AM
November 16, 2022, 05:45:24 AM
November 15, 2022, 08:17:46 PM
Alberto
November 15, 2022, 07:25:04 PM
post Re: Yet another UD2.x pulse skipper
November 14, 2022, 12:26:19 PM
November 14, 2022, 04:57:41 AM
November 14, 2022, 12:32:54 AM
post Vacuum pump
Alberto
November 13, 2022, 11:06:55 PM
November 13, 2022, 06:32:11 PM
November 13, 2022, 04:41:20 PM
post Re: QCW questions
November 13, 2022, 02:38:41 PM
November 13, 2022, 05:23:09 AM
thedark
November 12, 2022, 10:39:21 PM
November 12, 2022, 12:45:16 PM
November 12, 2022, 05:44:35 AM
thedark
November 12, 2022, 05:30:10 AM
November 12, 2022, 01:11:31 AM
November 12, 2022, 12:42:54 AM
