Author Topic: Setting over current protection for my drsstc  (Read 262 times)
Offline octopus1
« on: November 28, 2020, 12:37:32 AM »
Hello all,
I have been thinking way to hard about this and I feel like it should be simple. I should set the over current protection to the max current rating of my igbt. Or am I over looking something simple.
Thanks in advance!  :)
Re: Setting over current protection for my drsstc
« Reply #1 on: November 28, 2020, 12:36:05 PM »
Hello all,
You should set it to something you dare push your IGBTs to or it could also be used to limit the voltage across the MMC. Just two sides of the same case.
If you are looking for proven numbers, there is a list of IGBT peak currents in a Tesla coil / DRSSTC here
If you are looking to do the math and calculate the maximum current for your IGBT in a Tesla coil / DRSSTC, scroll down to Fmax2 calculations here
Calculating the voltage across the MMC can be done with the MMC calculator or if you want the full theory behind it, then MMC design for Tesla coil / DRSSTC is where you want to go
Offline octopus1
« Reply #2 on: November 28, 2020, 03:10:04 PM »
Thanks! So I got that I need a current limit of 800a. I’m using a cm300dy-12nf brick, a .235uf 8kv mmc, and 8 turns of 1/4” copper tube for the primary. Let me know if that sounds way to high, thanks for all the help I wouldn’t be able to do this project with your website and the good people on this forum.
« Reply #3 on: November 28, 2020, 06:22:11 PM »
800A sounds reasonable but only IF your resonant frequency is over ~70kHz. If it is lower than that then the MMC voltage rating is too low (and I'd try to give a bit more margin than peak voltage = DC voltage rating). The IGBT should be OK at 800A or a little higher.
Offline octopus1
« Reply #4 on: November 28, 2020, 06:54:18 PM »
Oh good! My resonant frequency is around 90khz so it should be fine then, again thanks for all your guys help
post Alternative phase lead
panjaksli
Today at 10:24:39 AM
post Re: 8 ft spark french tesla coil
paulj
Today at 09:40:18 AM
kyledellaquila
Today at 07:04:38 AM
kyledellaquila
Today at 06:43:43 AM
post Difference between halfbridge driver ICs and low/high side drivers?
Arcatarter
Today at 05:49:11 AM
January 25, 2021, 11:51:44 PM
paulj
January 25, 2021, 10:02:48 PM
January 25, 2021, 09:16:22 PM
January 25, 2021, 08:21:56 PM
Bradselph
January 25, 2021, 07:38:55 PM
SalinsLV
January 25, 2021, 05:07:56 PM
January 25, 2021, 05:02:34 PM
post Re: GU5B VTTC Flashover
SalinsLV
January 25, 2021, 04:48:02 PM
January 25, 2021, 04:42:52 PM
January 25, 2021, 01:42:42 PM
January 25, 2021, 12:35:57 PM
paulj
January 25, 2021, 12:13:33 PM
January 25, 2021, 12:06:31 PM
January 25, 2021, 11:24:37 AM
post Re: A new type of eBay drsstc driver?
JCF
January 25, 2021, 11:24:16 AM
January 25, 2021, 11:18:30 AM
January 25, 2021, 11:14:45 AM
January 25, 2021, 09:20:51 AM
January 25, 2021, 09:02:35 AM
January 25, 2021, 08:56:02 AM
January 25, 2021, 08:37:01 AM
January 25, 2021, 08:16:23 AM
January 25, 2021, 07:33:26 AM
zytra
January 25, 2021, 04:12:05 AM
January 25, 2021, 03:31:13 AM
zytra
January 25, 2021, 02:39:08 AM
January 24, 2021, 10:18:13 PM
January 24, 2021, 10:13:16 PM
kyledellaquila
January 24, 2021, 07:11:20 PM
post 833A Cathode Modulation
kyledellaquila
January 24, 2021, 07:09:52 PM
post GU5B VTTC Flashover
SalinsLV
January 24, 2021, 03:01:46 PM
January 24, 2021, 12:57:53 PM
January 24, 2021, 10:26:15 AM
January 24, 2021, 06:09:48 AM
January 24, 2021, 03:57:45 AM
kyledellaquila
January 23, 2021, 07:22:57 PM
January 23, 2021, 07:15:46 PM
January 23, 2021, 06:54:18 PM
January 23, 2021, 06:39:16 PM
kyledellaquila
January 23, 2021, 05:43:59 PM
Acid Byte
January 23, 2021, 03:40:18 PM
pc50kd
January 23, 2021, 02:35:18 PM
paulj
January 23, 2021, 11:00:37 AM
January 22, 2021, 11:23:39 PM
January 22, 2021, 08:09:18 PM
