Author Topic: I started making a drsstc  (Read 1010 times)
Offline Miki_407
« on: November 30, 2020, 11:58:29 AM »
I am 14 years old and this is my first true drsstc. Does the secondary need to be changed? I used 0.1mm wire for it and a 75mm pvc pipe, length of windings is 14.5cm. Would it be better to make a 24cm long windings with 0.2mm wire on a 75m pvc pipe? I plan on using a full bridge with parallel 40n60n igbts. Also i wanted to ask is my topload ok, i made it myself from some copper pipe. Any later questions i have i will make in this post.
Re: I started making a drsstc
« Reply #1 on: November 30, 2020, 12:56:05 PM »
Hi Miki and welcome to HVF :)
It is great to see young people taking on the challenge of building a DRSSTC.
I calculated your tesla coil resonant frequency and you have around 1300 turns and which your topload you are properly around 130'ish kHz resonant frequency, looking at the tesla coil impedance list, you properly have a impedance higher than 60k, so you should be designing for a high impedance inverter. This means lower peak current, longer on-time and that means you should have more turns on the primary coil and a smaller MMC in order to hit high impedance in the primary circuit. You should also check out the MMC calculator to make it easier to get it right in your Tesla coil.
What are you planning to use as driver? There is a great variety of the old school universal driver 1.3b and up to the latest fully digital and PC controlled NextGen UD3
Offline Miki_407
« Reply #2 on: November 30, 2020, 01:16:04 PM »
I am planing on using ud2.7. I have used this coil before with a smaller topload and 16 turns primary. I was afraid with this bigger topload it would arc back to primary.
This is the video of it on 300vdc. It sadly died shortly after. I think a biggest problem was phase lead as i have been using a pll circuit also long wires from bridge to primary, no snubber capacitors.
Few other questions.
1.How long sparks should i expect?
3.Should i make a primary with tap points or go with a primary simular to one shown in my video?
« Last Edit: November 30, 2020, 07:47:05 PM by Mads Barnkob »
« Reply #3 on: November 30, 2020, 08:49:30 PM »
Your primary looks fine.  With it being fixed inductance, you will need some way to add and/or remove capacitance of the MMC between H-Bridge and primary coil.  That is my preference - adjusting MMC rather than primary winding.  However, tapped primary winding is much more common.  (Ferrites can be used to adjust primary frequency, but there are many complications to consider for that option.)
Arc length depends on many factors, especially enable pulse width and repetition frequency.  I've had best success with high (1kHz+) repetition with ramped pulse width.
For H-Bridge layout, I recommend copper planes as in this post:
https://highvoltageforum.net/index.php?topic=1324.0
Good luck!  Nice progress already!
Offline Miki_407
« Reply #4 on: November 30, 2020, 08:58:41 PM »
I am using a layout of loneoceans easybridge. Soon parts should arrive so i will post when i find new problem or finish it. Adjusting a mmc wont really be problem as i am using 50 capacitors(2kv 4.7nf). Thank for the help.
Offline Miki_407
« Reply #5 on: January 09, 2021, 03:53:25 PM »
         So a little problem has risen. I used non inverting mosfet driver UCC27424 instead of UCC27423. Will making a mod board that fits on phase control and inverts the inputs be good enough until i order replacements.
« Reply #6 on: January 09, 2021, 07:42:20 PM »
Yes, inverters on those two 74HC08 outputs should work fine.  The inverters will add a bit more delay, so require slightly more phase lead to compensate.
Another option is to change the 74HC08 to a 74HC00 (AND to NAND gate).  If you do that, bypass the inverter on pin 8 of the NAND gate to keep enable logic correct (bypass 74HC14 pins 12 and 13).
For your previous concern about arcs to the primary coil, most DRSSTC designs include a strike rail near the top of the primary coil.  That's a grounded not-quite-complete turn of exposed conductor (ie. copper pipe or ...) with diameter a bit larger than outside of primary.  Any arcs that head down will hit that rail before reaching the primary.
Offline Miki_407
« Reply #7 on: January 11, 2021, 09:15:11 PM »
Finally made the mod board work :D. Turns out my first ic was broken. It isn't tuned right. Primary side is 150kHz and secondary is 185kHz with no arcs. No phase lead is set jet. I had issues with it arcing back to primary but lowering the primary fixed it. Later I might change to pancake primary.
So here is a video of it working:
« Reply #8 on: January 11, 2021, 09:41:53 PM »
Congratulations!
Offline Miki_407
« Reply #9 on: January 16, 2021, 06:38:11 PM »
I need to ask some questions.
On what amperage should I put ocd for my 2 parallel 40n60n igbt full bridge?
What is easiest way to see if I am not too far away from zero point switching? I don't have a differential probe and I only have usb oscilloscope.
Soon i will upload another video.
« Reply #10 on: January 16, 2021, 07:06:13 PM »
What is the full part number for "40n60n"?  I'd need to see a datasheet in order to estimate current capability.  Also, what gate voltage are you running (in other words, what supply voltage is running to the UD2.7 board)?
