Author Topic: Difference between halfbridge driver ICs and low/high side drivers?  (Read 260 times)
Offline Arcatarter
Hi all, I am designing a class D amp using a TL494, and while the typical halfbridge used often in sstcs works fine for testing it obviously has issues, especially at lower freq. I am going to use a split rail supply, but I stumbled upon something that confused me.
I am using a half bridge driver (L6384), but it seems that most other amplifiers with a split rail supply use a low/high side driver (such as IR2110). Is there a specific reason that many schematics use this IR2110 or equiv instead of a typical 8 DIP halfbridge driver? I feel like I am missing something here. The halfbridge driver has far less pins, has built in variable deadtime, and is easier to implement than the IR2110 etc. so I don't quite understand why many people gravitate toward an IR2110 or equiv. despite having looked through the datasheets. I cant see any reason that a halfbridge driver such as the I6384
Thanks for any words of wisdom!
Offline johnnyzoo
Re: Difference between halfbridge driver ICs and low/high side drivers?
« Reply #1 on: January 26, 2021, 07:17:42 PM »
IR2110 has been available for a long time, maybe that's why it's popular among hobbyists and designers. Just my 2 cents.
Check that the driver chip has the capability (frequency range, gate charge, maximum high-side voltage) to drive the switching transistors you are using, and the features you need (dead time control etc.), and you should be fine.
Offline Arcatarter
« Reply #2 on: January 28, 2021, 01:56:56 AM »
Hey, thanks for your reply! That actually makes a lot of sense, that the ir2110 is in many circuits because of availability. Ive never even seen the L6384 in a schematic before :p. For whatever reason, I had just convinced myself that I was missing something even though using a halfbridge with a split rail supply does the *exact* same thing as with the capacitors that make up the psuedo split rail supply (no idea if there is a better term for that  ???).
Now I just need to figure out why my amp stopped working when i went to a split rail supply, time for more research (and by that I mean adding another halfbridge driver and making an H bridge) :)
Today at 03:51:26 AM
Today at 01:27:18 AM
Today at 01:19:19 AM
SimonNwardUK
April 22, 2021, 10:36:43 PM
April 22, 2021, 06:52:48 PM
April 22, 2021, 01:20:02 PM
post Re: Corona discharge
April 22, 2021, 12:57:35 PM
April 22, 2021, 10:59:28 AM
April 22, 2021, 05:56:48 AM
April 22, 2021, 05:38:10 AM
post Re: UD2.7 Thru Hole
April 22, 2021, 02:41:13 AM
April 22, 2021, 02:41:08 AM
April 21, 2021, 09:18:14 PM
April 21, 2021, 08:38:20 PM
April 21, 2021, 08:15:13 PM
April 21, 2021, 08:08:15 PM
April 21, 2021, 07:59:41 PM
April 21, 2021, 07:40:40 PM
April 21, 2021, 04:29:42 PM
April 21, 2021, 06:12:33 AM
post UD2.7 Thru Hole
April 21, 2021, 03:52:44 AM
post Corona discharge
April 21, 2021, 12:16:22 AM
Vdekje
April 20, 2021, 10:48:45 PM
Vdekje
April 20, 2021, 10:33:53 PM
April 20, 2021, 07:32:37 PM
April 20, 2021, 07:29:04 PM
April 20, 2021, 07:25:30 PM
April 20, 2021, 06:55:36 PM
April 20, 2021, 06:48:29 PM
April 20, 2021, 03:42:58 PM
mrsebe
April 20, 2021, 01:54:01 PM
April 20, 2021, 04:53:09 AM
April 20, 2021, 02:32:21 AM
April 20, 2021, 02:28:12 AM
April 20, 2021, 12:20:45 AM
April 19, 2021, 09:59:08 PM
April 19, 2021, 09:35:16 PM
April 19, 2021, 08:48:07 PM
April 19, 2021, 05:03:29 PM
post Intensifying screen
Merces
April 19, 2021, 04:45:03 PM
mrsebe
April 19, 2021, 04:36:43 PM
post Whoohoooooo
April 19, 2021, 12:29:03 PM
hashtala
April 19, 2021, 10:02:46 AM
April 19, 2021, 06:04:03 AM
April 19, 2021, 02:48:40 AM
April 18, 2021, 08:04:18 PM
April 18, 2021, 07:10:24 PM
April 18, 2021, 01:11:28 PM
iw1esu
April 18, 2021, 12:26:48 PM
April 18, 2021, 02:36:34 AM
