Author Topic: My first VTTM (Vaccum tube tesla magnifier) WIP  (Read 255 times)
Offline kaboooom2000uk
  • Oi oi
« on: April 30, 2021, 09:34:11 AM »
Hello Ladies and Gentlemen, I present my VTTM which I believe may be a first as I haven't seen any circulating the internet, seen plenty of classic spark gap derived machines, but none where they employ a tube oscillator. Mine uses a little 830B tube which seems to perform well and provides about 6" arcs.
here I use a simple schematic from an induction heater but I have modified the work coil to work at the same Fres as my secondary (which I established using the signal generator and scope method as I find it simpler to do this) and built it using parts around the shack. As you can see the circuit itself is very simple. Only real changes I made to it are making both the feedback and the primary resonant at the same freq as the resonator coil
Basic setup, but instead of spark gap I am driving it with an oscillator.
In my version I use a tightly coupled "driver" coil made from about 100 turns of litz wire wound on a borosilicate glass lantern chimney, which serves as a former, the primary is about 20 or so turns of thicker litz wire I made using some magnet wire and a drill which sits on its own former.
The feedback winding is about 5 turns of more litz wire. I wound that on a acrylic tube which sits over the other coils for simple removal and modification.
Power input was conceived using a pair of 650-115 transformers, I hooked them up backwards, to step up and the 115V windings were wired in series and fed with my 8A 240V variac. so I had about 1400V or so to play with at about 1KVA which is the limit of the transformers. This AC is then fed into a simple level shifter composed of a dual diode package and a 220uf 2500V capacitor, and 4700pf ceramic decoupler cap.
From the footage I took it appears to be working, I would say this because it appears the input voltage to the resonating coil is very low but then gains voltage the further up the coil I go.
I hope to get some more refinements done on this at some point but its been put on the hiatus while I play with solid state stuff. Namely my half-bridge universal driver.
« Last Edit: April 30, 2021, 09:39:05 AM by kaboooom2000uk »
Rapy2
Today at 01:06:02 AM
Today at 12:44:31 AM
Rapy2
Today at 12:41:33 AM
Rapy2
Today at 12:11:13 AM
June 13, 2021, 11:52:11 PM
Rapy2
June 13, 2021, 11:38:44 PM
Rapy2
June 13, 2021, 10:26:51 PM
June 13, 2021, 09:57:56 PM
Rapy2
June 13, 2021, 09:29:08 PM
June 13, 2021, 08:53:25 PM
Rapy2
June 13, 2021, 07:22:05 PM
June 13, 2021, 07:02:28 PM
June 13, 2021, 06:25:20 PM
Rapy2
June 13, 2021, 02:48:59 PM
gianpaolo
June 13, 2021, 12:00:09 PM
June 12, 2021, 07:28:03 PM
June 12, 2021, 07:23:12 PM
June 12, 2021, 12:24:06 PM
post Re: Nice PC Board Tesla
June 12, 2021, 10:06:18 AM
June 12, 2021, 10:01:29 AM
June 12, 2021, 08:47:08 AM
June 12, 2021, 07:03:10 AM
PEDRO HENRIQUE
June 12, 2021, 06:42:56 AM
June 12, 2021, 04:20:53 AM
post Re: SKM100 Mini DRSSTC
Willsmith001
June 11, 2021, 11:08:24 PM
post Re: How much propagation delay is too much propagation delay
Willsmith001
June 11, 2021, 11:07:00 PM
June 11, 2021, 12:33:55 PM
June 11, 2021, 12:03:24 PM
June 11, 2021, 06:47:52 AM
Power-Max
June 11, 2021, 06:32:02 AM
June 11, 2021, 05:16:03 AM
June 11, 2021, 04:53:50 AM
post Re: Why are SGT50T65FD1PN soo cheap on lcsc?
June 10, 2021, 11:51:17 PM
June 10, 2021, 09:52:59 PM
June 10, 2021, 09:16:25 PM
June 10, 2021, 08:19:40 PM
post Fujifilm PMT module PMT12A, reverse engineering
June 10, 2021, 08:05:27 PM
post Nice PC Board Tesla
June 10, 2021, 07:46:12 PM
post Re: Is it possible to go fully CW with a DRSSRC?
June 10, 2021, 06:31:40 PM
June 10, 2021, 02:12:07 PM
June 10, 2021, 05:14:41 AM
post How much propagation delay is too much propagation delay
Power-Max
June 10, 2021, 05:10:24 AM
Power-Max
June 10, 2021, 04:50:34 AM
June 10, 2021, 01:36:31 AM
June 09, 2021, 09:15:22 PM
Power-Max
June 09, 2021, 08:02:15 PM
PEDRO HENRIQUE
June 09, 2021, 07:17:27 PM
June 09, 2021, 06:58:33 PM
post Aisler PCB Manufacturer
June 09, 2021, 06:58:12 PM
post [WTS] (US) Large Ferrite U and E Cores, assorted types
June 09, 2021, 05:44:06 PM
