Author Topic: Nice PC Board Tesla  (Read 868 times)
Offline alan sailer
Nice PC Board Tesla
« on: June 10, 2021, 07:46:12 PM »
I have run across several printed circuit secondary tesla coils on the web and this is the first that I found impressive.
https://circuitsalad.com/2021/05/30/high-output-pcb-spiral-tesla-coil/
And for all those builders bragging about their primary height to spark length ratios, this one has a ratio of about 6,000x :-)
Cheers.
Re: Nice PC Board Tesla
« Reply #1 on: June 11, 2021, 12:03:24 PM »
That's really impressive output :D
Got me interested in trying building it
Offline Da_Stier
« Reply #2 on: June 11, 2021, 12:33:55 PM »
Looks impressive indeed.
I find it interesting, how a standard PCB handles the isolation of the secondary voltage.
Would be interesting to see if this performance can be achieved for a long time or only for short pulses, before the PCB fails.
EDIT:
I saw the video and therefore also the Epoxy layer on top of the PCB.
However I still find it interesting how the 6 mil spacing between the windings is enough to prevent arcing on the copper layer.  :o
« Last Edit: June 11, 2021, 09:04:21 PM by Da_Stier »
« Reply #3 on: June 12, 2021, 04:20:53 AM »
He trusts his test equipment, using a stack of three instruments as the ground target for sparks.
With an ECB secondary, it would be possible to adjust winding spacing vs. radius.  Outer turns have higher volts/turn, so could be spaced a bit farther apart.
Offline Twospoons
« Reply #4 on: June 12, 2021, 08:47:08 AM »
Based on some work I did with pcb coils for Qi chargers, he could improve the primary by splitting it into many thin parallel tracks - but they would need to be "twisted" 180 degrees half way around the loop in order to balance the impedances of the individual tracks so they share current better. This would entail vias and short tracks on the secondary side in order to create the swap over, but a liberal epoxy coat should protect them.
With a single wide track the current tends to flow at the edges - and may even flow backwards along one edge under some conditions, which just wastes power. Based on my simulations in Ansys Maxwell.
Offline Da_Stier
« Reply #5 on: June 12, 2021, 10:06:18 AM »
I would have sweated blood if it was my equipment, I'm always totally paranoid about something being damaged from my coil.
Greetings,
Michael
Offline Duane B
    • Roaring 20s Superhets
« Reply #6 on: September 03, 2021, 07:39:08 PM »
Yes, sweet Tesla coil! Even with the epoxy coating, I'm surprised it does not produce corona discharges from the low-voltage components towards the resonator.
Duane Bylund
post Re: QCW questions
Today at 03:15:18 AM
January 26, 2022, 07:26:22 PM
post Re: General Questions
January 26, 2022, 03:46:58 PM
post QCW questions
January 26, 2022, 10:49:14 AM
January 26, 2022, 05:17:03 AM
post Re: Mixing PID loops
January 26, 2022, 04:14:02 AM
January 25, 2022, 09:50:41 PM
post Re: Self Starting Coil (Not)
January 25, 2022, 03:52:42 PM
January 25, 2022, 01:48:02 PM
post Re: GDT Slow Rise/Fall times even with resistor shorted
January 25, 2022, 04:48:06 AM
January 25, 2022, 04:37:32 AM
SalinsLV
January 24, 2022, 08:42:57 PM
