Author Topic: High voltage transformer for neon bombarding.  (Read 344 times)
Offline AndreasVE
« on: January 21, 2021, 10:53:15 AM »
Hello everybody.
At the moment I'm looking into the neon craft. I've got everything figured out except for 1 transformer used in a process called "bombarding". It's a process in which a almost vacuum glass tube is bombarded with a very high voltage for the sake of cleaning it.
The instruction videos I have seen all use a pole like transformer (USA (I'm from Europe)). One transformer used is a 12.5Kva/20KV transformer, connected to 2 120V lines (USA). One video shows the current gauge when bombarding (0-400mA).
So my question:
Are there any modern alternatives to such a transformer (heavy noisy pole transformer)?
If a high voltage, low current is drawn from the secundary side, does this mean primary has a very high current? If so does this mean that the transformer should be connected to a 3 phase net (Europe) instead of regular 230V AC and 10mm² +- wires should be used?
I know how a transformer works in theory, but I haven't really yet used one for real. Also, the bombarding process is kind of specific.
I hope that my questions are somewhat clear.
Kind regards from Belgium,
Andreas
Re: High voltage transformer for neon bombarding.
« Reply #1 on: January 22, 2021, 01:52:12 AM »
Three phase is no good for what you are doing.  Here is one reference that gives electrical service requirements: https://www.egl-lighting.com/bombarders/
Regular bombarder transformers have core shunts, like NST's, to limit the current.
But they are designed for 15 to 30 times more current, to rapidly heat up the mostly evacuated glass tube.  Does your neon craft reference mention putting a bit of folded paper over the tube, which chars when the glass becomes hot enough?
As far as risk of lethal electric shock, neon bombarder transformers make MOT's look like safe playthings.   The electricity can jump much farther to get you.  These transformers have been essential tools of the neon trade for about 100 years.
« Last Edit: January 22, 2021, 02:05:25 AM by klugesmith »
Offline AndreasVE
« Reply #2 on: January 22, 2021, 11:16:43 AM »
Yes I know that these transformers are very dangerous, that's why I was wondering if there are any alternatives.
I recently had a BA5 formation but still..
« Reply #3 on: January 22, 2021, 11:23:39 PM »
Thank you for mentioning BA5 electrical certification, a thing I had not heard of before.
There might be people on forums that have hints about DIY bombarders.
For example, maybe a used pole transformer combined with a ballast choke like some in arc welders.
As for safety:
I think the task requires short circuit current of 0.4 to 0.9 amps, which is as lethal as can be.
For short tubes you might get by with open circuit voltage much less than 20 kV.
Less likely to jump through air, or find pinhole or punch through an insulating glove.  But you should not be close when a tube is being bombarded.
Beware of internal arc from one electrode into the gas manifold and/or the vacuum pump.
« Last Edit: January 22, 2021, 11:30:21 PM by klugesmith »
post Re: UD2.7 Thru Hole
Today at 02:41:13 AM
Today at 02:41:08 AM
April 21, 2021, 09:18:14 PM
April 21, 2021, 08:38:20 PM
April 21, 2021, 08:15:13 PM
April 21, 2021, 08:08:15 PM
post Re: Corona discharge
April 21, 2021, 07:59:41 PM
April 21, 2021, 07:40:40 PM
April 21, 2021, 04:29:42 PM
April 21, 2021, 06:12:33 AM
post UD2.7 Thru Hole
April 21, 2021, 03:52:44 AM
post Corona discharge
April 21, 2021, 12:16:22 AM
Vdekje
April 20, 2021, 10:48:45 PM
Vdekje
April 20, 2021, 10:33:53 PM
April 20, 2021, 07:32:37 PM
April 20, 2021, 07:29:04 PM
April 20, 2021, 07:25:30 PM
April 20, 2021, 06:55:36 PM
April 20, 2021, 06:48:29 PM
April 20, 2021, 03:42:58 PM
mrsebe
April 20, 2021, 01:54:01 PM
April 20, 2021, 04:53:09 AM
April 20, 2021, 02:32:21 AM
April 20, 2021, 02:28:12 AM
April 20, 2021, 12:20:45 AM
April 19, 2021, 09:59:08 PM
April 19, 2021, 09:35:16 PM
April 19, 2021, 08:48:07 PM
April 19, 2021, 05:03:29 PM
post Intensifying screen
Merces
April 19, 2021, 04:45:03 PM
mrsebe
April 19, 2021, 04:36:43 PM
post Whoohoooooo
April 19, 2021, 12:29:03 PM
hashtala
April 19, 2021, 10:02:46 AM
April 19, 2021, 06:04:03 AM
April 19, 2021, 02:48:40 AM
April 18, 2021, 08:04:18 PM
April 18, 2021, 07:10:24 PM
April 18, 2021, 01:11:28 PM
iw1esu
April 18, 2021, 12:26:48 PM
April 18, 2021, 02:36:34 AM
April 18, 2021, 01:24:59 AM
mrsebe
April 17, 2021, 07:56:07 PM
April 17, 2021, 07:50:17 PM
Maverikie
April 17, 2021, 07:20:58 PM
April 17, 2021, 11:53:37 AM
April 17, 2021, 09:34:02 AM
April 17, 2021, 05:36:49 AM
April 17, 2021, 04:30:36 AM
post Help needed with SSTC. First TC build
Maverikie
April 16, 2021, 09:22:47 PM
post HELP .... PLEASE?
April 16, 2021, 10:50:24 AM
