Author Topic: transistor markings question  (Read 333 times)
Offline NOOBPASTE51
« on: December 01, 2020, 12:02:19 PM »
Hello to all of you in this forum. I have found so many useful things here, that helped a newbie like me to fix some simple electronics..
So,  first of all, let me express my gratitude to this forum and all its members.
I am in NO WAY an electronics expert (not even studied any stuff like this). But many times i have stumbled upon "broken" electronics that need fixing (like replacing some tact-switches in my synthesizer, replacing capacitors, resistors, or constructing a pcb with various components based on other peoples' instructions etc..)
So, now, a new problem arised : my plasma tv has gone black, and based on various stuff i read in the web, it would probably be the YSUS boards' fault.. So i tried to check some electronics components with a multimeter, and found some transistors shorted to ground, and maybe a PP capacitor is leaking ...
Unfortunately, the transistors have some markings i cannot translate to actual specification, and i really need your help in this. There you go:
(transistors with 3 legs THROUGH-HOLE, probably TO-220 or TO-220F packaging, if i say this correctly..):
1)  (1rst line)  0944 /  (2nd line)  F20LC30
2)  1942  /  F20LC30
3)  0544/  F20LC30
4)  0644/  F20LC30
(Transistor SMD with 3 legs (one not to be soldered) and a tab on the opposite side) :
N 4C / 61FC4
I really do NOT have a clue if these are MOSFETs or diodes or regulators. I only found datasheets for the F20LC30 but i cannot identify the numbers before this code, so i am not sure if i should buy any F20LC30 with different numbers..
I would greatly appreciate your help with this.. (please note that my electronics knowledge is quite limited, so be gentle   :-[ )
Re: transistor markings question
« Reply #1 on: December 01, 2020, 07:39:48 PM »
If you've found a part "F20LC30", then the other numbers may just be lot numbers and/or date codes.
Offline Arcatarter
« Reply #2 on: December 24, 2020, 12:17:37 AM »
I have come across this issue many times while scavenging parts from plasma TVs, many of them have parts which I have been unable to find datasheets for. However I do know that all of the plasma TVs I've seen use IGBTs and rectifiers, and those are typically the components which I am unable to find datasheets for.
The majority of the plasma TV circuit boards I have use IGBTs that are rated for 300 volts and around 80 amps, and the rectifiers are usually around 400 volts and 10 amps. I feel pretty certain that the part number you gave is an IGBT. If pin 1 has a smaller trace than pin 2 and 3, you can be almost certain that it is an IGBT as the gate (pin 1) will almost always have a small trace due to the much lower current required. If you can take pictures of the board, I could tell you almost for sure whether they are IGBTs or rectifiers.
The numbers around the f20lc30 aren't important, as davekni said they are likely lot numbers and date codes.
« Reply #3 on: December 24, 2020, 10:01:17 AM »
When searching for part numbers from power silicon components, I find it useful to only search for the two numbers and the letters in-between. They are almost always structured as current first, some letter and then voltage rating. 20LC30 would be 20A 300V and LC is manufacturer specific.
As seen here: https://www.alldatasheet.net/view_datasheet.jsp?Searchword=20LC30&sField=3
The prefix of S, DF or SF makes a difference if its a diode or MOSFET, so that is how Shindengen chose to name their devices with a common current/voltage part of the name across different types.
Today at 10:18:13 PM
Today at 10:13:16 PM
kyledellaquila
Today at 07:11:20 PM
post 833A Cathode Modulation
kyledellaquila
Today at 07:09:52 PM
post GU5B VTTC Flashover
SalinsLV
Today at 03:01:46 PM
Today at 12:57:53 PM
Today at 10:26:15 AM
Today at 06:09:48 AM
Today at 03:57:45 AM
kyledellaquila
January 23, 2021, 07:22:57 PM
January 23, 2021, 07:15:46 PM
January 23, 2021, 06:54:18 PM
January 23, 2021, 06:39:16 PM
kyledellaquila
January 23, 2021, 05:43:59 PM
Acid Byte
January 23, 2021, 03:40:18 PM
pc50kd
January 23, 2021, 02:35:18 PM
January 23, 2021, 11:27:50 AM
January 23, 2021, 11:00:37 AM
January 22, 2021, 11:23:39 PM
January 22, 2021, 08:09:18 PM
zytra
January 22, 2021, 06:49:26 PM
AndreasVE
January 22, 2021, 11:16:43 AM
January 22, 2021, 10:05:28 AM
Patrik
January 22, 2021, 08:47:11 AM
January 22, 2021, 06:19:21 AM
January 22, 2021, 06:03:43 AM
January 22, 2021, 05:45:21 AM
AeraCura_
January 22, 2021, 05:22:44 AM
January 22, 2021, 04:58:04 AM
AeraCura_
January 22, 2021, 03:39:07 AM
January 22, 2021, 03:18:53 AM
January 22, 2021, 01:52:12 AM
kyledellaquila
January 22, 2021, 01:26:13 AM
aes92000
January 22, 2021, 01:19:24 AM
January 22, 2021, 12:46:22 AM
January 22, 2021, 12:41:44 AM
Patrik
January 21, 2021, 02:10:48 PM
Patrik
January 21, 2021, 11:31:39 AM
AndreasVE
January 21, 2021, 10:53:15 AM
zytra
January 21, 2021, 08:36:50 AM
January 21, 2021, 05:10:27 AM
post Re: 4HV gone?
January 21, 2021, 05:08:54 AM
post induction heater issues
aes92000
January 21, 2021, 04:19:43 AM
January 21, 2021, 03:00:50 AM
zytra
January 21, 2021, 02:21:32 AM
January 21, 2021, 01:23:12 AM
zytra
January 21, 2021, 01:12:01 AM
January 20, 2021, 11:51:48 PM
January 20, 2021, 11:47:09 PM
January 20, 2021, 11:19:41 PM
