Hey everyone,
So I have been looking for a proper analog phase-lead circuit, but unfortunately there is not much information out there.
One thing that's commonly used is variable inductor around 10s of uH with a 51 Ohm resistor, and the feedback voltage being measured across only the inductor. Correct ?
For whatever reason, I couldn't get the feedback to work, even with 1:100, 1:500, 1:1000 CTs. Seems like board wouldn't pick up the weak signal (Clouded leopard driver from Ali).
However the reason I'm writing this post, is that I found quite well working alternative. And that is, to use much larger value inductor 100uH - 300uH straight at the output of CT without any resistor. This way I was able to get the desired phase-lead without signal attenuation. But the thing is, it is pretty hard/impossible to find variable inductor of that value.
And by using a ferrite core, it's pretty hard to hit the sweetspot, because one turn could make the difference between having stable feedback and none feedback. Eg. (200-260uH for me)
But lucky me, the 10 piece package of "same" ferrite cores from Ali had anything but the same cores. After some digging I was able to find a core that would have 230uH at 20 or so turns, so the lower "AL" value is better for fine tuning.
Anyways, here is a picture, I have only one small issue, the igbts seem to turn on sligthly before zero crossing, but it doesn't seem to affect anything, since the feedback works perfectly.
