Author Topic: GU5B VTTC Flashover  (Read 414 times)
Offline SalinsLV
  • Electronics experience starting from 2015
GU5B VTTC Flashover
« on: January 24, 2021, 03:01:46 PM »
Hello!
I was experimenting with my newest build and while i was increasing power a flashover happened (i attached some photos in the attachments).
I am thinking of adding PVA glue (i currently can't get proper varnish because of the virus) on top of where the flashover happened, to isolate the burned area better. I also plan to decrease the number of turns on the feedback coil. Currently the feedback coil has 19 turns of 1mm wire and i have a tap point at 13 turn.
I also posted a video on how it happened:
Before i turn on the coil is there anything i should check so that the flashover doesn't happen again?
Krisjanis Salins
Re: GU5B VTTC Flashover
« Reply #1 on: January 25, 2021, 09:02:35 AM »
Looks like too high coupling between the secondary circuit and the feedback coil. Not so much the height of the coil but the diameters of the secondary coil, primary coil and feedback coil seems very close.
You could use a high voltage rated wire for the feedback coil instead of kinked varnished copper wire, it could be some cracks in the insulation that gives you problems. I had had problems with arcing between turns of my feedback coil in a dual 811A VTTC and I could only fix that with more spacing or another type of better insulated wire. The voltage per turn ratio on the feedback coil just seems too high for enameled copper wire.
« Reply #2 on: January 25, 2021, 04:42:52 PM »
You could try rewinding the feedback coil onto a larger diameter plastic ring that will fit over your existing primary coil tube. This will put more distance between the feedback coil and the secondary coil. Done properly, it could also provide a means of raising and lowering the feedback coil to adjust the coupling. This is how I implemented the feedback coil on my 833C VTTC.
« Last Edit: February 22, 2021, 08:50:22 PM by MRMILSTAR »
Offline SalinsLV
« Reply #3 on: January 25, 2021, 04:48:02 PM »
Thanks for the replies! :)
I will replace the feedback coil and report the results afterwards.
Krisjanis Salins
Offline SalinsLV
« Reply #4 on: February 02, 2021, 09:35:42 PM »
I made a ring that increases the distance between the secondary and the feedback coil. Now i have no problems with flashovers. The sparks aren't that big. I'm using only one MOT at 90% power and the coil is partly tuned. I'm having a hard time with calculating the required capacitance for the tank circuit. That's why I'm experimenting with the capacitors that i have and looking for which makes the longest sparks at the lowest voltage.
Here are some specs if anyone is interested:
Secondary coil
Diameter: 13 cm
Lenght: 45cm
Wire diameter: 0,3mm
Turns: ~1500
Resistance: 126 ohm (measured with basic multimeter)
Secondary Fres: 197 406 Hz (with topload)
VTTC [primary coil]
diameter: 20cm
turns: 31
wire diameter: 0.1mm
height of primary: 7.1cm
inductance: 0,19mH +/- 0,18mH
resistance: 0.2 ohm (multimeter) but cheap LCR says 0,6ohm +/- 0,7ohm
Inductive reactance: 223.261 Ohms @ 197 406 Hz (secondary coil Fres)
Primary inductance: 0.18mH (measured with cheap LCR from ebay)
Currently used tank capacitor value: 3.6nF
Recommended capacitor: ????
Krisjanis Salins
« Reply #5 on: February 03, 2021, 05:38:09 AM »
Do you have selectable tap points on your primary coil? Its hard to determine from your pictures. If not, then you need to add them in order to tune this coil.
You can use JAVATC to give you a good idea of the tap point with your capacitor.
Offline SalinsLV
« Reply #6 on: February 22, 2021, 08:15:40 PM »
Currently i have no tap points. The way i tried to tune this coil was by changing the capacitor values to match with the primary coil inductance to oscillate at the secondary coil resonant frequency. The coil works and if i bring my hands closer, the sparks also get louder and bigger.
I am now upgrading the coil with another MOT and extra filter capacitors for higher power. I will also add tap points on the primary as previously suggested.
Krisjanis Salins
Offline SalinsLV
« Reply #7 on: February 24, 2021, 09:30:40 PM »
 Should i also add tap points to the feedback coil?
Krisjanis Salins
« Reply #8 on: February 24, 2021, 10:14:02 PM »
Some people do add tap points to the feedback coil. I didn't.
Today at 11:26:36 PM
Today at 10:17:39 PM
Today at 08:48:19 PM
Today at 07:41:34 PM
dreamth
Today at 07:22:17 PM
dreamth
Today at 07:18:02 PM
Today at 07:12:26 PM
Today at 07:05:38 PM
Scicat111
Today at 02:48:50 PM
dreamth
Today at 11:54:31 AM
Today at 11:32:08 AM
Today at 09:55:49 AM
dreamth
Today at 09:32:25 AM
dreamth
Today at 09:16:51 AM
dreamth
Today at 08:40:02 AM
Today at 05:54:47 AM
Today at 05:43:13 AM
Today at 05:17:46 AM
Today at 05:08:14 AM
Today at 05:02:17 AM
Today at 04:45:37 AM
Today at 04:13:43 AM
Today at 03:08:09 AM
Today at 02:49:06 AM
Today at 02:29:05 AM
Today at 12:43:03 AM
Today at 12:37:50 AM
Today at 12:22:33 AM
March 04, 2021, 11:32:28 PM
March 04, 2021, 11:29:43 PM
March 04, 2021, 10:18:32 PM
dreamth
March 04, 2021, 09:35:40 PM
March 04, 2021, 09:27:58 PM
March 04, 2021, 07:58:06 PM
dreamth
March 04, 2021, 04:56:30 PM
dreamth
March 04, 2021, 04:41:06 PM
dreamth
March 04, 2021, 03:18:19 PM
March 04, 2021, 02:40:56 PM
dreamth
March 04, 2021, 01:48:05 PM
March 04, 2021, 01:18:44 PM
March 04, 2021, 11:15:01 AM
dreamth
March 04, 2021, 10:42:41 AM
post Interrupter frequency?
March 04, 2021, 10:08:39 AM
dreamth
March 04, 2021, 09:34:59 AM
Bouaziz
March 04, 2021, 09:34:05 AM
ChrisBlis
March 04, 2021, 09:30:38 AM
dreamth
March 04, 2021, 09:08:55 AM
March 04, 2021, 07:16:23 AM
March 04, 2021, 05:08:32 AM
March 04, 2021, 04:47:32 AM
