Author Topic: New DRSSTC with phase adjust  (Read 537 times)
Offline JCF
« on: February 13, 2021, 07:07:50 PM »
Hi
does anyone know this driver ?
this afternoon I received the driver from Ebay,
here is an overview of the printed circuit.
a little puzzled with the GDT driver. What do you think about power MOSFET (Alpha & Omega semiconductor) ?
« Last Edit: February 15, 2021, 06:01:23 PM by JCF »
Re: New DRSSTC with phase adjust
« Reply #1 on: February 13, 2021, 11:14:58 PM »
Alpha Omega Semiconductor makes nice FETs with low gate charge.  Unfortunately I've ran into multiple Chinese counterfeits of several AO parts.  In only one case did the counterfeit part meet (barely) the AO specifications.  Didn't find the specific AO part numbers based on markings in your image, so no idea what these FETs are (or are supposed to be).
Offline JCF
« Reply #2 on: February 14, 2021, 10:01:44 AM »
FET references is AOD438 and AOD403. see the specifications in attachment. there should be equivallents, no ?
« Last Edit: February 14, 2021, 10:04:44 AM by JCF »
Offline flyglas
« Reply #3 on: February 14, 2021, 04:33:20 PM »
Do you have a schematic of the controller and a manual?
Is the configuration of the CPLD available?
« Reply #4 on: February 14, 2021, 06:40:21 PM »
AOD438 and AOD403 are over-kill parts for gate drive, but should work fine.  I'd guess they are using such high-current FETs because they were available cheap, which may imply counterfeit.  But even counterfeit parts are likely good enough for this use.
Offline JCF
« Reply #5 on: February 15, 2021, 10:36:27 AM »
Thank's David, do you know which current mosfet could replace the AOD ? The box is DPAK TO252 (in case of breakdown)
If there is a problem with this DRV design, I think I must buy a piece of UDRV 2.7 with classical components. https://highvoltageforum.net/index.php?action=dlattach;topic=1388.0;attach=9656;image
Is somebody can give me a link to buy printed circuit of driver v2.7 or more with classical components ?
here schematic..... ?
« Last Edit: February 15, 2021, 05:59:00 PM by JCF »
Offline acobaugh
« Reply #6 on: February 15, 2021, 04:25:39 PM »
You can get boards for the latest version of the UD 2.7c here: http://www.loneoceans.com/labs/sales/ud27/
Offline JCF
« Reply #7 on: February 15, 2021, 06:05:18 PM »
Thank, I asked him: he only supplies PCs for CMS and no longer sells cards with soldered components ...
Offline acobaugh
« Reply #8 on: February 15, 2021, 06:31:57 PM »
Right, I thought you were only asking for PCBs. It's not too hard to solder up a board, and a couple of us have semi-recent mouser/digikey carts put together for the ud2.7c driver that we could share.
There are import drivers that are sort of based on the 2.7, some that might be based on the 2.9 board, but they all have limited support/documentation, and you'll likely end up wasting even more time and money putting something together if you go that route. EVR has assembled drivers, if you have more money than time.
If you take the time to assemble a driver yourself, you'll be better prepared for other similar projects in the future. Nobody even sells PCBs for the UD 3.0 drivers, let alone pre-assembled boards (turns out these microcontroller boards are actually cheaper to assemble than the discrete logic 2.7 boards - fewer components, and way more flexible).
There are plenty of SMD soldering tutorials on youtube (search for eevblog). I actually find SMD soldering less hassle than through-hole, personally.
« Reply #9 on: February 15, 2021, 06:58:25 PM »
SMD can be soldered with an iron.  The only time I use a hot-plate is for parts with pads entirely under the part.
If you really want to stay with through-hole, here are a few links from this forum:
https://highvoltageforum.net/index.php?topic=293.msg2864#msg2864
https://highvoltageforum.net/index.php?topic=1121.msg8161#msg8161
https://highvoltageforum.net/index.php?topic=227.msg1487#msg1487
Offline TMaxElectronics
« Reply #10 on: February 15, 2021, 08:01:32 PM »
I agree, just because it is SMD shouldn't scare anybody away from self assembly. From what I can see the board uses 0805 parts and no fine pitched ICs so is doable even for somebody that has never soldered SMD parts before.
