Author Topic: measure the secondary voltage of a tesla coil.  (Read 120 times)
Offline paulj
« on: February 22, 2021, 11:03:51 PM »
Good evening, I was wondering if with the minimum of material, we could measure the voltage of the secondary tesla coil?
I contacted another forum which suggested that I try first with a small model, a capacitive divider, and an oscilloscope, it's just to measured a peak only.
Regards, Paul
Online davekni
Re: measure the secondary voltage of a tesla coil.
« Reply #1 on: February 23, 2021, 01:07:46 AM »
Tesla coil voltage measurement is a fun challenge, but not at all easy to get accurate.  A capacitive divider can work until arcs form.  Once arcs form, capacitance from the arc changes the divide ratio.  If the sensing is on the opposite side from a breakout point, it might remain somewhat close.
My preferred approximate measurement technique is measuring secondary coil current and frequency on a scope.  (Frequency changes as arcs form, so needs measuring.)  With a known secondary inductance, voltage can be calculated from current and impedance (I*2*PI*F*L).  This approximation discounts two factors.  First: Secondary coil capacitance adds current passing through only part of the coil.  Second: Primary coil current induces secondary current that is not due to secondary voltage.  This latter effect can be removed by subtracting the appropriate (for your coil) amount of measured primary current from measured secondary current.  I make an extra tap on primary CT for this purpose.  The first issue of coil capacitance is harder to deal with.  As arcs grow, some of the coil capacitance is now to the arc instead of just to top-load and ground.
With a reasonably-large top load, I think voltage by secondary current can get with +-10%.  This is based on playing at "low" voltages where my 15kV probe can measure the top directly.
Offline paulj
« Reply #2 on: February 23, 2021, 09:14:02 PM »
thank you for your feedback, I suspected that it would be complex. For other members don't hesitate to give your opinion it would be very interesting.
Today at 05:08:32 AM
Today at 04:47:32 AM
dreamth
March 03, 2021, 11:20:38 PM
AeraCura_
March 03, 2021, 11:15:32 PM
March 03, 2021, 10:30:40 PM
dreamth
March 03, 2021, 10:03:26 PM
March 03, 2021, 09:45:28 PM
March 03, 2021, 09:44:17 PM
post First power on tests
March 03, 2021, 06:26:23 PM
March 03, 2021, 05:54:58 PM
dreamth
March 03, 2021, 03:13:30 PM
dreamth
March 03, 2021, 01:18:22 PM
dreamth
March 03, 2021, 12:25:52 PM
dreamth
March 03, 2021, 12:24:40 PM
ChrisBlis
March 03, 2021, 10:43:20 AM
March 03, 2021, 09:05:02 AM
March 03, 2021, 05:53:33 AM
March 03, 2021, 04:22:01 AM
March 03, 2021, 04:00:14 AM
March 03, 2021, 01:21:15 AM
March 03, 2021, 12:36:05 AM
dreamth
March 03, 2021, 12:35:57 AM
March 02, 2021, 11:40:16 PM
dreamth
March 02, 2021, 11:29:28 PM
March 02, 2021, 10:48:04 PM
March 02, 2021, 10:33:13 PM
dreamth
March 02, 2021, 10:20:22 PM
March 02, 2021, 10:18:05 PM
March 02, 2021, 09:38:45 PM
March 02, 2021, 08:54:33 PM
March 02, 2021, 08:53:31 PM
March 02, 2021, 05:04:44 PM
March 02, 2021, 03:16:25 PM
March 02, 2021, 09:41:31 AM
ChrisBlis
March 02, 2021, 08:26:30 AM
March 02, 2021, 07:05:01 AM
March 02, 2021, 06:22:52 AM
March 02, 2021, 05:24:46 AM
March 02, 2021, 05:21:16 AM
March 02, 2021, 04:37:50 AM
March 02, 2021, 01:26:36 AM
March 01, 2021, 11:07:01 PM
post Re: Very old flyback
March 01, 2021, 11:04:06 PM
dreamth
March 01, 2021, 09:45:59 PM
March 01, 2021, 09:30:44 PM
ChrisBlis
March 01, 2021, 09:27:38 PM
March 01, 2021, 09:05:02 PM
dreamth
March 01, 2021, 08:22:33 PM
March 01, 2021, 08:16:46 PM
dreamth
March 01, 2021, 07:39:33 PM
