Author Topic: Paralleling IGBT bricks for H-bridge  (Read 281 times)
Offline Patrik
« on: January 21, 2021, 02:10:48 PM »
Hi!
I am new here and I want to ask about paralleling IGBT bricks to create an H-bridge for my SSTC.
I have two 6MBI75UC-120-52 IGBT bricks each consisting of three half bridges for 3 phase inverter.
Here is the datasheet, if you want to check it out: http://www.bjrtd.com/pdf/6MBI75UC-120.pdf
Now, I want to put all of the half brigdes inside the brick in parallel, creating one big halfbridge, so that I can run about 100A through the primary coil
and out of those two paralleled modules create a full bridge to drive the primary.
I have done some research before and I know, I should use separate matched gate resistors and drive them from single GDT.
I will be placing a antiparallel doide to the resistor to speed up the discharging of the gate.
As a driver I will be using a Steve Wards universal driver 1.3.
Do you think, that this settup will be powerful enough to drive the IGBT transistors? And should I replace the 7824 regulator with a separate power supply or it is fine to keep it in the circuit?
Thank you wery much!
Re: Paralleling IGBT bricks for H-bridge
« Reply #1 on: January 22, 2021, 06:19:21 AM »
Are you building a DRSSTC (Dual Resonant SSTC where the primary coil and capacitor are tuned to match or slightly below secondary frequency)?  Or is this a normal SSTC with non-resonant primary coil?  For normal SSTCs, most designs use FETs rather than IGBTs.  For the short bursts of a DRSSTC, that IGBT brick could likely handle a peak of 300A per half-bridge, or 900A for all three in parallel.  Certainly at least 200A per half-bridge as is listed as the 1ms maximum in the specification.
Other details about your coil would help too - frequency in particular.  A dump from JavaTC would be even better.
Offline Patrik
« Reply #2 on: January 22, 2021, 08:47:11 AM »
Hi!
I am building a regular SSTC, without the primary resonance capacitor. I know, that most people use mosfet transistors, but I have these at home, and want to try them in this circuit.
The primary has an inductance of about 12uH.
The javaTC output:
« Reply #3 on: January 22, 2021, 08:09:18 PM »
Switching energy loss will dominate when using IGBTs for a SSTC (be much higher than conduction losses).  For 10-20% duty cycle on your 73kHz coil, you probably could run the three paralleled half-bridges at 100A.  Perhaps higher - depends largely on the current at switching times.  With your high-Q secondary, before long arcs form, current may drop fairly low before switching.  Scope at low duty cycle (and measure IGBT temperature) before increasing duty cycle.
« Reply #4 on: January 25, 2021, 11:18:30 AM »
You are mixing some things together here, as Dave points out there is a problem with switching losses by using IGBTs in a SSTC.
You also mention that you will use the Steve Ward Universal Driver 1.3b , but that is a DRSSTC driver that needs a powerful primary cirucit feedback, which you can not get from a SSTC as its primary circuit is not resonant.
You need to make choice about building either a SSTC or DRSSTC and then use the right parts and drivers for each kind.
dreamth
March 03, 2021, 11:20:38 PM
AeraCura_
March 03, 2021, 11:15:32 PM
March 03, 2021, 10:30:40 PM
dreamth
March 03, 2021, 10:03:26 PM
March 03, 2021, 09:45:28 PM
March 03, 2021, 09:44:17 PM
post First power on tests
March 03, 2021, 06:26:23 PM
March 03, 2021, 05:54:58 PM
dreamth
March 03, 2021, 03:13:30 PM
dreamth
March 03, 2021, 01:18:22 PM
dreamth
March 03, 2021, 12:25:52 PM
dreamth
March 03, 2021, 12:24:40 PM
ChrisBlis
March 03, 2021, 10:43:20 AM
March 03, 2021, 09:05:02 AM
March 03, 2021, 05:53:33 AM
March 03, 2021, 04:22:01 AM
March 03, 2021, 04:00:14 AM
March 03, 2021, 01:21:15 AM
March 03, 2021, 12:36:05 AM
dreamth
March 03, 2021, 12:35:57 AM
March 02, 2021, 11:40:16 PM
dreamth
March 02, 2021, 11:29:28 PM
March 02, 2021, 10:48:04 PM
March 02, 2021, 10:33:13 PM
dreamth
March 02, 2021, 10:20:22 PM
March 02, 2021, 10:18:05 PM
March 02, 2021, 09:38:45 PM
March 02, 2021, 08:54:33 PM
March 02, 2021, 08:53:31 PM
March 02, 2021, 05:04:44 PM
March 02, 2021, 03:16:25 PM
March 02, 2021, 09:41:31 AM
ChrisBlis
March 02, 2021, 08:26:30 AM
March 02, 2021, 07:05:01 AM
March 02, 2021, 06:22:52 AM
March 02, 2021, 05:24:46 AM
March 02, 2021, 05:21:16 AM
March 02, 2021, 04:37:50 AM
March 02, 2021, 01:26:36 AM
March 01, 2021, 11:07:01 PM
post Re: Very old flyback
March 01, 2021, 11:04:06 PM
dreamth
March 01, 2021, 09:45:59 PM
March 01, 2021, 09:30:44 PM
ChrisBlis
March 01, 2021, 09:27:38 PM
March 01, 2021, 09:05:02 PM
dreamth
March 01, 2021, 08:22:33 PM
March 01, 2021, 08:16:46 PM
dreamth
March 01, 2021, 07:39:33 PM
March 01, 2021, 07:25:33 PM
March 01, 2021, 07:17:02 PM