Do you have a scope probe capable of measuring 340V waveforms even if not isolated?  If so, you can capture useful H-Bridge output waveforms even on top of the line-frequency base.  Of course, DO NOT CONNECT THE SCOPE PROBE GROUND TO THE H-BRIDGE BUS SUPPLY.  (However, response will improve if the scope ground is wired through a ~0.1uF 400+V capacitor to H-Bridge VBus- rail.)  Trigger on the H-Bridge output waveform, adjusting trigger threshold for the lowest (most negative) voltage that captures waveforms.  You will be capturing waveforms once per line cycle, enough to be useful.  When voltage phase is lagging current, the H-Bridge output will show a larger noise spike at switching (caused by IGBT diode reverse-recovery snap-off).  At zero-phase there is sometimes a triple-transition on H-Bridge outputs - rising,falling,rising in rapid succession instead of a clean rising edge.  Slightly more phase lead (ideal point) and H-Bridge outputs will transition cleanly and smoothly.
Offline Miki_407
« Reply #11 on: January 16, 2021, 09:38:08 PM »
Full number is 40n60npfd.
I am running 20v.
I have 10x probe rated at 600v CAT II but I think my scope is made for max 6v with 1x probe so answer is I cant measure 340v. I haven't tested my coil at 300v yet max i have gone to is 120v.
« Reply #12 on: January 16, 2021, 10:09:21 PM »
I've found data for an IGBT part SGT40N60NPFDPN.  I'm guessing that is what you have.  It is rated for 120A peak, 40A at 100C case, 80A at 25C case temperature.  My rule-of-thumb is that IGBTs fry around 2x rated peak current or 4x rated average current in DRSSTC use.  That would be about 240A per IGBT, 480A for a pair IF they share current perfectly evenly.  That is destruction current, so you want OCD a ways below that, perhaps 300A.  I'd start even lower, ~200A until you have phase lead dialed in.  Others here may have more experience with similar parts.
Sometimes there is enough switching glitch showing up when probing driver output (GDT input) to use for phase lead adjustment.  It is hard to predict exactly what you will see there.  Another option is to form a couple turns (loops) of wire from scope probe tip to ground lead.  Tape over the wire ends (over the probe tip and ground clip) to avoid bumping any high-voltage nodes.  Use this as a magnetic-field probe around the IGBTs or VBus leads to the bridge.  That will often pick up enough signal to see the switching edges.  You will need to experiment with loop size and placement to get clear pulses (or at least spikes and ring-down) at switching times.
Acid Byte
Today at 06:57:06 AM
post Re: Segmented PTFE Secondary, Plasma Ball project
Today at 06:43:19 AM
zytra
Today at 05:48:27 AM
post Re: how to run these guys?
Today at 01:03:48 AM
Today at 12:26:26 AM
January 17, 2021, 11:29:04 PM
January 17, 2021, 09:55:24 PM
zytra
January 17, 2021, 09:34:21 PM
January 17, 2021, 08:51:50 PM
January 17, 2021, 08:04:54 PM
tophat
January 17, 2021, 05:40:59 PM
post Re: Schlieren images projected onto a wall (no camera)
January 17, 2021, 05:12:45 PM
January 17, 2021, 02:20:09 PM
post Re: First SSTC build - some questions
zytra
January 17, 2021, 05:56:05 AM
post Segmented PTFE Secondary, Plasma Ball project
zytra
January 17, 2021, 05:55:11 AM
January 17, 2021, 03:50:27 AM
January 17, 2021, 03:37:28 AM
zytra
January 17, 2021, 01:48:10 AM
January 16, 2021, 11:21:13 PM
Miki_407
January 16, 2021, 09:27:25 PM
post Re: UD2.9 Troubleshooting Help
January 16, 2021, 09:05:23 PM
GKnapp
January 16, 2021, 07:44:41 PM
January 16, 2021, 06:48:05 PM
Miki_407
GKnapp
January 16, 2021, 06:23:53 PM
January 16, 2021, 06:23:10 PM
GKnapp
January 16, 2021, 03:28:14 PM
January 16, 2021, 05:09:53 AM
January 16, 2021, 05:00:46 AM
January 16, 2021, 04:56:31 AM
post Re: General sstc questions ssts 5 built
January 16, 2021, 04:32:23 AM
_The_Plasma_Prince_
January 16, 2021, 04:09:57 AM
post how to run these guys?
January 16, 2021, 12:21:23 AM
post Re: Maximum frequency capability of microwave oven diodes
January 15, 2021, 09:38:27 PM
post Maximum frequency capability of microwave oven diodes
January 15, 2021, 09:27:43 PM
post UD2.9 Troubleshooting Help
GKnapp
January 15, 2021, 09:22:35 PM
post Re: Vintage ASEA EG-1 630A / 440 kW Contactor Test and Teardown
January 15, 2021, 08:29:18 PM
January 15, 2021, 07:11:03 PM
post Re: DRSSTC II
January 15, 2021, 06:37:06 PM
niels
January 15, 2021, 05:07:43 PM
post Drsstc Driver Board for Tesla Coil Driver Optic Fiber Splice
JCF
January 15, 2021, 04:41:47 PM
post Re: DRSSTC II
January 15, 2021, 01:45:36 PM
post Re: Try to make a full Bridge with IGBT and GDT
January 15, 2021, 01:36:45 PM
January 15, 2021, 10:20:32 AM
Pete57
January 14, 2021, 08:39:06 PM
post Try to make a full Bridge with IGBT and GDT
JCF
January 14, 2021, 06:11:06 PM
zytra
January 14, 2021, 09:24:10 AM