One mistake I often see people make when getting started is that they forget to put extra flux on the board, which makes it much harder to get good looking solder joints. When soldering through hole the flux comes from the solder, in smd it is common to tin one pad, get the component, re-melt the solder on the pad and then place the component. Any flux in the solder would have evaporated by then, resulting in that crusty look. With the right flux (and enough of it) it is even hard to bridge adjacent pads/pins even on 0.4mm pitch qfn devices.
And if you want to get the board looking really good you can put it on an upside down Clothes iron and use it as a makeshift hot plate, I made my pcbs with solder paste that way.
Offline JCF
« Reply #11 on: February 17, 2021, 06:28:11 PM »
Thank for your comments, I will try to buy components with help of forum members for make a new UD 2.7 CMS type
Après premiere recherche il y a des problèmes avec les nomenclatures chez Mouser
« Last Edit: February 17, 2021, 06:38:10 PM by JCF »
Offline JCF
« Reply #12 on: February 19, 2021, 12:11:30 PM »
Hello
first measurements on this driver: disaster
the edges of the output MOSFET driver are too soft
and with the FeedBack current sense in service, it's horrible.
primary current and bridge output
I really need to get the UD2.7C drivers printed circuit.
is there a recent BOM (Mouser) list ie 2019-2020 to buy the components for the driver board UD2.7C ?
« Last Edit: February 20, 2021, 05:37:04 PM by JCF »
post Re: Voltage readings on 13.8KV
Phoenix
Today at 10:13:38 AM
March 07, 2021, 08:57:23 PM
post Re: MOT tesla coil: Why put the midpoint to ground ?
March 07, 2021, 08:53:07 PM
post Re: Identification of capacitors
Mr_Project
March 07, 2021, 08:26:27 PM
post MOT tesla coil: Why put the midpoint to ground ?
paulj
March 07, 2021, 05:49:49 PM
post Voltage readings on 13.8KV
lex1969
March 07, 2021, 10:47:55 AM
March 07, 2021, 02:48:08 AM
post Re: Question about the meaning of "±20V" specification for Vge on IGBT datasheet
March 07, 2021, 02:19:47 AM
March 07, 2021, 01:49:55 AM
March 07, 2021, 01:26:52 AM
jhorneljohn02
March 07, 2021, 12:30:36 AM
post Re: Coil destroyed at 4ms on-time.
March 06, 2021, 11:30:27 PM
post Re: Simplified mutli-stage coilgun idea
March 06, 2021, 10:13:19 PM
March 06, 2021, 09:54:31 PM
March 06, 2021, 09:48:37 PM
March 06, 2021, 09:44:20 PM
March 06, 2021, 09:33:17 PM
March 06, 2021, 09:21:44 PM
March 06, 2021, 09:15:09 PM
post Re: Osciloscope
March 06, 2021, 08:55:52 PM
March 06, 2021, 08:51:06 PM
March 06, 2021, 08:48:52 PM
March 06, 2021, 08:44:23 PM
March 06, 2021, 06:26:56 PM
March 06, 2021, 06:24:15 PM
post Question about the meaning of "±20V" specification for Vge on IGBT datasheet
jhorneljohn02
March 06, 2021, 06:00:21 PM
jhorneljohn02
March 06, 2021, 05:53:40 PM
March 06, 2021, 05:49:48 PM
March 06, 2021, 05:31:42 PM
dreamth
March 06, 2021, 05:16:24 PM
March 06, 2021, 04:35:37 PM
post Identification of capacitors
Mr_Project
March 06, 2021, 03:43:41 PM
March 06, 2021, 12:33:22 PM
March 06, 2021, 08:27:54 AM
alexhanyuan
March 06, 2021, 06:49:27 AM
March 06, 2021, 06:33:58 AM
March 06, 2021, 06:20:59 AM
March 06, 2021, 06:03:40 AM
March 06, 2021, 05:59:49 AM
March 06, 2021, 05:08:48 AM
March 06, 2021, 04:50:01 AM
March 06, 2021, 04:24:44 AM
hightemp1
March 06, 2021, 03:41:03 AM
March 06, 2021, 01:20:13 AM
March 05, 2021, 11:26:36 PM
March 05, 2021, 10:17:39 PM
March 05, 2021, 08:48:19 PM
March 05, 2021, 07:41:34 PM
dreamth
March 05, 2021, 07:22:17 PM
dreamth
March 05, 2021, 07:18:02 PM
