Author Topic: Simple H-Bridge construction with low parasitic inductances (for SSTC or ...)  (Read 483 times)
A basic half-bridge SSTC makes a great first electronic Tesla coil project.  For example, this SSTC-1 design from KaizerPowerElectronics:
http://kaizerpowerelectronics.dk/tesla-coils/kaizer-sstc-i/
There are two sections to the electronics.  The driver:
http://kaizerpowerelectronics.dk/wp-content/gallery/2009_01_22_-_kaizer_SSTC_I/KaizerSSTCIdriverschematic.gif
And the half-bridge:
http://kaizerpowerelectronics.dk/wp-content/gallery/2009_01_22_-_kaizer_SSTC_I/KaizerSSTCIbridgeschematic.gif
Many first-time builds have problems due to half-bridge construction.  Wires and even device leads have inductance, often enough to disrupt operation.  A wired bridge certlainly can work, as shown in the above links.  However, lower parasitic inductance reduces voltage spikes, making for a more robust build.  Below is a simple technique (no ECBs) for building a half-bridge with low parasitic inductance.  Part labels are from the above KaizerPowerElectronics SSTC-1 bridge schematic.
The key to low inductance is copper planes.  Ideally the planes are on opposite sides of an insulating layer.  Four rectangles of copper foil tape is all it takes for a bridge, two on each side of a flat insulating layer.  Fiberglass or other phenolyc would be ideal for soldering temperatures, but may not be readily available.  Here I use 2mm-thick polycarbonate.  Even though the melting temperature is below soldering temperature, it works well.  Perhaps counter-intuitive, but it works best to use a hot soldering iron.  A hot iron can make joints quickly before the polycarbonate has time to melt.
Apply two rectangles of copper tape to one side of the insulating sheet horizontally, with a small gap between rectangles.  Apply the other two copper rectangles to the other side vertically, again with a small gap.  The gaps form a cross shape.
Simplest construction is to solder parts along the edges.  It's not space-efficient, but works well:
For better space efficiency, parts can be mounted on top of the foil/insulator sandwich.  This requires drilling a couple holes for one lead each of C8 and C9, and cutting a larger clearance hole in the top copper foil.  One lead each of C8 and C9 is bent out horizontally to solder to top copper.  The other lead goes through the hole, then bent horizontally and soldered.
Size of these copper planes and insulator is not at all critical.  Make them fit the pars being used.  The key is just overlapping planes instead of wires, and minimal lead length from part bodies to copper planes.
This can alternatively be constructed from double-sided copper-clad board.  Just cut a horizontal gap in top-side copper and a vertical gap in bottom-side copper.  I find that a dremel-tool cut-off wheel works well.  A hobby knife or round file can work too.  For clearance around through-holes, a few turns by hand of a large drill bit works nicely.  (Not for foil, which tends to tear.)
Notice that the gate-drive wires solder to the FETs (IGBTs in my sample) close to the device bodies, not to the foil planes.  This minimizes source (emitter) inductance that is shared between gate-drive and output current paths.
It is best to use copper foil tape that is wide enough, then cut it down as needed.  Soldering multiple strips of copper tape together is difficult.  Solder resists bridging between sections, as it doesn't wet the sticky layer.  Here's two example EBay listings for 50mm tape (no indorsement - just search result):
https://www.ebay.com/itm/Copper-Foil-Tape-EMI-shielding-for-Guitar-Slug-and-snail-barrier-6x50mm-Folded/273719723048
https://www.ebay.com/itm/3m-50mm-Guitar-Copper-Foil-EMI-Shielding-Tape-for-Electric-Guitar/133531273698
BTW, the top and bottom copper layers can be swapped.  There's nothing magic about which signals are on top.  Also, this works for a full-bridge, by removing C8 and C9 and adding two more IGBTs/FETs along the edge opposite the existing two.
