Author Topic: sstc drive method  (Read 1128 times)
sstc drive method
« on: January 04, 2018, 03:52:45 AM »
hey,
every now and then when i run my "big" sstc and occasionally blow some igbts, other times it works flawlessly. the problem is the breakout point and antenna needs to be positioned perfectly or else i start to have drive issues, essentially cutting out.
so it got me thinking.... would it just be better to convert it to a pll driver and still interrupt it using the enable pins of the ucc3732x drivers.
any help is highly appreciated.
cheers.
Offline Laci
Re: sstc drive method
« Reply #1 on: January 04, 2018, 09:31:19 AM »
I have a PLL driver circuit and it works great with my coil.The best thing about it in my opinion is that it can be audio modulated easily and makes great sounding CW arcs.This is the schematic: https://cdn.instructables.com/FXU/AK63/GRFN8J90/FXUAK63GRFN8J90.LARGE.gif
The IGBTs die due to overcurrent?I had the same problem with MOSFETs,but the problem was not the driving circuit,instead the long mains rectified power cable to the bridge.
« Reply #2 on: January 08, 2018, 06:07:22 AM »
Cheers for the reply Laci. I messed around with a pll circuit but it had troubles staying in tune for some reason. I ended up making a circuit (nothing new about the design) that I'll post up. It's basically Steve wards sstc 5 driver, the design with a 555 to start the oscillation.
Offline Laci
« Reply #3 on: January 08, 2018, 11:42:13 AM »
I am currently using the Kaizer SSTC I driver circuit and no need to start the oscillations.Maybe try a secondary base CT as feedback.
« Reply #4 on: January 08, 2018, 04:27:19 PM »
I am not sure that a PLL controlled driver would like to be cut on and off like that, I do not know, I never made a PLL controlled coil. But it needs a few cycles to lock on the frequency, so maybe it could get bad, hopefully someone knows better?
I also had stuttering behaviour on the SSTC when spark length became too long, like it can be seen in this video from 0:50
« Reply #5 on: January 10, 2018, 01:36:32 AM »
I've noticed your sstc ii had a metal enclosure, was it grounded?  My idea was to have the new driver enclosed for more reliable operation.
Laci, tbh I'm not sure why the driver is cutting out. I've tried both antenna and secondary CT feedback. I think it's due to emf or something along those lines.... But that's a big guess on my behalf
« Reply #6 on: January 10, 2018, 08:21:06 AM »
Yes the shielding was grounded and that is crucial! It is a strong EMF to be in for this little driver, when I did the audio modulation, I also had to shield the cable to the driver enclosure and all the way to keyboard, but even then it would still lock up from time to time.
The only thing getting outside the enclosure is the antenna and GDT wires.
post Re: My First DRSSTC
sjsimmo
Today at 08:08:58 AM
post Re: How to calculate VA rating and other things for Ferrite Core? (SMPS)
[Transformer (ferrite core)]
sjsimmo
Today at 01:24:15 AM
post How to calculate VA rating and other things for Ferrite Core? (SMPS)
FilipŠebík
January 18, 2019, 07:32:38 PM
post Re: How to design a 7.5kV AC source?
January 18, 2019, 04:25:14 PM
post How to design a 7.5kV AC source?
CristianM
January 18, 2019, 03:48:06 PM
[Electronic circuits]
the_anomaly
January 17, 2019, 02:01:36 AM
January 16, 2019, 04:26:38 AM
post AC vs DC fuses, high current, explosive destructive testing and theory
[Capacitor banks]
January 15, 2019, 09:48:48 PM
neukyhm
January 15, 2019, 10:51:46 AM
January 14, 2019, 05:08:38 PM
the_anomaly
January 14, 2019, 01:15:53 PM
January 14, 2019, 12:22:07 PM
January 11, 2019, 05:10:39 AM
January 10, 2019, 10:59:25 PM
post Re: 迎词、来
[General chatting]
January 10, 2019, 06:56:59 PM
January 10, 2019, 05:33:48 PM
[General chatting]
black.yang
January 10, 2019, 02:11:58 AM
January 09, 2019, 09:14:59 PM
post Acoustic spectra of sung vowels by the FFT analyzer HP 3561A
Physikfan
January 08, 2019, 08:44:16 PM
post Re: IGBT failure in DRSSTC
Felix Bieri
January 08, 2019, 05:33:55 PM
post Re: Huawei RRU3928 1800MHz radio base station teardown (part 1 of 2)
[Radio frequency]
January 08, 2019, 08:25:08 AM
post Re: SimpleDriver v2.3, my phase-shifting QCW DRSSTC controller
January 08, 2019, 08:25:02 AM
January 08, 2019, 02:01:50 AM
post Re: (DR)SSTC II
January 07, 2019, 10:23:38 PM
Laci
January 07, 2019, 08:53:32 PM
January 07, 2019, 08:17:44 PM
January 07, 2019, 07:37:53 PM
January 07, 2019, 01:30:36 PM
Laci
January 07, 2019, 12:43:26 PM
January 07, 2019, 08:09:49 AM
NEYi
January 07, 2019, 07:43:50 AM
[General chatting]
January 07, 2019, 06:48:06 AM
January 07, 2019, 06:39:56 AM
Laci
January 06, 2019, 09:23:19 PM
January 06, 2019, 07:11:25 PM
January 06, 2019, 07:02:14 PM
January 06, 2019, 12:43:46 PM
Laci
January 06, 2019, 11:55:09 AM
TDAF
January 06, 2019, 09:48:06 AM
post Re: First SSTC build, need help troubleshooting
[Solid state Tesla coils]
TDAF
January 06, 2019, 09:45:17 AM
post 关于: 这个便宜的 drsstc 驱动程序从 aliexpress 1.3 b 类型?
black.yang
January 06, 2019, 08:34:46 AM
post 迎词、来
[General chatting]
black.yang
January 06, 2019, 08:20:21 AM
flyrod
January 06, 2019, 12:34:15 AM
January 05, 2019, 05:27:23 PM
flyrod
January 05, 2019, 03:46:29 PM
Laci
January 05, 2019, 09:51:10 AM
January 04, 2019, 11:02:25 PM
Laci
January 03, 2019, 08:38:15 PM
January 03, 2019, 08:15:48 PM
post Re: Component questions
January 03, 2019, 02:05:31 PM
