Author Topic: Mains synced sstc questions  (Read 327 times)
Offline costas_p
« on: April 14, 2021, 05:00:12 PM »
Hello to HVF community, I am looking to build a mains synced sstc (here in Greece 230v 50Hz).
I am considering using Kaizer VTTC staccato controller as the AC pulse sensing, so a have some questions:
~ The output that goes into SCR/transistor/mosfet, can it be used in enable pin 3 on UCC3732x drivers? Should I omit R18 (100k) resistor?
~ I am planning to use an ac to dc 12v wall plug adapter for the logic, and a tiny VA rated  230:12v transformer in order to drive the Q1 (2n2222), so R3 resistor and Q1 emitter should be
   connected to the wall plug's dc negative side, or the neutral side of the small transformer? Or maybe for that to work, neutral side of transformer secondary and logic ground should
   be one?
Papadakis Costas
Re: Mains synced sstc questions
« Reply #1 on: April 14, 2021, 07:35:25 PM »
You need to have a common ground for it all, else there is no reference between AC to DC side through 2N2222, I can at least not tell you what would happen.
Grounding all power supplies negative and one leg of the secondary side of a isolation transformer is known as PELV ( https://en.wikipedia.org/wiki/Extra-low_voltage#/media/File:Extra_low_voltages_(third_safety_class).JPG ) and that is best practice for electrical safety.
R18 could properly be omitted, you do not need current limiting for driving the UCC gate driver IC.
Offline dexter
« Reply #2 on: April 15, 2021, 10:48:12 PM »
Hi. Here is my take on mains synced sstc using the same staccato circuit but with a few improvements :)
I used a single power supply (mains transformer) for both the zero cross detection and to power the controller. To do so you'll need to add a diode in series with the bridge rectifier (note 1)
This circuit will utilize both peaks of the mains sinewave giving you up to a max 100 bps
The phase control pot (Power) when turned to max will either never reach the max 10ms time or will exceed it clipping on the next period resulting in a noticeable drop in BPS. To fix this choose the timing R C a bit over 10ms but add a trimmer in parallel with the pot (note 2)
Edit 1. sorry for the messed up schematic :) but is the same as Kaizer VTTC staccato
controller
Edit 2. my profile pic is this mains synced sstc running at 100 bps and max power (10ms)
« Last Edit: April 15, 2021, 10:54:37 PM by dexter »
Offline Magneticitist
« Reply #3 on: April 18, 2021, 02:36:34 AM »
SciTubeHD's ramped PLL SSTC. He has his staccato output going to the enable pins. Beautifully simplistic overall circuit and results.
Today at 12:44:31 AM
Rapy2
Today at 12:41:33 AM
Rapy2
Today at 12:11:13 AM
June 13, 2021, 11:52:11 PM
Rapy2
June 13, 2021, 11:38:44 PM
Rapy2
June 13, 2021, 10:26:51 PM
June 13, 2021, 09:57:56 PM
Rapy2
June 13, 2021, 09:29:08 PM
June 13, 2021, 08:53:25 PM
Rapy2
June 13, 2021, 07:22:05 PM
June 13, 2021, 07:02:28 PM
June 13, 2021, 06:25:20 PM
Rapy2
June 13, 2021, 02:48:59 PM
gianpaolo
June 13, 2021, 12:00:09 PM
June 12, 2021, 07:28:03 PM
June 12, 2021, 07:23:12 PM
June 12, 2021, 12:24:06 PM
post Re: Nice PC Board Tesla
June 12, 2021, 10:06:18 AM
June 12, 2021, 10:01:29 AM
June 12, 2021, 08:47:08 AM
June 12, 2021, 07:03:10 AM
PEDRO HENRIQUE
June 12, 2021, 06:42:56 AM
June 12, 2021, 04:20:53 AM
post Re: SKM100 Mini DRSSTC
Willsmith001
June 11, 2021, 11:08:24 PM
post Re: How much propagation delay is too much propagation delay
Willsmith001
June 11, 2021, 11:07:00 PM
June 11, 2021, 12:33:55 PM
June 11, 2021, 12:03:24 PM
June 11, 2021, 06:47:52 AM
Power-Max
June 11, 2021, 06:32:02 AM
June 11, 2021, 05:16:03 AM
June 11, 2021, 04:53:50 AM
post Re: Why are SGT50T65FD1PN soo cheap on lcsc?
June 10, 2021, 11:51:17 PM
June 10, 2021, 09:52:59 PM
June 10, 2021, 09:16:25 PM
June 10, 2021, 08:19:40 PM
post Fujifilm PMT module PMT12A, reverse engineering
June 10, 2021, 08:05:27 PM
post Nice PC Board Tesla
June 10, 2021, 07:46:12 PM
post Re: Is it possible to go fully CW with a DRSSRC?
June 10, 2021, 06:31:40 PM
June 10, 2021, 02:12:07 PM
June 10, 2021, 05:14:41 AM
post How much propagation delay is too much propagation delay
Power-Max
June 10, 2021, 05:10:24 AM
Power-Max
June 10, 2021, 04:50:34 AM
June 10, 2021, 01:36:31 AM
June 09, 2021, 09:15:22 PM
Power-Max
June 09, 2021, 08:02:15 PM
PEDRO HENRIQUE
June 09, 2021, 07:17:27 PM
June 09, 2021, 06:58:33 PM
post Aisler PCB Manufacturer
June 09, 2021, 06:58:12 PM
post [WTS] (US) Large Ferrite U and E Cores, assorted types
June 09, 2021, 05:44:06 PM
June 09, 2021, 02:35:47 PM