I've since rebuilt this as a full H-Bridge with two parallel TO247 IGBTs for each switch (8 total):
The gap in top-side foil between VBus+ and VBus- isn't visible in these latest images.  Please refer back to the original post.  It's also hard to see, but I've added some 10nF 630V 1206 caps across the VBus+ to VBus- gap adjacent and under the three 3.9uF snubber caps.
The gate-drive diodes and resistors are now on cut copper-clad board using SMD parts.  Had to change values anyway, so went with my typical build technique.  This gate-drive change isn't critical.  (I also added small 3-turn inductors in series with the turn-on gate drive resistors to add a bit more dead-time.)
« Last Edit: November 30, 2020, 08:48:35 PM by davekni »
Offline Da_Stier
Very intersting, I like the additive construction with copper tape instead of milling / etching copper clad.
What ferrite cores do you use for your ethernet cable GDT?
They look like the typ you would get out of VGA cables ;)
Greetings,
Michael
Michael,
The GDT cores are from a surplus store.  Likely were for cables originally.  Only spec's I have are what I measured.  They are 28mm long, 18mm OD, 9mm ID, 2.8uH/turn^2, ~25uVs/turn.  So this 3-turn GDT on two cores is good for ~70kHz and up at room temperature and +-20V gate drive.  To be safe, I don't plan to run it much under 100kHz.
post Alternative phase lead
panjaksli
Today at 10:24:39 AM
post Re: 8 ft spark french tesla coil
Today at 09:40:18 AM
kyledellaquila
Today at 07:04:38 AM
kyledellaquila
Today at 06:43:43 AM
post Difference between halfbridge driver ICs and low/high side drivers?
Arcatarter
Today at 05:49:11 AM
January 25, 2021, 11:51:44 PM
January 25, 2021, 10:02:48 PM
January 25, 2021, 09:16:22 PM
January 25, 2021, 08:21:56 PM
Bradselph
January 25, 2021, 07:38:55 PM
SalinsLV
January 25, 2021, 05:07:56 PM
January 25, 2021, 05:02:34 PM
post Re: GU5B VTTC Flashover
SalinsLV
January 25, 2021, 04:48:02 PM
January 25, 2021, 04:42:52 PM
January 25, 2021, 01:42:42 PM
January 25, 2021, 12:35:57 PM
January 25, 2021, 12:13:33 PM
January 25, 2021, 12:06:31 PM
January 25, 2021, 11:24:37 AM
post Re: A new type of eBay drsstc driver?
JCF
January 25, 2021, 11:24:16 AM
January 25, 2021, 11:18:30 AM
January 25, 2021, 11:14:45 AM
January 25, 2021, 09:20:51 AM
January 25, 2021, 09:02:35 AM
January 25, 2021, 08:56:02 AM
January 25, 2021, 08:37:01 AM
January 25, 2021, 08:16:23 AM
January 25, 2021, 07:33:26 AM
zytra
January 25, 2021, 04:12:05 AM
January 25, 2021, 03:31:13 AM
zytra
January 25, 2021, 02:39:08 AM
January 24, 2021, 10:18:13 PM
January 24, 2021, 10:13:16 PM
kyledellaquila
January 24, 2021, 07:11:20 PM
post 833A Cathode Modulation
kyledellaquila
January 24, 2021, 07:09:52 PM
post GU5B VTTC Flashover
SalinsLV
January 24, 2021, 03:01:46 PM
January 24, 2021, 12:57:53 PM
January 24, 2021, 10:26:15 AM
January 24, 2021, 06:09:48 AM
January 24, 2021, 03:57:45 AM
kyledellaquila
January 23, 2021, 07:22:57 PM
January 23, 2021, 07:15:46 PM
January 23, 2021, 06:54:18 PM
January 23, 2021, 06:39:16 PM
kyledellaquila
January 23, 2021, 05:43:59 PM
Acid Byte
January 23, 2021, 03:40:18 PM
pc50kd
January 23, 2021, 02:35:18 PM
January 23, 2021, 11:00:37 AM
January 22, 2021, 11:23:39 PM
January 22, 2021, 08:09:18 PM
