Author Topic: Building the OpenTheremin V3  (Read 1664 times)
« on: January 10, 2018, 11:18:42 AM »
I received a bare board and some of the SMD components for a OpenThereminV3, it is a semi-assembled kit that can be bought from Gaudi ( http://www.gaudi.ch/OpenTheremin/index.php?option=com_content&view=article&id=180&Itemid=115 ). The board I got was from a previous unsoldered kit where you have to buy all the components yourself. This totalled to another 35€ in parts as I do not have much SMD components in stock.
It is made as a shield that mounts directly on a Arduino Uno, which also makes the programmering very easy. Plug in USB, download source code from github, download the source to the controller and start playing on your new theremin!
The whole building process is very easy from just looking at the parts list and the schematic when you are in doubt, the silk screen layout is almost good enough to just use that along with parts list to solder it up correctly.
I made a video of the soldering and building process with a bit of testing it at the end
Here is some more detailed photos of the enclosure, antennas and boards inside. Starting with the Open Theremin V3 board where it is all soldered up and I am fairly satisfied with the result as I just used my regular soldering iron used for DIP components and a very thin solder.
The Arduino Uno board mounts directly on top of it and fits nicely inside of the enclosure.
I used 4 different colour knobs for the potentiometers so it was easier to remember which is volume, pitch, register and timbre, as I did not have anything in mind to use as a front with texts on.
The antennas is all done by hand and bend around a wine bottle, easily done and the result is absolutely perfect!
I did a quick test setup where it was just connected to a tube amplifier I have in my lab, in the future I will try to modify it for MIDI output which there is a separate guide on ( http://www.gaudi.ch/OpenTheremin/index.php?option=com_content&view=article&id=200&Itemid=121 )
Re: Building the OpenTheremin V3
« Reply #1 on: January 11, 2018, 12:00:07 AM »
I watched this last night with my girlfriend, she says your voice is relaxing to listen to.
 The snapping of your fingers than the parts appearing was pretty cool, all the small things you keep adding to your videos make a big difference.
« Reply #2 on: January 13, 2018, 07:50:32 AM »
I hope it is not too relaxing, as hearing about technical stuff in a relaxing voice might just lull you to sleep :)
I do not have a set things of "effects" or particular scenes that I use in every video, but I do try to add something different in each video so that I do not end up with hundreds of perfectly aligned edited videos.
Feedback on how to increase the perceived "production value" is always welcome! I am beginning to see a staple view count on my channel and do of cause want to expand that.
« Reply #3 on: January 13, 2018, 02:56:15 PM »
Nice build and nicely explained! I'm glad it worked on the first try
In gaudi's kit you also receive adapter for camera stand, I was thinking about making 3D printed adapter for microphone stand which is much cheaper
"and now i will give it to my daughter and enjoy the extra background noise in my life" :D
Offline Amessiah
« Reply #4 on: March 19, 2020, 05:56:48 PM »
This really great device. I want one too. But unfortunately can't find components list for v3 board. Do you have list of all components you used in your project? I know it's kinda long time past. Anyway I will be really appreciate if you able to help me with it. Thanks
« Reply #5 on: March 19, 2020, 08:03:08 PM »
I could not find the BOM either, as it is not mentioned specifically anywhere.
But it is in the github, look for the file "BOMOpenThereminV3.ods" here: https://github.com/GaudiLabs/OpenTheremin_V3_Shield/tree/master/PCB
Offline Amessiah
« Reply #6 on: March 19, 2020, 08:25:18 PM »
Indeed! Thanks for your time.
Today at 08:14:58 AM
[Radioactive Sources]
Today at 06:30:09 AM
post Re: Datasheet Question
June 03, 2020, 08:01:53 PM
June 03, 2020, 03:04:11 PM
June 03, 2020, 02:54:04 PM
June 03, 2020, 02:27:26 PM
June 03, 2020, 02:19:32 PM
June 03, 2020, 02:10:57 PM
arctichominid
June 03, 2020, 02:10:18 PM
June 03, 2020, 12:27:06 PM
post Datasheet Question
June 03, 2020, 08:10:27 AM
June 03, 2020, 07:57:48 AM
June 03, 2020, 07:01:44 AM
June 03, 2020, 01:01:25 AM
June 03, 2020, 12:50:28 AM
June 03, 2020, 12:35:11 AM
09d08
June 03, 2020, 12:22:31 AM
June 02, 2020, 09:25:51 PM
09d08
June 02, 2020, 03:58:49 PM
June 02, 2020, 06:50:52 AM
TheMaxii2007
June 02, 2020, 05:52:14 AM
June 02, 2020, 04:53:24 AM
TheMaxii2007
June 02, 2020, 04:19:02 AM
post Re: Neon transformer
June 01, 2020, 11:55:28 PM
June 01, 2020, 08:34:10 PM
June 01, 2020, 07:58:20 PM
June 01, 2020, 05:50:47 PM
June 01, 2020, 05:27:08 PM
post Neon transformer
Iyacht
June 01, 2020, 10:02:58 AM
June 01, 2020, 03:38:05 AM
June 01, 2020, 03:07:36 AM
May 31, 2020, 11:59:47 PM
erlendse
May 31, 2020, 11:05:19 PM
May 31, 2020, 11:03:45 PM
boxermick
May 31, 2020, 09:25:36 PM
May 31, 2020, 09:25:26 PM
May 31, 2020, 09:19:32 PM
May 31, 2020, 09:12:09 PM
May 31, 2020, 09:10:39 PM
May 31, 2020, 09:00:46 PM
May 31, 2020, 08:57:42 PM
May 31, 2020, 08:50:17 PM
May 31, 2020, 08:40:02 PM
May 31, 2020, 08:32:03 PM
May 31, 2020, 08:20:07 PM
May 31, 2020, 08:13:21 PM
May 31, 2020, 07:45:04 PM
May 31, 2020, 07:42:19 PM
May 31, 2020, 07:32:32 PM
May 31, 2020, 07:23:35 PM