January 24, 2022, 03:55:07 PM
January 24, 2022, 12:00:50 PM
post Re: Hi! 811 A tesa coil
304er
January 24, 2022, 09:05:40 AM
post Mixing PID loops
January 24, 2022, 07:28:01 AM
jpvvv123
January 24, 2022, 04:13:06 AM
January 24, 2022, 03:34:15 AM
post Self Starting Coil (Not)
January 23, 2022, 10:45:46 PM
January 23, 2022, 09:06:49 PM
post GDT Slow Rise/Fall times even with resistor shorted
SalinsLV
January 23, 2022, 07:18:56 PM
304er
January 23, 2022, 06:18:13 PM
post Re: 120VAC Mains Ramped Builds
January 22, 2022, 11:20:55 AM
January 22, 2022, 07:07:09 AM
post Re: GDT Testing
January 22, 2022, 05:27:37 AM
January 22, 2022, 04:27:38 AM
jpvvv123
January 22, 2022, 12:53:04 AM
January 21, 2022, 07:36:07 PM
post Re: Muon Decay
January 21, 2022, 07:27:23 PM
January 21, 2022, 02:05:52 PM
January 21, 2022, 09:08:18 AM
post Re: Muon Decay
January 21, 2022, 08:42:54 AM
January 21, 2022, 03:00:04 AM
post Re: Muon Decay
January 21, 2022, 02:16:57 AM
January 20, 2022, 06:56:35 PM
post Re: Muon Decay
January 20, 2022, 05:19:26 PM
post Re: Muon Decay
January 20, 2022, 03:53:54 PM
post Re: Muon Decay
January 20, 2022, 01:20:19 PM
post Re: Muon Decay
January 20, 2022, 10:11:21 AM
post Re: Muon Decay
January 19, 2022, 08:22:49 PM
post Re: Muon Decay
January 19, 2022, 06:49:36 PM
hardboiled99
January 19, 2022, 07:37:27 AM
January 18, 2022, 10:34:48 PM
post Re: Muon Decay
January 18, 2022, 08:46:53 PM
post Re: Muon Decay
January 18, 2022, 08:08:53 PM
January 18, 2022, 07:15:22 PM
post Muon Decay
January 18, 2022, 06:49:48 PM
304er
January 18, 2022, 08:47:53 AM
January 17, 2022, 09:13:32 PM
January 17, 2022, 09:05:56 PM
January 17, 2022, 07:45:48 PM
January 17, 2022, 07:41:34 PM
January 17, 2022, 07:38:25 PM
January 17, 2022, 07:31:03 PM
January 17, 2022, 07:28:02 PM
January 16, 2022, 09:00:02 PM
January 16, 2022, 07:35:26 PM
Bambinz
January 16, 2022, 12:21:40 PM
January 15, 2022, 07:10:03 PM
Bambinz
January 15, 2022, 06:31:33 PM
January 14, 2022, 08:47:43 PM
January 14, 2022, 08:39:07 PM
January 14, 2022, 08:14:17 PM
January 14, 2022, 08:12:13 PM
January 14, 2022, 05:51:52 PM
304er
January 14, 2022, 08:51:57 AM
Bambinz
January 13, 2022, 08:20:02 PM
January 13, 2022, 05:27:40 AM
January 13, 2022, 03:10:32 AM
304er
January 12, 2022, 06:18:15 PM
January 12, 2022, 05:45:26 PM
January 12, 2022, 03:29:04 PM
January 12, 2022, 01:30:38 PM
304er
January 12, 2022, 09:09:13 AM
January 11, 2022, 08:05:27 PM
January 11, 2022, 07:42:12 PM
January 11, 2022, 07:33:15 PM
January 11, 2022, 06:19:49 PM
304er
January 11, 2022, 05:19:46 PM
January 11, 2022, 04:31:28 PM
January 11, 2022, 03:21:37 PM
January 11, 2022, 06:50:49 AM
January 11, 2022, 06:34:20 AM
January 11, 2022, 06:24:13 AM
January 11, 2022, 06:15:08 AM
January 11, 2022, 05:25:31 AM
January 11, 2022, 12:07:22 AM
January 10, 2022, 10:56:48 PM
January 10, 2022, 09:38:53 PM
January 10, 2022, 07:50:13 PM
January 10, 2022, 07:19:17 PM
January 10, 2022, 03:13:08 PM
January 10, 2022, 04:21:46 AM
304er
January 10, 2022, 03:59:09 AM
January 10, 2022, 03:54:59 AM
January 09, 2022, 11:45:09 PM
jpvvv123
January 09, 2022, 11:04:25 PM
January 09, 2022, 04:22:11 PM
January 09, 2022, 05:52:11 AM
January 09, 2022, 05:10:50 AM
