Author Topic: Try to make a full Bridge with IGBT and GDT  (Read 155 times)
Offline JCF
« on: January 14, 2021, 06:11:06 PM »
Hello to all, I am recently on the forum.  I have a small Tesla coil made with 4 IRFP 460. I want make a new one with primaire 18cm (15 turn) et secondaire 55 cm (1000 turns)
For that I have 2 CM200DU1-2F IGBTs that I would like to use to make a full bridge.
see the signal on this 1 picture. I have a lot of parasitic peaks and a false signals on a 200 Ohm resistor which replace the primary to make a test at 50 v max ?
picture 2 signal on Gate IGBT
I do not know what to do now ?, I tested the 2 IGBTs, they are good, Signal of the four GDT secondary outputs on 1 kHoms correct ...
« Last Edit: January 14, 2021, 06:31:14 PM by JC78 »
Offline Pete57
Re: Try to make a full Bridge with IGBT and GDT
« Reply #1 on: January 14, 2021, 08:39:06 PM »
Hi JC78.
I have just joined also, but have been building Tesla Coils for a long time.
Looking at your two waveform samples.
The first screenshot shows excessive low frequency ringing, (Transformer totally un-useable ). The second screenshot is better, but still has ringing and voltage spikes.
I think the best thing you can do is to wind a better Gate Drive Transformer.
I wind my GDTs using cat5 ( outer sheath removed ), cable around an Epcos N30 ferrite core.
I normally wind  11 to 13 turns around the core.  I use the CM200DY-12H IGBT bricks, and find that 11 turns around a 27mm o\d core normally works well.
Make sure you use purpose made snubber caps across C1\E2 of the igbt mods . These will help with the voltage spikes . Also, dont forget to add BI-DIRECTIONAL TVS DIODES across the Gate\Emitter junctions of each igbt. These help protect the gates from voltage spikes.
Hope this helps.
« Reply #2 on: January 15, 2021, 01:36:45 PM »
Hi JC78 and Pete, welcome to HVF!
You can not substitute the primary coil with a 200 Ohm resistor and expect the feedback / gate drive transformers to do their job correct, from a driver that expects a resonant LC feedback current. You need to test with about 100V on the DC bus to avoid excessive IGBT output capacitance ringing and get a proper feedback signal. Instead of a secondary coil that makes sparks, you can place a iron pot/container with water in as a dummy load.
To trouble shoot your GDT waveforms further, this is a great reference: http://www.richieburnett.co.uk/temp/gdt/gdt2.html
post Re: Segmented PTFE Secondary, Large Plasma Ball project
zytra
Today at 06:37:53 AM
Today at 06:16:41 AM
zytra
Today at 05:00:50 AM
Today at 04:03:12 AM
post Just a noob with some HV concerns...
MrScrOggs
Today at 03:07:11 AM
zytra
Today at 02:57:27 AM
Today at 12:06:44 AM
January 18, 2021, 11:56:31 PM
post Re: how to run these guys?
January 18, 2021, 11:50:22 PM
January 18, 2021, 10:30:15 PM
zytra
January 18, 2021, 10:03:46 PM
January 18, 2021, 09:58:44 PM
zytra
January 18, 2021, 08:52:29 PM
January 18, 2021, 07:08:09 PM
post Re: Adding interrupter Self oscillating tesla coil
January 18, 2021, 06:49:28 PM
post Re: Alcatel Lucent B4 RRH2x60-4R teardown and reverse engineering
January 18, 2021, 06:12:44 PM
January 18, 2021, 04:53:23 PM
post Adding interrupter Self oscillating tesla coil
arto
January 18, 2021, 11:54:54 AM
post Re: Segmented PTFE Secondary, Plasma Ball project
zytra
January 18, 2021, 08:27:18 AM
Acid Byte
January 18, 2021, 06:57:06 AM
January 18, 2021, 06:43:19 AM
zytra
January 18, 2021, 05:48:27 AM
January 18, 2021, 01:03:48 AM
January 18, 2021, 12:26:26 AM
January 17, 2021, 11:29:04 PM
January 17, 2021, 09:55:24 PM
zytra
January 17, 2021, 09:34:21 PM
January 17, 2021, 08:51:50 PM
January 17, 2021, 08:04:54 PM
tophat
January 17, 2021, 05:40:59 PM
post Re: Schlieren images projected onto a wall (no camera)
January 17, 2021, 05:12:45 PM
January 17, 2021, 02:20:09 PM
post Re: First SSTC build - some questions
zytra
January 17, 2021, 05:56:05 AM
post Segmented PTFE Secondary, Large Plasma Ball project
zytra
January 17, 2021, 05:55:11 AM
January 17, 2021, 03:50:27 AM
January 17, 2021, 03:37:28 AM
zytra
January 17, 2021, 01:48:10 AM
January 16, 2021, 11:21:13 PM
January 16, 2021, 10:09:21 PM
Miki_407
January 16, 2021, 09:38:08 PM
January 16, 2021, 09:27:25 PM
post Re: UD2.9 Troubleshooting Help
January 16, 2021, 09:05:23 PM
GKnapp
January 16, 2021, 07:44:41 PM
January 16, 2021, 07:06:13 PM
January 16, 2021, 06:48:05 PM
Miki_407
January 16, 2021, 06:38:11 PM
GKnapp
January 16, 2021, 06:23:53 PM
January 16, 2021, 06:23:10 PM
GKnapp
January 16, 2021, 03:28:14 PM
January 16, 2021, 05:09:53 AM
